Prove that every natural number is either odd or even
  • Context: Undergrad
  • Thread starter Thread starter Hobold
    even Natural
The discussion revolves around the proof that every natural number is either odd or even, focusing on the methods of proof, particularly induction, and the definitions of odd and even numbers. Participants explore various approaches and clarify their reasoning within the context of number theory.
  • One participant proposes a proof by induction but expresses uncertainty about its elegance and correctness.
  • Another participant points out that assuming a natural number is not odd implies it must be even, which may not be valid reasoning.
  • A different participant questions the definitions of even and odd, suggesting that if even means divisible by 2 and odd means not divisible by 2, then the statement may not need proving.
  • Some participants suggest refining the proof by considering the smallest element of a set of natural numbers that are neither odd nor even, leading to a contradiction.
  • One participant critiques the use of quantifiers in the original proof, suggesting a clearer formulation using existential quantifiers.
  • Another participant presents a new proof structure, defining even and odd numbers and using induction to demonstrate that all natural numbers belong to the set of either odd or even numbers.
  • Subsequent replies highlight minor issues in the new proof, such as inconsistent notation and clarity in the induction step.
Participants express differing views on the validity of the initial proof and the definitions of odd and even. While some suggest refinements and alternative approaches, there is no consensus on a single correct proof method.
Some participants note limitations in the original proof regarding the use of quantifiers and the clarity of the induction argument. The discussion also reflects varying interpretations of the definitions of odd and even numbers.
Hobold
Hello people.
I'm a freshman in college and I'm looking forward to enter an advanced mathematics program. The admission test is basically number theory & sometimes I get stuck with some questions (I'm using Spivak's Calculus to study).
I'm stuck on question 8, chapter 2.
"Prove that every natural number is either odd or even."
I've come to a solution though I don't think it is right and it doesn't seem very elegant. I'm doing this by induction.
Let X be a non-empty set of natural numbers that are not even or odd.
Let A an specific set of natural numbers that are not odd, so they must be even.
An specific number [tex]n[/tex] is even if, and only if, it satisfies the equation [tex]n=2k,~ \forall k \in \mathbb{Z}[/tex] and odd if, and only if, it satisfies the equation [tex]n=2k +1 ,~ \forall k \in \mathbb{Z}[/tex]
So if A is a non-empty set, it must have a smallest number [tex]y=2x,~ \forall x \in \mathbb{Z}[/tex]
[tex]A(x) = 2x[/tex]
[tex]A(x) + 1 = 2x + 1[/tex]
This way, we proved that the first natural number following an even is odd.
Let B be an specific set of natural numbers that are not even, so it must be odd.
So if B is a non-empty set, it must have a smallest number [tex]i=2j +1,~ \forall j \in \mathbb{Z}[/tex]
[tex]B(j) = 2j +1[/tex]
[tex]B(j) + 1 = 2j + 2 = 2(j+1)[/tex]
Therefore, the smallest natural number after an odd is even. So [tex]A \cup B = \mathbb{N}[/tex] therefore [tex]X = \varnothing[/tex], which contradicts a previous statement, therefore every natural number is either odd or even.
With this statement you are, in effect, assuming what you're trying to prove. In other words, you're saying that if a natural number is not odd, then it must be even. I think, however, that you can "rescue" this proof. Try this: Let A be the set of all natural numbers that are neither odd nor even and suppose that A is nonempty. Let n be the smallest element of A. Then ... .
Try to finish the proof from here. You should be able to arrive at a contradiction. Please post again if you'd like additional hints.
Petek
It is a strange question. What are the precise definitions of even and odd that you are using?
Usually, even means divisible by 2, while odd means not divisible by 2. From this definition there is nothing to prove.
"even" means of the form 2n, "odd" means of the form 2n+1. So proving every natural number is either even or odd has some content.
Proof by induction (or well-ordering) is the way to go, but as noted the proof given by the OP is flawed.
Suppose there is a natural number n that is neither even nor odd. Consider n-1 ... there are three possibilities for n-1 that must be eliminated ... Can you continue?
This is absurd. There is no n that satisfies n=2k FOR ALL k! You meant THERE EXISTS k such that n=2k, i.e. you confused the existential and universal quantifiers.
Induction is indeed the way to go, but I would do it slightly different than g_edgar. Assume that for some k, we have that k is either even or odd. We want to prove that k+1 is either even or odd. Now, for k there are two possibilities: k=2n, or k=2m+1 (for some natural numbers n,m). In both cases, consider k+1, and finish the proof.
Is this one valid?
Define S to be the set of all natural numbers that are neither even or odd, and assume it is non empty. Every subset of the natural numbers must have a least element; let this element be s. Consider s-2. s-2 can not be of the form 2n, because then s= 2n+2 = 2(n+1) for some natural number n, ie even, which it can not be. So s-2 is not even. s-2 can not be of the form 2n+1 either, as s would be 2(n+1) + 1, which it can not be. So then s-2 is neither even nor odd, so is in the set S. But s-2 is less than s, and s was defined the be the least element. Contradiction.
Looks good. One detail: you should notice that s>2, so that s-2>0, otherwise s-2 would be negative and hence not in S which gave you the contradiction. Of course, s>2 because 1 and 2 are even or odd.
Thanks for posting, people, it's nice to see other solutions. I've come to a new one. Is this correct?
Definition: A natural number n is:
(i) even,if [tex]\exists ~ m \in \mathbb{N} ~\text{for which}~ n=2m[/tex]
(ii) odd,if [tex]\exists ~ m \in \mathbb{N} ~\text{for which}~ n=2m-1[/tex]
Theorem: Every natural number is either odd or even.
Demonstration: Let [tex]A = \{ n \in \mathbb{N} :~ \text{n is odd or n is even}~ \}[/tex]
[tex]1 = 2\cdot 1 - 1 \therefore~ \text{1 is odd}~ \therefore 1 \in A[/tex]
Suppose [tex]p \in A[/tex], we have two possibilities:
(a) p is even, [tex]\therefore p=2m~ \text{for some}~ m\in \mathbb{N} \therefore p +1 = 2m+1 = 2(m+1)-1 \in \mathbb{N} \therefore p+1~ \text{is odd}~ \therefore p+1 \in A[/tex]
(b) p is odd, [tex]\therefore p=2m-1~ \text{for some}~ m\in \mathbb{N} \therefore p +1 = 2m-1+1 = 2m \in \mathbb{N} \therefore p+1~ \text{is even}~ \therefore p+1 \in A[/tex]
[tex]\therefore[/tex] by induction [tex]A = \mathbb{N}[/tex]
Steps a and b use N instead of A in several places, and you don't say "by induction" which makes the final step slightly unclear. But the basic idea is right.
Thanks, edited a little so things make more sense.
  • · Replies 21 ·
  • · Replies 24 ·
  • · Replies 26 ·
  • · Replies 19 ·
