Thread Closed
Fortran Program Won't run
Share Thread
Apr15-10, 07:07 PM   #1
We made a program for our thermo class and when we go to run it, it tells us errors were encountered but will not display what errors it has. It won't print out anything. I appreciate any help you guys have to offer.
Print *, 'Nicholas Grover / Corey Demers'
Print *, 'Thermodynamics II FORTRAN problem'
C 4/16/06
C Program Thermo
Implicit None
Real T2, T3, T5, thN, Tpe
Real Wcs, Wts, Wc, Wt, Wnet, regN, Qh, Qr
Integer rv, T4
Print *, 'Pr Temp Nreg Nth Wnet'
Print *, '============================='
Do 10 rv = 4,4,2
Do 20 T4 = 1620, 4, 360
Do 30 regN = 0,.05,19
Call Compressor(Wc,rv,Wcs)
Call Turbine(Wts,Wt,T5,rv,regN,T4)
Call HighHEX(T3,T2,T5,Tpe,Qr,Qh,regN,rv)
Wnet = Wt - Wc
thN = Wnet/Qh
Print 40, rv,T4,regN,thN,Wnet
30 Continue
20 Continue
10 Continue
40 Format(1x,F1.0,F8.0,F7.2,F6.2,F7.2)
END
C *--------------------------------------------------------------*
Subroutine Compressor(Wc,rv,Wcs)
Real Wc,T2,Wcs
Integer rv
T2=540*rv**(.4/1.4)
Wcs= .24*(540-T2)
Wc=(Wcs/.81)
END
Subroutine Turbine(Wts,Wt,T5,rv,regN,T4)
Real Wts,Wt,T5,dP,regN
Integer T4,rv
dP=(.5*regN)/(1-regN)
P2=rv*14.7
P4=dP+P2
P5=14.7+dP
T5=T4*(P5/P4)**(.4/1.4)
Wts=(-.24)*(T5-T4)
Wt=Wts*.87
END
Subroutine HighHEX(T3,T2,T5,Tpe,Qr,Qh,regN,rv)
Real T3,T2,T5,Tpe,Qr,Qh,regN
integer rv
T2=540*rv**(.4/1.4)
T3=T2+(T5-T2)*regN
Tpe=T3+180
Qr=(-.24)*(Tpe-3060)
Qh=Qr*(-1)
END
C *---------------------------------------------------------------*
Thanks again!
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Apr15-10, 07:09 PM   #2
Mentor
Quote by FortranFreaks View Post
C 4/16/06
C Program Thermo
Implicit None
Integer rv, T4
Do 10 rv = 4,4,2
Wnet = Wt - Wc
thN = Wnet/Qh
30 Continue
20 Continue
10 Continue
END
Real Wc,T2,Wcs
Integer rv
T2=540*rv**(.4/1.4)
Wcs= .24*(540-T2)
Wc=(Wcs/.81)
END
Integer T4,rv
P2=rv*14.7
P4=dP+P2
P5=14.7+dP
Wts=(-.24)*(T5-T4)
Wt=Wts*.87
END
integer rv
T2=540*rv**(.4/1.4)
T3=T2+(T5-T2)*regN
Tpe=T3+180
Qh=Qr*(-1)
END
Thanks again!
What compiler are you using? Any clues why it won't show you the error messages? Are they maybe getting piped to some error file somewhere?
If you strip the program down (comment out stuff), can you get the simplified version to compile?
Apr15-10, 07:13 PM   #3
Force 2.0
We tried it without the subroutines but it gave us the same problem.
C Program Thermo
Implicit None
Real T2, T3, T5, thN, Tpe, dP, P2, P4, P5
Integer rv, T4
Do 10 rv = 4,4,2
T2=540*rv**(.4/1.4)
Wcs= .24*(540-T2)
Wc=(Wcs/.81)
P2=rv*14.7
P4=dP+P2
P5=14.7+dP
Wts=(-.24)*(T5-T4)
Wt=Wts*.87
T2=540*rv**(.4/1.4)
T3=T2+(T5-T2)*regN
Tpe=T3+180
Qh=Qr*(-1)
Wnet = Wt - Wc
thN = Wnet/Qh
30 Continue
20 Continue
10 Continue
END
Apr15-10, 07:29 PM   #4
Mentor
These lines are screwy.
Code:
Do 10 rv = 4,4,2
The first one says to do (execute) the code up through line 10, starting with rv = 4, up through rv = 4, in increments of 2.
The second one says to execute the code up through line 20, starting with T4 = 1620, up through T4 = 4, in increments of 360.
The third one says to execute the code up through line 30, starting with regN = 0, up through regN = 0.05, in increments of 19.
I haven't done any Fortran for awhile, but I don't think any of your loops will run at all.
What values do you want rv to have (start, end, increment)? Same for T4 and regN.
Apr15-10, 07:30 PM   #5
Mentor
How much do you have to strip out to get it to run? Have you successfully compiled previous programs, or is this your first one?
If you've used this compiler before, has it shown you error messages? Have you looked in its Help files to see if you have to turn on a verbose mode or something?
EDIT -- good catches by Mark. Still seems like the compiler must be tossing those error statements someplace though...
Apr15-10, 08:12 PM   #6
Even a bad compiler will give a line number where it has trouble.
Apr15-10, 08:24 PM   #7
Quote by Mark44 View Post
Code:
Do 10 rv = 4,4,2
Is this better?
Do 10 rv = 4,10,2
Do 20 T4 = 1620, 2700, 360
Do 30 regN = 0, .95, .05
I need it to do all combinations for
rv: 4, 6, 8, 10
T4: 1620, 1980, 2340, 2700
regN: 0, .4, .5, .6, .7, .8, .9, .95
Quote by berkeman View Post
I have not used it before but it will run if I make a very basic program. When I first wrote it, it would display all the errors at the bottom and I fixed them one by one until they were all gone. So it no longer displays any errors but will say some were encountered.
Apr15-10, 08:26 PM   #8
It is giving me this as output
C:\Documents and Settings\Corey\My Documents\THERMO FORTRAN PROBLEM.f: In program `MAIN__':
C:\Documents and Settings\Corey\My Documents\THERMO FORTRAN PROBLEM.f:1:
C:\Documents and Settings\Corey\My Documents\THERMO FORTRAN PROBLEM.f:7: (continued):
Implicit None
Statement at (2) invalid in context established by statement at (1)
C:\Documents and Settings\Corey\My Documents\THERMO FORTRAN PROBLEM.f:9: (continued):
C:\Documents and Settings\Corey\My Documents\THERMO FORTRAN PROBLEM.f:10: (continued):
C:\Documents and Settings\Corey\My Documents\THERMO FORTRAN PROBLEM.f:11: (continued):
Integer rv, T4
C:\Documents and Settings\Corey\My Documents\THERMO FORTRAN PROBLEM.f: In subroutine `compressor':
C:\Documents and Settings\Corey\My Documents\THERMO FORTRAN PROBLEM.f:22: warning:
C:\Documents and Settings\Corey\My Documents\THERMO FORTRAN PROBLEM.f:42: (continued):
Argument #2 (named `rv') of `compressor' is one type at (2) but is some other type at (1) [info -f g77 M GLOBALS]
C:\Documents and Settings\Corey\My Documents\THERMO FORTRAN PROBLEM.f: In subroutine `turbine':
C:\Documents and Settings\Corey\My Documents\THERMO FORTRAN PROBLEM.f:23: warning:
C:\Documents and Settings\Corey\My Documents\THERMO FORTRAN PROBLEM.f:55: (continued):
Argument #4 (named `rv') of `turbine' is one type at (2) but is some other type at (1) [info -f g77 M GLOBALS]
Argument #6 (named `t4') of `turbine' is one type at (2) but is some other type at (1) [info -f g77 M GLOBALS]
C:\Documents and Settings\Corey\My Documents\THERMO FORTRAN PROBLEM.f: In subroutine `highhex':
C:\Documents and Settings\Corey\My Documents\THERMO FORTRAN PROBLEM.f:24: warning:
C:\Documents and Settings\Corey\My Documents\THERMO FORTRAN PROBLEM.f:70: (continued):
Argument #8 (named `rv') of `highhex' is one type at (2) but is some other type at (1) [info -f g77 M GLOBALS]
Apr15-10, 08:31 PM   #9
Mentor
Is this better?
Do 10 rv = 4,10,2
rv: 4, 6, 8, 10
Yes, these look reasonable.
Apr15-10, 08:33 PM   #10
Mentor
I think that the compiler is complaining about the two PRINT statements at the top. I believe that they need to be after your declarations, not before them. See if that makes a difference.
Apr15-10, 08:59 PM   #11
Sweet! That was the problem, just need to figure out the new problems I'm encountering.
Apr15-10, 09:01 PM   #12
Mentor
Keep us posted. I'll be offline for awhile.
Apr15-10, 09:56 PM   #13
Does anyone know why my given rv and T4 values are being printed as all zeros?
Apr15-10, 10:50 PM   #14
Mentor
Code:
Integer rv, T4
First off rv and T4 are declared as Integer types. Your format statement doesn't match these types. The Fx.x field specifiers are for real values, with F1.0 being used to print a real number in a field of width 1 space. The next one, F8.0 is used for T4, printing it in a field of width 8 characters, but with no places to the right of the decimal point. The appropriate specifier for Integer values is I4 or I6, or something big enough to hold the values you need printed. You should ask yourself though, whether Integer is the right type for these two variables. I haven't looked at your code close enough to say one way or the other.
If you fix these things, and you're still getting 0's for rv and T4, then the time-honored way of debugging is to sprinkle PRINT (or WRITE) statements at places in your code where these variables are getting set. Knowing the value of a variable is always better than guessing its value.
That's an obvious place to star
Apr18-10, 12:59 PM   #15
Thanks for the help! We ended up getting it running.
Apr18-10, 10:28 PM   #16
Mentor
Code:
Integer rv, T4
That's an obvious place to start.
xxxx
Thread Closed
Similar discussions for: Fortran Program Won't run
Thread Forum Replies
c program Programming & Comp Sci 0
running a Fortran 77 program in a C++ enviorment/program Programming & Comp Sci 2
how to program? Programming & Comp Sci 4
Astro simulation program problem - program bugs? Astrophysics 4
