Interpreting the probability distribution of the potential step
The discussion revolves around the interpretation of the probability distribution associated with the wavefunction solutions for a potential step problem in quantum mechanics, particularly when the energy of the incident particle is less than the potential step height. Participants explore the implications of non-normalizable solutions and their physical significance.
  • Some participants note that for a potential step where the energy E is less than V_0, the wavefunction yields a non-normalizable solution, raising questions about the interpretation of |\psi|^2.
  • Others argue that the non-normalizable solution should be discarded as it does not belong to Hilbert Space and is not a valid probability amplitude.
  • A participant provides a detailed form of the wavefunction and its squared modulus, highlighting the presence of a cosine wave for x<0 and a constant for x>0, both of which are non-normalizable.
  • Some participants suggest that the solutions can be interpreted as plane wave solutions, indicating interference between incoming and reflected waves, but acknowledge the limitations of this interpretation due to the time-independent nature of the solutions.
  • Another participant challenges the provided solutions, suggesting that the form for x>0 should involve an exponential decay, indicating a misunderstanding of the wavefunction behavior in that region.
  • There is a discussion about the amplitudes of the incoming and reflected waves, with some participants asserting they should differ while others maintain they can be the same under certain conditions.
Participants express differing views on the validity and interpretation of the wavefunction solutions for E < V_0. There is no consensus on whether the non-normalizable solutions can be interpreted meaningfully or should be discarded, and disagreements arise regarding the correct form of the wavefunctions in different regions.
The discussion highlights the complexities involved in interpreting quantum mechanical solutions, particularly regarding normalization and physical significance. Participants reference mathematical forms and properties of wavefunctions without resolving the underlying assumptions or definitions that may affect their interpretations.
Identity
Say you have a potential step problem where the potential steps up from [tex]V=0[/tex] to [tex]V=V_0[/tex] at [tex]x=0[/tex]. If the incident particle has energy [tex]E <V_0[/tex], you get a non-normalisable solution for the wavefunction.
How can you interpret [tex]|\psi|^2[/tex] for this non-normalisable solution? Is it still the probability density or does it mean something else?
Thanks
You get two solutions, one is normalizable and one is not. We throw out the non-normalizable solution as it is not in Hilbert Space and is not a probability amplitude. It is curious why it is there, I think it stems back to our method of differential equations, rigorous mathematics may prove it is not a solution.
I'm not sure if you understood what I meant, sorry
The general solution is of the form:
[tex]\psi(x) = \begin{cases} Ae^{ik_1x}+A\frac{k_1-k_2}{k_1+k_2}e^{-ik_1x} \ \ \ \ \ \ x < 0\\\\ A\frac{2k_1}{k_1+k_2}e^{ik_2x}\ \ \ \ \ \ x \geq 0\end{cases}[/tex]
Hence,
[tex]|\psi(x)|^2 = \begin{cases} A^2\left[1+\left(\frac{k_1-k_2}{k_1+k_2}\right)^2+2\frac{k_1-k_2}{k_1+k_2}\cos{2k_1x}\right] \ \ \ \ \ \ x < 0 \\\\ A^2\frac{4k_1^2}{(k_1+k_2)^2}\ \ \ \ \ \ x \geq 0\end{cases}[/tex]
For [tex]x<0[/tex] we have a cosine wave which can't be normalised, since it has a vertical translation
For [tex]x>0[/tex] we have a constant, which is certainly not normalisable.
The are continuous and differentiable at [tex]x=0[/tex], and in all regions satisfy the Schrödinger equation for the potential step
However, since they are NOT normalisable, how do you interpret them?
Hence,
The solutions you are talking about are the plane wave solutions, and all of the problems you raise are also problems for a plane wave. Mathematically, plane waves are the momentum eigenstates, so you could interpret your results as showing the intereference between the incoming and reflected plane waves in the x<0 region, and as showing the transmitted plane wave in the x>0 region. However, there is a chicken and egg problem with this analysis, because it is time-independent and distributed over all space. Thus, as you say, it is a mathematical solution with little direct physical significance.
If you want to make your life a little harder, you can try solving the time-dependent version of this problems, where you start with a (normalized) wavepacket incident on the barrier from one side or the other. You can then propagate the wavepacket and see what happens when it encounters the barrier. The math is significantly more difficult, but the results are more physically significant. However, the qualitative insights about quantum phenomena are the same; the wavepacket splits into a reflected part and a transmitted part, and the reflected part interferes with the incoming wavepacket on its way back out (for a finite time).
Thus the static plane wave picture still gets you the quantum weirdness (barrier penentration for E<V and over-barrier reflection for E>V), but you have to work a lot less hard on the math. I think that is the main reason that the plane wave solutions for this 1-D problem (and many others), are taught in intro courses.
I don't see how you got those solutions for E less than V. For X > 0 you should have
Cexp[-sqrt(2m(V-E))x/h-bar]
I use C as a constant because the amplitude changes when the potential changes. Also the exponential is negative, the positive exponential is thrown out.
Also your incoming and reflected waves functions should not have the same amplitude.
For [itex]x>0[/itex], [itex]\psi \left( x \right)[/itex] is okay if [itex]k_2[/itex] is imaginary, but [itex]\left| \psi \left( x \right) \right|^2[/itex] is incorrect because then [itex]\left| \exp \left( i k_2 x \right) \right| \ne 1[/itex].
I think they are okay. Note that the reflected wave has a constant multiplying [itex]A[/itex].
Ahh..
Yes, you are right ... I had just assumed we were talking about E>V ... for which he gave the correct solutions.
  • · Replies 22 ·
  • · Replies 22 ·
