Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Quantum Physics
Reply
image Two concepts about quantum electrodynamics and quantum field theory Share It Thread Tools Search this Thread image
Old Aug8-04, 05:03 AM                  #1
guo_xiaobo
guo_xiaobo is Offline:
One question has disturbed me long time, I don't know the distinction between quantum electrodynamics and quantum field theory.
By the way, which quantum field thoery or quantum electrodynamics textbook is prefer?
Old Aug8-04, 05:14 AM                  #2
΅³
΅³ is Offline:
I'm not too sure but quantum electrodynamics (along with quantum chromodynamics, and quantum electroweak theory) are branches of quantum field theory. QED deals primarily with the electromagnetic force.
http://en.wikipedia.org/wiki/Quantum_electrodynamics
http://en.wikipedia.org/wiki/Quantum_field_theory
Old Aug8-04, 07:00 AM       Last edited by humanino; Aug8-04 at 07:03 AM..            #3
humanino
humanino's Avatar
humanino is Offline:
Recognitions:
PF Contributor PF Contributor
Quantum field theory is the general theory resulting from attempts to put quantum mechanics and special relativity together.
Quantum electrodynamics is the resulting quantum field theory when applied to electromagnetic phenomena. But LaTeX Code: \\mu^3 had already said it.
Old Aug8-04, 08:58 AM                  #4
selfAdjoint
selfAdjoint is Offline:
Recognitions:
Retired Staff Retired Staff
Quantum field theory is the general study of quantized fields. There are a number of different ones, for different fields, some only studied for educational purposes. QED is one such theory, the quantized relativistc electromagnetic field. There were originally three formulations of QED, due to the three discoverers Schwinger, Tomonaga, and Feymann. But Dyson showed they were all equivalent, and the only difference was how you developed the equations.
Other quantum field theories that are studied are the Electroweak theory, which is the unification of electromagnetism with the weak force, and QCD, the field theory of the strong force. The standard model is a unification of these last two theories. There are conjectures of theories beyond the standard model, but none of them has yet emerged as a true competitor for it.
Old Aug8-04, 03:00 PM                  #5
vanesch
PF Mentor
vanesch is Offline:
I just finished reading "Quantum Field Theory in a Nutshell" by A. Zee and I have to say it is simply brilliant. The only problem (but also the strong point) is that he jumps over a lot of calculations, to give you the basic ideas, but if you want to sit down with pencil and paper, it is a lot harder. The book that takes the opposite approach (a classic by now) is Peskin and Schroeder, Introduction to quantum field theory. They explain you all the calculations in all details, but sometimes you get a bit lost between all the calculational technicalities. Both books will probably get you going.
cheers,
patrick.
Old Aug8-04, 06:13 PM       Last edited by humanino; Aug8-04 at 06:14 PM.. Reason: typo            #6
humanino
humanino's Avatar
Recognitions:
I fully agree with Patrick. I ate Zee's Nutshell in a few hours. One gets a clean overview from the introduction of Fields as matress vibrations, to advanced subject such as supersymmetry unification strings gravity which are usually not even mentinoned in good introductory texts. There are numerous examples and application in condensed matter. This compares well to Peskin and Scrhoeder one which a I was already working at that time. Having those two books together to discover the subject is fascinating. One completes what misses in the other.
Old Aug9-04, 05:01 PM                  #7
Eye_in_the_Sky
Eye_in_the_Sky is Offline:
A principle of complementarity
Consider the following statement:
And now consider this one:
The first description is in terms of "historical events with regard to human efforts". The second is in terms of "the objects of the theory". Each description is given from a different perspective, and each one, relative to the other, enhances our appreciation of "what QFT is".
To my eye, it is no coincidence that the former description is offered by one called "humanino", while the latter is offered by one called "selfAdjoint".
Furthermore, the first description tells us that, in the nonrelativistic domain, we have no particular need for QFT, while the latter suggests to us that, nevertheless, in that domain, QFT can still be applied.
Old Aug9-04, 05:11 PM                  #8
marlon
marlon's Avatar
marlon is Offline:
in the nonrelativistic domain QFT has to be valid. It has <to produce the same results as QM. Just as QM has to give the same results as Newtonian mechanics when you look at distances that are not to small that interference-effects come into play... This is the correspondence-principle.
regards
marlon
Old Aug9-04, 05:56 PM                  #9
vanesch
PF Mentor
vanesch is Offline:
I suppose that Eye meant the applications of the methods of quantum field theory in condensed matter physics where the fields are not "elementary fields" such as the electron field or so, but constructs that exhibit collective phenomena.
cheers,
patrick.
Old Aug10-04, 11:33 AM       Last edited by Eye_in_the_Sky; Aug10-04 at 11:35 AM..            #10
Eye_in_the_Sky
Originally Posted by Eye_in_the_Sky
... the first description tells us that, in the nonrelativistic domain, we have no particular need for QFT, while the latter suggests to us that, nevertheless, in that domain, QFT can still be applied.
The above remark was intended to dispel the not uncommon misconception in which the notion of a "quantized field" is thought to apply strictly to a relativistic domain.
So, what is an example of a nonrelativistic domain in which QFT can be applied, yet for which it may be said that QFT satisfies no particular need?
Well, quite simply ... take the single-particle Schrφdinger field and quantize it.
Upon doing that ... what do we get?
(note: x is a spin-space index; i.e. x=(s,x), δ(x-x')=δ3(x-x')δss')
case (1): [Ψ(x,t),Π(x',t)]=ihbarδ(x-x') → Fock space for identical Bosons
case (2): {Ψ(x,t),Π(x',t)}=ihbarδ(x-x') → Fock space for identical Fermions
In QM, on the other hand, the Fock space is constructed by taking a direct sum of a one-dimensional Hilbert space plus a series (n = 1,2, ...) of appropriately symmetrized n-particle Hilbert spaces. Thus, QFT gives us the exact same thing back (except (with the "bonus") that the symmetrization postulates for multiparticle states in QM have been replaced by the commutator-anticommutator rules of QFT (which themselves are on par with (i.e. no stronger than) QM's rule [Qj,Pj'] = ihbarδjj')).
Old Aug10-04, 08:15 PM                  #11
Haelfix
Haelfix is Offline:
Recognitions:
For a nice little challenge, try writing down what the infinite square well potential from vanilla quantum mechanics would be in the QFT context.
Old Aug11-04, 06:24 AM                  #12
Eye_in_the_Sky
Assuming the particle to be spinless, I get:
Ψ(x,t) = Σn bn exp(-iEnt/hbar) φn(x)
Ψ†(x,t) = Σn bn† exp(iEnt/hbar) φn*(x)
where
En = kn2 (hbar2/2m)
kn = n (π/L)
φn(x) = sqrt(2/L) sin knx
n = 1, 2, 3, ...
and each bn† (bn) is a creation (annihilation) operator, relative to the single-particle energy eigenstates, for a particle with energy En.
If a†(k) and a(k) are creation and annihilation operators with respect to momentum, then from
<x|a†(k)|0> = [1/sqrt(L)] eikx
and
<x|bn†|0> = sqrt(2/L) sin knx
it follows that
bn† = -i/sqrt(2) [a†(kn) - a†(-kn)]
bn = i/sqrt(2) [a(kn) - a(-kn)] .
Pure "vanilla" ... and not a drop of "fudge"!
(I have the sneaking suspicion that somehow I circumvented the "challenge".)
Old Aug11-04, 09:47 AM                  #13
guo_xiaobo
Thank you for your answers!
I think the QED is just an application of QFT, in other words, it's an special example,
of cause, the application to electronicmagnetism is very successfully. we called it QED.
and, the QFT contains the weakforce , strongforce and electromagneism force.
Old Aug11-04, 10:35 AM                  #14
ZapperZ
PF Mentor
ZapperZ's Avatar
ZapperZ is Offline:
Actually, QFT is even more general than that.
QFT is a treatment or a description of the interaction in quantized fields of anything. In fundamental interactions, this reduces to the basic interactions of strong, weak, and electromagnetic. However, these are NOT the only types of interactions that QFT are used for. In condensed matter physics (where field theoretic methods are used to the full extent), the quantized fields can range from phonons, magnons, polarons, spinons, etc... These are the "collective" fields that cause the relevant interactions in a condensed matter system. In fact, a lot of the the methodologies and techniques used in condensed matter have been adopted by particle physics and field theories (eg. Anderson's broken symmetry principle).
So to put it crudely, QFT is a description of ANY kind of interaction.
Zz.
Old Aug11-04, 12:20 PM                  #15
vanesch
PF Mentor
vanesch is Offline:
To add to what Zapper said, QFT is a framework. QED is a theory within that framework about electromagnetism. What you write above is another theory within the same QFT framework, called the standard model.
It is a matter of definition of words. If you want an analogy: QFT is like the laws of mechanics (Newton's law and so on), while QED is like the mechanics of a weight on a spring, and the standard model is like the mechanics of two bodies with gravitational interaction. The frame is mechanics, and the specific applications are weight+spring, or two bodies and gravity.
cheers,
Patrick.
Old Aug11-04, 03:22 PM                  #16
Haelfix
Haelfix is Offline:
Recognitions:
Yea the challenge is to do it with the path integral formulation, and I just realized the subtetly is with the finite square well potential =)
image image
Reply
Thread Tools
Similar Threads for: Two concepts about quantum electrodynamics and quantum field theory
Thread Thread Starter Forum Replies Last Post
[SOLVED] Quantum Field Theory: Field Operators and Lorentz invariance flix Quantum Physics 6 Mar31-08 01:23 PM
Is quantum field theory a genuine quantum theory? Demystifier Quantum Physics 3 Jun4-07 10:23 AM
Help! Quantum Field Theory grahamc Quantum Physics 1 Jan30-07 04:02 AM
What is quantum field theory? Mike2 Quantum Physics 31 Apr20-04 12:35 PM
quantum field theory kurious High Energy, Nuclear, Particle Physics 9 Mar30-04 03:35 AM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
