Is Normalizing Oxygen Concentrations in a Channel Accurate?
  • Thread starter Thread starter howtophysics
    Partial
The discussion centers on the accuracy of normalizing oxygen concentrations in a channel where cells consume oxygen. It establishes that the partial pressure (PP) of oxygen in water saturated with air matches the PP of oxygen in the surrounding air. As oxygen is consumed along the channel, the PP decreases, and normalizing measured values against the inlet (saturated PP concentration) should yield consistent results when compared to absolute concentrations expressed in mol/m³. The conclusion is that both normalized graphs should align under controlled conditions, confirming the reasoning presented.
  • Understanding of partial pressure (PP) concepts
  • Knowledge of oxygen saturation in water
  • Familiarity with normalization techniques in scientific measurements
  • Basic principles of gas exchange in aquatic environments
  • Research methods for measuring partial pressure of gases in liquids
  • Explore oxygen saturation dynamics in aquatic systems
  • Learn about normalization techniques in environmental science
  • Investigate the impact of temperature and pressure on gas solubility
Researchers in environmental science, marine biologists, and anyone involved in studying gas exchange processes in aquatic ecosystems will benefit from this discussion.
howtophysics
Tell me if this line of reasoning is correct:
The partial pressure (PP) of oxygen in water which is saturated with air is the same as the partial pressure of the oxygen in the air around the water. Now, if I have a channel where cells are consuming oxygen, the PP is going to be going down over the length of the channel. Now, let's say I am measuring the partial pressure of the oxygen along the bottom of the channel (where the cells are) and I normalize these values against the inlet (saturated PP concentration) -- now let's say I have a model which gives me oxygen concentrations in terms of absolute concentrations along the bottom of the same channel (i.e. in mol/m^3) - I then normalize these concentrations against the inlet concentration.
Shouldn't these too normalized graphs be the same (assuming nothing else happens [other changes in temperature and pressure] - and both cases are describing the same system under the same conditions)?
Chemistry news on Phys.org
Sounds reasonable to me.
24K
