Understanding Litmus: pH Indication with Lichens and Dyes
  • Thread starter Thread starter jackson6612
    Ph
The discussion revolves around the properties and applications of litmus as a pH indicator, particularly focusing on its chemical nature, the source of its dyes from lichens, and the historical context of its use. Participants explore the behavior of litmus in various pH conditions and the implications of irreversible reactions with certain chemicals.
  • One participant notes that litmus is a mixture of dyes extracted from lichens, specifically Roccella tinctoria, and works within a pH range of 4.5-8.3.
  • Another participant claims that litmus can indicate pH levels outside the specified range, turning red below 4.5 and blue above 8.3.
  • There is a discussion about the historical discovery of litmus, with one participant suggesting it was a coincidence that someone found its color-changing properties when introduced to acids or bases.
  • A participant shares a personal anecdote about using red wine as an indicator, suggesting that the discovery of pH indicators may not be as straightforward as deriving it from first principles.
  • One participant explains that while litmus can be easily reversed between red and blue in acid and base tests, it cannot return to its original state after reacting with chlorine, indicating an irreversible reaction.
  • Another participant mentions that lichens contain interesting dyes, which can be analyzed through chromatography, and that some lichens have historically been used for dyeing cloth.
  • A participant speculates on the historical context of litmus production, linking it to medieval society's fascination with the color purple and the dye's chemical behavior in alkaline solutions.
Participants express differing views on the behavior of litmus outside its typical pH range and the historical context of its discovery. There is no consensus on the exact mechanisms or implications of the reactions discussed.
Participants highlight various assumptions about the chemical behavior of litmus and the historical context of its use, but these assumptions remain unresolved and depend on interpretations of historical practices and chemical properties.
jackson6612
I'm not a chemistry student. So, I humbly request you to limit yourself to the basics, please do not indulge in infighting. If you ignore the request, you would be investing your efforts at the wrong place and perhaps it would be considered a pretentious show of knowledge.
Litmus is a water-soluble mixture of different dyes. It works between the pH range 4.5-8.3. To cover the full of spectrum of pH, 1-14, universal indicator is used.
The dyes used in the litmus are extracted from lichens, especially Roccella tinctoria.
Lichens are composite organisms consisting of a symbiotic association of a fungus with a photosynthetic partner, usually either a green alga or cyanobacterium.
Here dye is certain chemical which can be single molecule or a group of different molecules and behaves in a particular way under different pH conditions.
1: As it is stated above that the litmus can only used when the range is between 4.5-8.3, what would happen to the litmus or dyes or their color patterns when pH is outside this bound?
2: How did someone come up with the idea that some weird composite organisms called lichens can be used to tell the acidity of the solution? It was not like that someone accidently dropped few grains of table salt or sugar into the solution and discovered that it could be used for acidity test.
Wikipedia says: Chemical reactions other than acid-base reaction can also cause a color-change to litmus paper. For instance, chlorine gas turns blue litmus paper white – the litmus paper is bleached. This reaction is irreversible and therefore the litmus is not acting as an indicator in this situation.
3: What does it mean by 'irreversible' here? Perhaps, it means that chlorine somehow permanently damages the dyes and even if it is evaporated or removed fully, the dyes wouldn't retain their original property and couldn't be used for the test again.
Chemistry news on Phys.org
1) Litmus can be used outside the 4.5-8.3 range. It will be red below 4.5 and blue above 8.3
2)Well, I'd say it was just a coincidence: someone dropped in an acid or base and found out that it changes collors. I think it would be hard to derive from first principles which types of substances are indicators.
(In fact, just a few weeks ago, I found out that some types of wine can be used as indicators. I was washing some dishes and a red wine spot turned blue. Than I did a few other tests and confirmed this is the case. So the whole idea of "someone just accidentaly dropped litmus in acid and found out it changed color" is not as absurd as it may sound)
3)Litmus is red in acidic medium. You can turn it blue by adding base. You can turn it red again using acids. You can turn it blue again by adding base. You can turn it... You got the idea: when litmus is used in acidity/basicity tests, it's very simple to reverse its color.
When you use it for testing chlorine, however, litmus can't be brought to its original state. So litmus reacted with chlorine irreversably.
Remains to be said that lichens quite generally contain interesting dyes and that chromatography of these dyes is even used to distinguish species.
Some lichens were (and are) also used to dye cloth.
The fascination of medieval society with the color purple is likely the impetus for the experimentation with the extraction and production of litmus. At some point during manufacture, the dye contains both blue and red (purple) components in alkaline solution. This was http://www.ravensgard.org/gerekr/Orchil.html"
20K
  • · Replies 20 ·
166K
  • · Replies 21 ·
  • · Replies 266 ·
33K
10K
