| Thread Closed |
Intuitive Difference Between Weak And Strong Convergence in Probability |
Share Thread | Thread Tools |
| Sep17-10, 08:46 PM | #1 |
I've seen numerous rigourous/conceptual explanations of the difference between convergence in probability (weak), and strong, almost sure convergence.
One explanation my prof gave was that convergence in probability entails: [tex]\lim_{n \rightarrow \infty} \mathbb{P}\left\{|X_{n}-X|<\epsilon\right\}=1[/tex] or: [tex]\lim_{n \rightarrow \infty} \mathbb{P}\left\{\omega:|X_{n}(\omega)-X(\omega)|>\epsilon\right\}=0[/tex] While strong convergence means: [tex]\mathbb{P}\left\{\lim_{n \rightarrow \infty} X_{n}=X\right\}=1[/tex] So my prof explains one difference is the limit is taken outside the probability for convergence in probability, while it is inside the probability for almost sure convergence. Can anyone elaborate on this? Also, the limits in both forms of convergence seem to imply the same thing. How is it that saying the probability that [itex]|X_{n}-X|[/itex] is greater than some epsilon, goes to 0 for large n, implies that difference can jump above epsilon, infinitely many times? And if it does, how is it that saying the probability of it staying below epsilon goes to 1, as n goes to infinity, implies that it CAN'T jump above epsilon EVER, after some n? (And is thus a somehow stronger form of convergence). Thanks! |
| Sep22-10, 08:10 PM | #2 |
Weak convergence is analogous to the probability density of an event under an infinite continuous distribution. An infinite distribution cannot be uniform. Given that some events have a non zero probability density, then for every event, there can be an event with a smaller non zero probability density. Note that the closed interval [0,1] is finitely bounded by, and includes, 0 and 1 while the range of the Gaussian pdf is not finitely bounded. BTW my intuition based on this example may be too restrictive or even wrong; in which case I'm sure someone will jump in and correct me. I responded because your post has gone unanswered for a while. Essentially, my understanding of strong convergence of a probability is defined in terms of a sample space while almost everywhere convergence is defined in terms of a pdf. |
| Sep23-10, 02:39 AM | #3 |
| Thread Closed |
| Tags |
| law of large numbers, probability, strong convergence |
| Thread Tools | |
Similar Threads for: Intuitive Difference Between Weak And Strong Convergence in Probability
| Thread | Forum | Replies | ||
| Weak/Strong Acid w/ Strong Base Titrations and pH Indicator Selection Help | Biology, Chemistry & Other Homework | 1 | ||
| Weak and strong equivalence- what is the difference really? | Special & General Relativity | 2 | ||
| Weak, Strong convergence of the discretized solutions of a variational problem | Calculus & Beyond Homework | 0 | ||
| Weak and strong interaction | General Physics | 0 | ||
| Strong or Weak? | General Discussion | 4 | ||
