Fortran Debugging Strange Fortran Code: A Simple Delta Function
The discussion revolves around a Fortran code snippet intended to implement a delta function. The user encounters issues with the output when using a function to calculate the delta function, which produces unexpected results compared to a direct calculation. The problem is identified as a type mismatch: the function expects an eight-byte double-precision floating point value, but the user was passing a four-byte single-precision value due to the use of the `real()` function. The solution suggested is to use `dble(i)` instead of `real(i)` when calling the `del` function, ensuring the correct data type is passed. This adjustment resolves the accuracy issues, leading to the expected sharp Gaussian distribution around zero. The discussion emphasizes the importance of matching variable types in function calls to avoid computational errors.
phynewb
Hi guys,
I just wrote a simple code for delta function and print it out. Here it is.
Code:
      program main
        implicit none
        integer i
        real*8 del
        real*8,parameter:: ep=1D-2
        real*8,parameter:: pi=3.1415926
        do i=-10,10,1
        write(*,*) i,del(real(i))  ! use function
        enddo
        do i=-10,10,1
        write(*,*) i,(1.0/pi*ep/((real(i))**2+ep**2)) ! no use function
        enddo
        end
      function del(x)
      implicit none
      real*8 del
      real*8 x
      real*8,parameter::ep=1D-2
      del=(1.0/pi*ep/(x**2+ep**2))
      return
      end
It turns out to be quite wrong by using function del. I cannot figure out what's wrong with the function because the expression is the same. Can you tell me how to debug the function? Thanks!
Technology news on Phys.org
phynewb said:
Hi guys,
Code:
      program main
        implicit none
        integer i
        real*8 del
        do i=-10,10,1
        enddo
        do i=-10,10,1
        enddo
        end
      function del(x)
      implicit none
      real*8 del
      real*8 x
      return
      end
What output do your two loops produce?
It shows
-10 31.830990148286446
-9 4.42379935910539249E-054
-8 3.96072696157977595E-306
-7 31.830990148286446
-6 4.42379936653263965E-054
-5 0.0000000000000000
-4 31.830990148286446
-3 4.42379937841623373E-054
-2 0.0000000000000000
-1 31.830990148286446
0 4.42380394766179441E-054
2 4.42380242655975552E-054
3 31.830990148286446
4 4.42380241467614869E-054
5 31.830990148286446
6 4.42380240873434528E-054
8 4.42380240279254245E-054
9 31.830990148286446
10 4.42380239982164045E-054
-10 3.18309583173281331E-005
-9 3.92974701861929112E-005
-8 4.97358443944407051E-005
-7 6.49610718106421125E-005
-6 8.84191714697638248E-005
-5 1.27323451299340604E-004
-4 1.98942445036508832E-004
-3 3.53673738606087140E-004
-2 7.95754859835665312E-004
-1 3.18278073675496917E-003
10 3.18309583173281331E-005The upper part is from the function and the lower part is calculated without function. It shall look like sharp gaussian distribution around 0 instead of random distribution.
I'm pretty sure this line is causing the problem:
Code:
In the call to your del function, you are converting an integer value, i, to a four-byte real (a single-precision floating point value), but the function is expecting an eight-byte real (a double-precision floating point value).
I think this will fix the problem:
Code:
write(*,*) i,del(dble(i))  ! use function
Here's a link to a page with more information - http://www.liv.ac.uk/HPC/HTMLF90Course/HTMLF90CourseNotesnode114.html .
Code:
Code:
Thanks Mark44. It really works! I am always troubled by this accuracy stuff...
Thank you a lot :p
It's more about the size, in bytes, of the variables you're using. For floating point variables, the choices are real*4 (single precision - 4 bytes) and real*8 (double precision - 8 bytes). real() converts whatever to a 4-byte floating point value and dble() converts whatever to an 8-byte floating point value.
Make sure that what you pass to a function is what it is expecting - otherwise you'll have problems.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
