Which disks are in equilibrium?
  • Thread starter Thread starter taliaroma
    Equilibrium
The discussion focuses on the equilibrium of rotating disks subjected to various forces, specifically analyzing which disks are in equilibrium based on torque calculations. Disks labeled a and c are determined to be in equilibrium, while disks b and d are not. The net torque equation, τ_net = 0, is crucial for understanding the conditions for equilibrium, particularly how forces acting at different points on the disks contribute to the overall torque. The conversation emphasizes the importance of considering moments about different points to simplify torque analysis.
  • Understanding of torque and its calculation (τ = r × F)
  • Familiarity with the concept of equilibrium in physics
  • Knowledge of forces acting on rigid bodies
  • Basic principles of rotational motion
  • Study the principles of rotational dynamics in detail
  • Learn about calculating net torque for various force configurations
  • Explore the concept of moments about different points in rigid body mechanics
  • Investigate real-world applications of equilibrium in mechanical systems
Students of physics, mechanical engineers, and anyone interested in understanding the dynamics of rotating systems and the conditions for equilibrium.
taliaroma
Figure 12-16 shows four overhead views of rotating uniform disks that are sliding across a frictionless floor. Three forces, of magnitude F, 2F, or 3F, act on each disk, either at the rim, at the center, or halfway between rim and center. The force vectors rotate along with the disks, and, in the “snapshots” of Fig. 12-16, point left or right. Which disks are in equilibrium?
2. [tex]\tau[/tex][tex]_{}net[/tex] = 0
[tex]\tau[/tex] = r(perpendicular)F
3. So I'm pretty sure that I understand why b and d are not in equilibrium, and I'm pretty sure that I understand why a is in equilibrium. I don't know how to figure out why c is in equilibrium, though. I can figure out that net force is 0, but I don't know why net torque is 0. Using the 1st and 2nd equations listed, I got -
[tex]\tau[/tex][tex]_{}net[/tex] = 0(2F) + R(F) + R(F) = 2RF
where R is the radius. For c to be in equilibrium, the result of this equation has to be 0. How should I do this?
welcome to pf!
hi taliaroma! welcome to pf! :smile:
(have a tau: τ :wink:)
taliaroma said:
… So I'm pretty sure that I understand why b and d are not in equilibrium, and I'm pretty sure that I understand why a is in equilibrium. I don't know how to figure out why c is in equilibrium, though. I can figure out that net force is 0, but I don't know why net torque is 0. Using the 1st and 2nd equations listed, I got -
where R is the radius. For c to be in equilibrium, the result of this equation has to be 0. How should I do this?[/b]
Your second equation should be τ = r x F
if you take moments about the centre of the disc, then r is in opposite directions for the two forces, so the two r x Fs have opposite signs :wink:
however, I do it by just looking at it and saying oh that's clockwise, that's anti-clockwise! :biggrin:
(btw, note that you can take moments about any point, and it still comes out zero … so you can take a point which has all the forces on the same side!)
(and of course you're right about a b and d :smile:)
Thank you!
  • · Replies 31 ·
  • · Replies 25 ·
