How to Find Coefficient of Friction on Sandpaper Using Applied Force and Mass?
The discussion revolves around a physics lab project focused on determining the coefficient of friction for a block of wood moving on sandpaper. The original poster describes measuring the applied force and mass but struggles with calculating the friction force using the provided data and a graphing method.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants explore the relationship between applied force, friction force, and normal force, questioning how to derive the friction force from the known applied force and mass. Some suggest plotting points on a graph to visualize the relationship.
Some participants have offered guidance on maintaining a constant speed to ensure that the applied force equals the friction force, while others express confusion about how to proceed without directly calculating the coefficient of friction. The discussion reflects a mix of interpretations and approaches to the problem.
The original poster mentions that the experiment must not rely solely on mathematical calculations but rather on graphical representation, which adds a layer of complexity to the problem-solving process.
Havenater23
I have a lab project in physics and I'm having a bit of trouble. We measured the Applied force of a moving block of wood using a spring scale. The first trials were don't with just the table , knowing the mass and applied force I was able to find the friction force; simply it was the same as F app. My problem now is that we did other trials on sandpaper, and I have the Applied force and mass and I don't know how to find the mass. We are suppose to find the Co efficent of friction, but not through math ; we have to use a graph where : y = mx aka Ff=U*Fn
Which isn't too bad, I just can't figure out how to get Force friction with only the mass and applied force when it is using the sand paper.
Mass = 0.27952 kg Force applied = 2.0N
Fn = Fg
mg= 0.27952(9.8)= 2.739296 N
Help please
I am assuming that the block or mass is moving slowly or at constant speed when the force is applied...in the 2nd example, you know the applied force so you then know the kinetic friction force, and since you have calculated the normal force, plot that point on the graph with Ffriction on the y-axis and the normal force on the x axis. Then try another mass, and do the same, moving it slowly; and yet another...your graph should approximate a straight line, the slope of which is____?
Can't find friction, yes I have the Force normal , but no coefficient. Even if I know the applied force I don't know how that helps me find friction example
Fapp-Ffrict = MA
I only know F app and mass
Ffrict = U * Fn
Don't see how you solve unless Fapp in the 2nd problem also equals Ffrict.
Fapp-Ffrict = MA
Ffrict = U * Fn
That's right, and that is why i mentioned that in your experiment, you move the object slowly so it doesn't accelerate (a =0). Then Fapp-Ffrict = 0, or Fapp = ffrict. If you use too much of a force and the object accelerates, now you need a means of determining the acceleration. Instead, move it s-l-o-w-l-y, without accelerating. Per Newton 1, an object at rest or moving in a straight line at constant speed, will remain at rest or moving in a straight line at constant speed, unless the net force acting on it is greater than 0. Keep it at constant speed, and F_net = 0.
Oh true, didn't even think about it. Ha.
Thank you , appreciate it.
