New Reply
Quick Question About Plastic Bottle Delfating!
Share Thread Thread Tools
Nov28-10, 08:05 PM   #1
Hi Guys,
I am new here, but I have a quick question.
I had a somewhat tepid liquid in a plastic soda plastic 2L bottle
When I tightened the cap to close it all was well and normal
After a day a portion of the top of the bottle deflated, as if oxygen was sucked out
Can someone explain this process?
Thank You
QM
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Nov28-10, 08:12 PM   #2
Was the water warmer than room temperature?
If yes, the temperature of the bottle and the water became equal after you closed the cap. The air volume contracted as its temperature went down. It couldn't get air from outside because the cap was closed.
http://en.wikipedia.org/wiki/Thermal_expansion
Nov28-10, 08:23 PM   #3
Quote by omoplata View Post
yes, we have been having snowfall lately, it's cold right now
Nov28-10, 10:01 PM   #4
Here is a clearer and more correct explanation.
Let's assume when you closed the cap, the bottle, the air inside it, and the soda were at the same temperature. When you closed the cap, matter (air) couldn't move in or out of the bottle, so you made it a Closed System. There was Heat Conduction between the liquid and air mixture and the outside air through the bottle. So the soda and air mixture which was at a higher temperature than the room transferred heat out to the air in the room until it was at the same temperature as the room. But the volume of a certain substance depends on it's temperature: Thermal Expansion. So they reduced in volume. But air and water (~soda) have different Volumetric Thermal Expansion Coefficients. So air contracted more as the temperature reduced. That's why the soda volume seemed to be the same but the air volume appeared to be less.
You can look up these terms in your science textbooks too.
New Reply
Thread Tools
Similar Threads for: Quick Question About Plastic Bottle Delfating!
Thread Forum Replies
I need a mould to resize/reduce a plastic bottle's neck? General Engineering 5
Question about liquid expulsion from a spray bottle General Physics 5
A question about cooking oil bottle caps General Discussion 3
Plastic Water Bottle Use Medical Sciences 3
2-liter bottle harmonics question General Physics 0
