Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Special & General Relativity
Reply
image Einstein's Thought Experiment Share It Thread Tools Search this Thread image
Old Sep1-04, 12:02 PM                  #1
Gfoxboy
Gfoxboy is Offline:
I just recently saw a video in Physics class about Einstein's thought experiment that led to his discovery of Special Relativity. I was just curious how he knew at that time that light always moves at c even when the observer of the light is moving. I know that is the most important part of SR and I'm sure it's true, I was just curious if someone had discovered that previous to Einstein's thought experiment with the clock and the tram.
Old Sep1-04, 12:32 PM                  #2
Alkatran
Alkatran's Avatar
Alkatran is Offline:
Recognitions:
Homework Helper Homework Helper
I believe it was the Michelson-Morley experiment which was the first to notice that they couldn't measure light at any other speed than c.
The lorentz contractions were all discovered before Einstein, he only figured out WHY it was working like that. (We're skewed through time)
Of course, that's a very, very big "only"
Old Sep1-04, 12:41 PM                  #3
Nenad
Nenad is Offline:
this only proved that light does not propagate as a wave, and there is no magical 'ether' in the universe in which light travels through.
The lorents contractions were widely used by Pointclare (a french Mathematician) but they had no idea about the implications of physics. They never had the slightest thought.
What helped einstein prove his theory was simoutinaety, and the fact that two events that happen at the exact same time, can be seen as happening at different times by an observer in another fame of reference.
Old Sep1-04, 12:47 PM                  #4
Alkatran
Alkatran's Avatar
Recognitions:
But light can be seen as a wave in certain circumstances, especially when you're talking about interference.
The fact that light moves at c would be the disproving of the ether.
Old Sep1-04, 12:52 PM                  #5
Nenad
Nenad is Offline:
Light is onlt thought of as a wave in a probability sence, not in a mechanical sence. It is never thought of as an actual wave propagating though ppace.
Old Sep1-04, 01:36 PM                  #6
russ_watters
PF Mentor
russ_watters is Offline:
Of course it is - interference is one example, but there are plenty of others where light does act like a wave: radio communications, microwave ovens, lasers, etc.
Whether light is a wave or a particle depends on whether you need it to be a wave or a particle for certain observations.
If you're talking specifically about the aether, the fact that there is no aether does not mean that light can't still be a wave.
Old Sep1-04, 02:00 PM                  #7
pervect
pervect is Offline:
Recognitions:
Retired Staff Retired Staff
AFAIK, Einstein had two main clues that when combined together led him to the conclusion that light must always travel at 'x'.
These were Maxwell's equations, and the Micehlson-Morley experiment.
Maxwell's equations gave a result of the speed of light of 1/sqrt(uo*E0). It would be possible, of course, for these constants to vary with velocity, to make the speed of light vary with velocity. But the Michelson-Morley experiment showed that the speed of light didn't vary with the changes in velocity of the earth orbiting the sun.
Einstein thought a lot about various alternatives, and decided that the simplest one which matched experimental results was that the speed of light was constant to all observers.
Old Sep1-04, 02:06 PM                  #8
Alkatran
Alkatran's Avatar
Recognitions:
Why are we arguing over what we agree on?
Old Sep1-04, 03:05 PM                  #9
Gfoxboy
Gfoxboy is Offline:
Thanks guys.
Old Sep1-04, 05:31 PM                  #10
davidhart890
davidhart890 is Offline:
Hi, I just finished reading the special Einstein issue of Discover (of which Dr Michio Kaku article 'Einstein [in a nutshell]' led me (ultimately) to this forum....
I thought I understood and now I'm sure I don't.
If I sat on a particle of light leaving point x at time y and 'you' did exactly the same (in a parallel direction) would I not view 'you' as stationary? the reading suggests different - any other answer other than yes is going to be really hard to swallow.
If you can help me understand this, I would be most grateful
regards,
David Hart
Old Sep1-04, 07:05 PM                  #11
pervect
pervect is Offline:
Recognitions:
Well, the very short answer is that you can't sit on a particle of light. The light, being massless, can move at 'c'. You, having mass, can't move that fast. Trying to say you can is like dividing by zero in mathematics - it yields nonsensical results. In fact, if you study the Lorentz transformations, you'll see that moving at 'c' does involve dividing by zero.
Old Sep1-04, 07:30 PM                  #12
JasonRox
JasonRox's Avatar
JasonRox is Offline:
Recognitions:
PF Contributor PF Contributor
He didn't say physically sit on it!
He just indirectly said visualize yourself as a particle of light. If you can visualize yourself sleeping with Britney Spears when that's impossible, why not visualize yourself as a photon hitting Britney Spears.
Note: I don't have a thing for Spears.
Old Sep2-04, 04:44 PM                  #13
pervect
pervect is Offline:
Recognitions:
Well, if you visualize that 2+2=5, you can conclude, quite logically, that you are the King of England. (See the derivation by the famous mathemetician, Charles Dogson, aka Lewis Carroll).
The point here is that one has to be careful about making impossible assumptions - given one false statement, one can logically prove anything. Moving at 'c' as a material body is one of those impossible assumptions that one should avoid.
ps: It doesn't violate any laws of physics to sleep with Britney Spears. Why, if you won a celebrity date with her, then there was a power blackout while you were out on the date, and then you both got stuck in an elevator alone for 12 hours, you might both get tired and go to sleep. I wouldn't think you'd have much luck having sex with her, though.
Old Sep8-04, 06:55 PM       Last edited by robert Ihnot; Sep8-04 at 09:23 PM..            #14
robert Ihnot
robert Ihnot is Offline:
Recognitions:
[quote=pervect]AFAIK Einstein had two main clues that when combined together led him to the conclusion that light must always travel at 'x'.
While Einstein clearly gave credit to Maxwell, there is doubt that Einstein was influenced by the M-M experment, even though he wrote in his 1905 paper, "Together with the unsuccessful attempts to discover any motion of the earth relative to the 'light medium..." This seems to refer to Stellar aberration and Fizeau's experiment on the speed of light in moving water.
I base this on "Understanding Relativity," by Leo Sartori p52, where it is stated that in an interview in 1950, Einstein told Robert Shankland that he became aware of the M-M experiment only after 1905 and Einstein added,
"Otherwise I would have have mentioned it in my paper."
Old Sep8-04, 07:09 PM                  #15
humanino
humanino's Avatar
humanino is Offline:
Recognitions:
could not help
Because I am a very proud and arrogant french guy, I would like to point that Poincare is among the most important mathematicians of the beggining of the century, and was not so far behind Einstein, probably closer than Hilbert for instance
Poincare especially was the first to backup Einstein in France, and maybe also in Europe. Since physicists could not yet undestand Einstein's theory, and it looked to much like philosophy to them, horrible statements have been made. When Einstein was invited to the french Academie, a well-known scientist declared "Who needs the theory of this jewish guy who, thinking he is prosecuted, prides himself with an ununderstanble theory, invented by others anyway"
Old Sep9-04, 02:52 AM                  #16
ШЇSЭЯ
ШЇSЭЯ is Offline:
does light always travel at the same speed no matter where it comes from??
just curious, im new to this i need to read up, a lot
and where can i read that article by michio "Einstien [in a nutshell]"
image image
Reply
Thread Tools
Similar Threads for: Einstein's Thought Experiment
Thread Thread Starter Forum Replies Last Post
thought experiment snoopies622 Special & General Relativity 34 Apr8-08 12:24 PM
Modelling Einstein's Thought Experiments (Trains + Mirrors) DunnyBasher Special & General Relativity 8 Nov21-07 03:56 AM
A thought experiment actionintegral Special & General Relativity 117 Jan11-07 02:29 AM
Thought Experiment complexPHILOSOPHY General Astronomy 10 May23-06 01:51 PM
Thought Experiment leka General Physics 20 Dec9-05 05:26 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
