Does Accelerated Thermohaline Circulation Increase Tropical Water Vapor?
  • Thread starter Thread starter kurious
    Circulation
The discussion revolves around the relationship between accelerated thermohaline circulation (THC) and the increase of water vapor in tropical regions. Participants explore various factors that might influence this relationship, including geological and oceanographic phenomena, while considering the implications of isotope differentiation in ocean waters.
  • Some participants propose that the acceleration of deep cold water flow in the Atlantic could be linked to increased tropical water vapor, potentially influenced by geological factors such as magma heating or hydrothermal vents.
  • Others argue that thermal vents are unlikely to have a significant impact on ocean currents, suggesting that solar energy and the balance of salt and fresh water are the primary controls.
  • There is a discussion about the Milankovitch cycles and their potential inadequacy in explaining energy changes related to THC, with some participants expressing uncertainty about the causes of these changes.
  • One participant raises a question about the expected isotope differentiation between ocean bottom water and surface water, noting that this differentiation does not appear to be as distinct as anticipated.
  • Another participant challenges the assumption that the sinking heavy and salty water takes thousands of years to travel, questioning the evidence for such a timeline and the role of biological activity in the ocean.
  • There are references to the "conveyor-belt" model of ocean circulation, with participants discussing the implications of speeding up this process and its potential effects on isotope ratios in ocean water.
  • Several links to external resources are shared, indicating a search for further information on isotope ratios and ocean circulation dynamics.
Participants express a range of views, with no clear consensus on the mechanisms driving changes in THC or the implications for tropical water vapor. Disagreements exist regarding the significance of thermal vents, the timeline of water movement in the ocean, and the expected isotope differentiation.
Participants acknowledge the complexity of the factors influencing THC and the potential for multiple influences to be at play, highlighting the limitations in current understanding and the need for further exploration of the topic.
kurious
When the flow of deep cold water in the atlantic speeds up what causes
the amount of water vapour in the tropics to increase too.Could
magma in the Earth be heating the sea water or hydrothermal vents - presumably sea currents would have to move to a hot spot or somehow
encourage vents to release more energy.
hmm, i'd say thermal vent won't have a big effect.
Its like trying to boil a swimming pool wit 20 guys holding a blowtorch.
Ocean currents are maily controlled by the sun and the balance of salt and fresh water.
Maijn:
Kurious:
I agree with what you say but is it not the case that even phenomena like the Milankovitch cycles cannot fully account for the energy changes involved in the thermohaline circulation?
Your right on that one.
But without calculating it, you can fairly easilly rule out thermal vents.
Consider the amount of water coming from themal vents, in relation to the watermass it vents into, it's peanuts.
Vulcano's are fairly save to rule out as well.
Being that their activity is very local, and not prolonged (could be rong on the duration).
I think their effect is relatively small compared to the Milankovitch cycles.
The Milankovitch cycles are an influence quite bigger than vulcano's and thermal vents, afteral the Milankovitch cycles are being held responsible for finishing the last ice-age (Berger (1991), and Laskar (1993)).
What does cause the changes i can't say, and i don't know if anyone does.
There are just to many influences to pick one (or a combination) to say, "yeah, that's causing it!".
Maybe Andre has some more info on this, afteral its related to his hobby: ice-ages.
Sorry missed this one. I have not really additional information on the variation in the THC. But something has been puzzling me. We consider de engine motoring the THC to be Atlantic surface water that cools due to prolongued evaporation. Hence it gets saltier but also enriched in heavy 18O oxygen because the lighter 16O oxygen evaporates more easily. Now the sinking heavy and salty water starts a journey of several thousand years close to the ocean bottom, whilst the surface water is refreshed mainly by light fresh precipitation water -hence heavy oxygen depleted - Consequently, after hundreds and thousands of years you would expect a distinct isotope differentiation between ocean bottom water and surface water. But this is not true. Have to find the link back but most of the ocean water is pretty much within less than a mil difference in isotope ratios.
My idea is that this is odd. Somebody agree, disagree?
"Now the sinking heavy and salty water starts a journey of several thousand years close to the ocean bottom,"
How do we know this? We have seen how the tanker spill of yellow rubber ducks migrated, but what about movements deep under the ocean?
"Consequently, after hundreds and thousands of years you would expect a distinct isotope differentiation between ocean bottom water and surface water."
Would you? The bottom of the ocean is not a desert. There is a lot of biological activity going on. And is saltwater a static thing? Does the salt affect isotopic behavior?
Andre you're now talking about the "conveyor-belt" right?
Does it take several thousands of years to travel that distance?
Thats a bit hard to believe.
The route it would take surely has some more elevated parts in it.
Thus the water would release some Co2 because of lowered pressure.
This appart from what the effects of life would be on the Co2 level.
Could you explain a bit more what you meant?
Right, well looking at this http://www.firstscience.com/site/images/articles/conveyor.jpg it appears that speeding up the conveyor belt would indeed bring more warm surface water to the Atlantic.
http://www.clas.ufl.edu/users/emartin/GLY3074S04/lectures/deepcirc.htm I wasn't that far off. :-p
Again, my area of interest is the d18O and dD isotope ratios thoughtout the whole ocean. I used to have an excellent link showing the ratio / salinity properties throughout the Atlantic but can't find it back right now. Files too thick and no luck with google. Anyway it showed that the variation in isotopes is very small.
If the downdraft in the North Atlantic pushes heavy isotope enriched water down, then why isn't oceanic bottom water enriched in heavy isotopes?
The fact that it isn't, may be a very important piece of evidence for a few ideas.
http://www.geo.cornell.edu/geology/classes/Geo656/00notes/656_00Lecture36.pdf
Thanx, Nilequeen, excellent study material.
http://www.windows.ucar.edu/cgi-bin/tour.cgi/earth/Water/temp.html
This one?
  • · Replies 20 ·
9K
9K
13K
  • · Replies 21 ·
9K
  • · Replies 39 ·
17K
