sophiecentaur
Homework Helper
- 30,501
- 7,506
kwaekins said:I have considered using crystals as a primary source for energy generation. Consider a turning fork. It is not large, nor loud, yet it can shatter glass. I am sure with the primary tone and it's harmonics, some acustic engineering and channeling it's point of critical mass or it's most effective convergent frequency; energy can be gleaned. The problem is not creating energy, the problem is increasing the yield. Once you increase the yeild of one, the same approach can be use to increase all forms of energu.
A tuning fork is not loud because it doesn't couple its vibrational energy out into the air efficiently. (You need a sounding board to hear it). But it has (relatively) a lot of energy in it - you give it a hard bash to get it going. That energy is more than enough to smash a glass, which makes sense because, if you gave the glass the sort of bash you give a tuning fork, you could break it and cut out the middle man.
You can alter the 'yield', as you put it, but not to get more out than you put in.
But which are you discussing, noise production or noise reception? What are you actually trying to do with this noise?
