PF Photography: Tips, Tricks, & Photo Sharing
This thread focuses on various aspects of photography, including tips for taking better photos, sharing personal images, and discussing techniques for image manipulation. Participants share their experiences, seek advice, and showcase their work, covering both technical and creative elements of photography.
  • Homework-related
  • One participant expresses a desire for pointers in photography, noting their inexperience.
  • Several participants share links to their photos, discussing the qualities of their images, such as focus and background.
  • There are suggestions for image hosting services and guidelines for photo sizes to avoid clutter.
  • Image manipulation software, specifically GIMP, is recommended for enhancing photos.
  • One participant notes that their dog photo appears dull and seeks advice on improving its appearance.
  • Another participant points out a blue tint in a dog photo and suggests adjusting the color balance to warm it up.
  • Participants discuss the challenges of photographing wildlife, with some sharing their experiences and techniques.
  • There are discussions about the use of high f-stop settings to achieve specific effects in photographs.
  • Some participants express admiration for each other's work, highlighting specific aspects like detail and composition.
  • Advice is given on joining photography groups for constructive criticism to improve skills.
Participants generally share tips and experiences, but there are varying opinions on techniques and preferences for photo editing and styles. The discussion includes both agreement on the value of certain tools and differing views on how to achieve desired effects in photography.
Some participants mention specific technical aspects, such as focal lengths and f-stop settings, but there is no consensus on the best practices for all scenarios. The discussion also reflects a range of skill levels and personal preferences in photography.
Individuals interested in photography, from beginners seeking advice to more experienced photographers looking for community feedback and tips on improving their work.
  • #1,021
turbo-1 said:
Can I justify the extra money for the L? I don't know.
That's when wife sharing hobby comes in handy :biggrin:
  • #1,022
You are WAY too crafty, Borek! I gave my wife my old Olympus C-3040, but she only uses it for kids' birthday parties, etc. We have been greatly expanding the flower gardens, so maybe some macro flower/insect shots will tip the scales.
  • #1,023
You share your wife? Zounds! :)
  • #1,024
That's what I thought too :eek: :smile: !
  • #1,025
:smile:
  • #1,026
Spring is here :smile:
No, it is not Junior with his GF, this is some random pair I have seen today at Warsaw Old City.
  • #1,027
Sorry if this isn't the right place, but I guess the PF photographers will see it here:
I want to make digital images from about 1000 sheets of A3 size paper (= USA 11x17). This is a "one off" task, so I don't want to buy an expensive A3 size scanner. The paper originals are clean high contrast black-and-white images (actually music scores, hand-written in ink). They are separate single sheets, not bound in a book.
I have a digital camera that is good enough to handlle this. The question is, is it possible to buy (rather than make) a fairly cheap camera stand for this? The easiest way would probably be to have the paper flat on a table and the camera pointing vertically down, so a normal camera tripod won't work. I'm thinking of something like an L shaped arm that would clamp onto the edge of a table, with a mount for the camera pointing downwards. Do such things exist ready made?
My camera has a 10:1 optical (not digital) zoom, so the stand wouldn't necessarily need to be height adjustable.
I'm not bothered about color balance etc so long as the images are "readable", so lighting is not an issue.
  • #1,028
Can't you put the sheets on the table tilted 45 deg? Resting on a stool or something? Then simple tripod will work. To keep sheets in place you can glue slat of wood to the table, water soluble glues should be later not difficult to remove.
Alternatively you can put the tripod horizontally ON the table - just use some heavy books on the legs.
In my experience makeshift solutions for such tasks are the best :smile:
  • #1,029
You could clamp the camera onto the edge of a coffee table and photograph the pages with the sheets lying on the floor. If you have a relatively bright, sunny room to do this in, it could go pretty quickly. Once you have the camera set to match the aspect of the first sheet, make some "Ls" out of tape to mark the corners of that sheet so you don't have to align every sheet one-by-one.
  • #1,030
Even better - instead of tape use something sticking out (like two books for a corner, just on one side), so that you don't have to align each sheet to the marks, just push it till it stops touching the edge.
  • #1,031
Good idea. That would work very well, and would eliminate the need for visual alignment with the tapes. 1000 sheets could go very quickly that way.
  • #1,032
In 1998 I moved from bpp.vr.pl to bpp.com.pl. Problem was, I had several thousands copies of booklet to put into CD boxes with one of my programs, and the booklet was printed with the old domain name. What I did was I ordered a self inking rubber stamp "we inform you our new website is at bpp.com.pl" (in Polish). Then I took a piece of plywood, glued two slats to it - so putting the booklet always on the same position was not a problem, and the stamp was pushed against the same slats - which meant all the booklets were stamped in exactly the same position in exactly the same corner. Few hours and all were modified.
I love such witty solutions :smile:
  • #1,033
That nudged my brain in the right direction. I've got an ironing board where the metal wires that make the stand for the iron are the right spacing to locate the camera lens down, without needing to actually clamp it.
Next task: recharging all the available batteries. I'm not sure how many shots the camera will take on one set, but I'm pretty sure the answer is "less than 1000".
  • #1,034
And legs don't come into the sight?
Note that if the camera just lies, you will probably move it slightly with each picture taken (just by pressing the button). That in turn means each sheet will have slightly different position on the picture, which is quite inconvenient and may mean a lot of work later (work that can't be easily automated). Go for something more rigid. Perhaps even just tying camera with a strong cord will work.
  • #1,035
The paper will be on a low table that overlaps the bottom end of the X-shaped legs.
It's easy to locate the camera in a fixed position pressed against the wire frame. An elastic band round the camera and the frame might be useful though.
I'm not too bothered about accurate matching of the positions of each image. The real task is typesetting the music with computer software (which will probably take a few years, given the quantiity and complexity of it). The images aren't going to be published as a facsimile of the original, they are just for displaying on a monitor while doing the transcribing. That will be much less risky than continual handling of the originals (no coffee spills, etc!).
Even if the originals were photocopied to avoid the coffee, physically searching through hundreds of large sheets of paper to find two or three sheets to compare some details side by side, etc, would be much more hassle than working on a computer screen.
Sample page, done to check that the music notation software could handle the job, attached...
  • #1,036
If the simplified approach works for you - that's great. I just did similar things in the past and I know from experience where the possible problems are, if they are not important for you - don't bother.
  • #1,037
I got inspired by all that reproduction work and started to digitize my pix of before the digital era. I used a little wooden box and the 45 degrees angle. Allows to stack the pix quickly into the right position. Wow decades of memories.
Oldest daughter, 15 years ago:
  • #1,038
There is software available (Neuratron PhotoScore) which will take scans or photos of music and convert it to computer music notation, typically requiring a bit of manual fix-up, but much less work than starting from scratch. I've successfully used the free version that comes with Sibelius, both with photos and with PDFs of old music, but not for anything as ambitious as your example.
You would definitely need a higher resolution than your sample for such software to be able to read the score very successfully.
  • #1,039
The new multi-volume book set "Modernist Cuisine" has some *amazing* photos. There's a lot of 'cutaway' shots- a grill cut in half to show what goes on inside, for example- but lots of amazing photos throughout.
http://modernistcuisine.com/
http://modernistcuisine.com/docs/ModernistCuisine_About%20the%20book_spreads.pdf
  • #1,040
http://www.nytimes.com/2011/03/09/dining/09modernist.html" . If only it weren't so expensive... and didn't make me so hungry! What eye candy!
  • #1,041
I have Sibelius and PhotoScore.
I don't think there is much chance of Photoscore doing anythng useful with this sort of handwriting. Actually this clip is pretty neat compared with some of it!
  • #1,042
As I mentioned, I got some good news recently- my NIH proposal was approved for funding- so I decided to spend some of my (non-grant) startup money and get two 'big boy' lenses. They just came this morning, and so rather than do what I'm supposed to be doing, I wandered around campus playing with the new toys.
The first lens is a 15mm f/3.5 rectilinear lens- an ultrawide angle lens. This lens is really good for indoor shots as it distorts the volume of spaces- here's my palatial-sized office:
[PLAIN]http://img848.imageshack.us/img848/8488/dsc5698.jpg
And an indoor commons area:
[PLAIN]http://img600.imageshack.us/img600/8067/dsc5699v.jpg
I also took a shot inside of an elevator- it's not very good, but it shows the distortion effect fairly well. The elevator can hold at most 5 people, it's like 3' x 3'.
[PLAIN]http://img600.imageshack.us/img600/1513/dsc5702j.jpg
This image shows some of the challenges of this lens- the blue blobs at the bottom are flare from the overheard lights, and the vertical lines aren't quite vertical- the huge angle of view makes alignment super critical- both pitch and yaw angles, but also centering. But, I got this lens both because of the huge field of view/depth distorition and that it is a *rectilinear* lens- there is no distortion (in the lens aberration sense).
The other lens is a little intimidating, frankly- it's a 400mm f/2.8. I found an older manual focus version, so I could afford the freaking thing- the front element is about 6" in diameter, and the lens is *really* heavy. I also picked up a 2x teleconverter for it to also use it as a 800mm f/5.6- why not? It close-focuses to 10', so it's practically a macro :)
It's an outdoor lens, and since it's raining today I won't be able to use it. So, I have time to check that my tripod can handle the weight...
In other news, I've been carefully stripping down the crackberry's LCD display- there are some really weird lighting elements that I've been trying to understand, and when I do, I'll post those pics.
  • #1,043
Finally- we have sun outside. I took my 'new' lenses out for a test drive- here's the 15mm, full frame and then 100% crop:
[PLAIN]http://img856.imageshack.us/img856/1071/dsc57451.jpg
[PLAIN]http://img196.imageshack.us/img196/1316/dsc5745.jpg
And here's the 400mm, full frame and 100% crop:
[PLAIN]http://img718.imageshack.us/img718/9855/dsc57461.jpg
[PLAIN]http://img856.imageshack.us/img856/1184/dsc5746.jpg
The nikon-sony adapter has some slight vignetting at long focal lengths (which I knew about, it's the cost of doing business...), but even so, the image is quite impressive- the thermal lensing is clearly visible.
Adding the 2x teleconverter increases the vignetting considerably, but even so:
[PLAIN]http://img251.imageshack.us/img251/9561/dsc57471.jpg
[PLAIN]http://img690.imageshack.us/img690/4407/dsc5747u.jpg
"lens shake" is extreme with this lens- except it's not the lens exactly- it's the camera flopping up and down. I used the 10-second timer delay to get (reasonably) crisp images. If the weather hold up, I'll try taking some images of the moon tonight.
  • #1,044
Got a really nice shot of the moon last night:
[PLAIN]http://img233.imageshack.us/img233/4696/dsc58161.jpg
[PLAIN]http://img8.imageshack.us/img8/523/dsc58162.jpg
The settings were 800mm f/5.6, ISO100, 1/125s exposure.
The star photos were not acceptable. Seeing was mediocre at best, and even though I got excellent separation of Alcor and Mizar and may even have resolved Mizar as a quadruple, it's not clear due to vibration issues. At extreme blow-up, there is some purple fringing (spherochromatism), but I'm reserving judgment until my technique is 'up to spec'- getting tack-sharp images with this lens is not easy, even when the view is spectacular through the viewer.
After working with the lens for a while, the main residual problem seems to be due to 'mirror flap'- I'll try locking the mirror up first, waiting a few seconds, and then use a remote shutter to trigger- I ordered the remote last night. On the plus side, the lens has almost no flare- here's the sun, about 30 minutes prior to sunset:
[PLAIN]http://img684.imageshack.us/img684/3091/dsc5806g.jpg
The settings were 800mm f/22, ISO 100, 1/2500s exposure, HDR enabled and set to maximum.
I ordered a couple large sheets of polaroid- it would be nice if I could see sunspots.
  • #1,045
Have you tried higher ISO and shorter times?
  • #1,046
I usually stick to ISO 200 and slower because the Sony Exmor is very susceptible to amplifier noise. The noise is noticeable at ISO 400, and annoying at ISO 1600. That's one of the reasons I prefer fast lenses- it's easier to throw photons away than it is to scavenge every last one.
That said, I could take an image at ISO 6400 and after re-scaling it to 650x480 you would never know how much noise there is; I can work in the ISO 400-1600 range and smooth the image later to get acceptable results at 100% crops.
Now that the weather is nicer, I can spend some time outside taking nighttime shots with the goal of improving (reducing) camera shake. I'm hopeful that using a remote shutter will fix the majority of the problem.
  • #1,047
Yes the noise is indeed an issue, but using high ISO is just another trade off, if you like to shoot tele or macro handheld in a dynamic environment of moving subjects and you like low ISO's for the lack of noise, you run out of options even in fair light conditions. Then it would nice if say F16 and 1/1000 sec could be done, but you might need ISO3200 to accommodate that.
In that case, one would currently like the Nikon D3S best, closely followed by the quicker Canon 1D mkIV
But you could also buy a decent car for that money,
  • #1,048
It is either the shake or atmosphere, we have discussed it earlier. I was surprised several years ago by the sharpness of Moon images taken at very short times.
  • #1,049
Too true.
  • #1,050
Based on the star images, I suspect my main culprit is mirror flap- the stars consistently got distorted into short lines, even for 1/10 second shutter speed- and the lines were always the same length and orientation (of course, I didn't change the orientation of the camera to check this last night).
  • · Replies 40 ·
