Is radial acceleration and centripetal acceleration the same thing?
The discussion revolves around the concepts of radial acceleration and centripetal acceleration, particularly in the context of uniform circular motion. Participants explore the definitions, relationships, and distinctions between these types of acceleration, as well as the role of tangential acceleration in both uniform and non-uniform circular motion.
  • Some participants propose that radial acceleration and centripetal acceleration are synonymous in the context of uniform circular motion.
  • Others clarify that while the terms are often used interchangeably, there may be nuances in their definitions depending on context.
  • A participant questions the difference between two formulas for tangential speed provided by a lecturer, suggesting a lack of clarity in their connection to frequency.
  • It is noted that in uniform circular motion, acceleration has only a radial component, while in non-uniform circular motion, tangential acceleration also exists.
  • Some participants discuss the relationship between centripetal acceleration and radial acceleration, with one suggesting that centripetal acceleration is directed opposite to the radial vector.
  • There is a mention that any acceleration, including centripetal acceleration, requires a net force, and tangential acceleration specifically occurs when there is a tangential component to that force.
Participants generally agree on the definitions of radial and centripetal acceleration as they relate to uniform circular motion, but there are differing views on the implications and nuances of these terms. The discussion remains unresolved regarding the precise relationship between centripetal and radial acceleration, as well as the conditions under which tangential acceleration occurs.
Some statements made by participants depend on specific definitions and assumptions about motion, particularly regarding uniform versus non-uniform circular motion. The discussion does not resolve the mathematical relationships or the implications of the formulas mentioned.
Femme_physics
In uniform circular motion,
Is radial acceleration and centripetal acceleration the same thing? Just a vector pointing towards the center? i.e. a synonym?
Yes. Typically those terms are synonymous in that context.
Ah, great :) Thanks. Um, while I got your attention
Our lecturer gave us 2 formulas (presumably both to tangential speed):
http://img198.imageshack.us/img198/5021/thedifferencebetween.jpg I don't understand the difference between those formulas. Our lecturer wrote us that in "industrial usage" f = n (where f is 1/T). But I don't see the connection.
Those formulas are essentially the same. For whatever reason, the second formula uses n for the frequency. (Think n = number of cycles per second.)
I see it now :) Thanks Doc.
I understand that V is tangential speed, and that acceleration is centripetal acceleration. But is there also a beast known as tangential acceleration? I thought the only two players here are the two mentioned first.
In general a speed V has a tangential and a radial component.
Same thing for acceleration - it has a tangential and a radial component.
The case of circular movement is special in that the acceleration only has a radial (or centripetal) component.
Furthermore, the speed only has a tangential component.
In the case of non-uniform circular motion there will be tangential acceleration as well as radial acceleration. Uniform circular motion means constant speed, so the tangential acceleration would be zero.
tiny-tim said:
(oh, and centripetal acceleration is minus radial acceleration)
Did you mean to say that the centripetal acceleration direction is opposite to the radial vector?
The accelerations are the same:
[tex]\vec{F_c}/m = -\omega^2r \hat{r} = \ddot{\vec{r}}[/tex]
AM
[tex]F_c/m = -\omega^2 r\hat r = \ddot{\vec{r}}[/tex]
AM
Hi Andrew! :smile:
(not enough {} :wink:)
Yes … eg a centripetal acceleration of 5 m/s2 would be a radial acceleration of -5 m/s2 :wink:
I can see clearly now :) Tangential acceleration only occurs when there's a force applied. Thanks tiny-tim, ILS, Doc, Andrew. Being in mechanics class for the past 4 hours also helped!
Any acceleration--including centripetal--requires a net force. Better to rephrase your statement like this: Tangential acceleration only occurs when the net force has a tangential component.
  • · Replies 21 ·
9K
  • · Replies 16 ·
  • · Replies 37 ·
