| New Reply |
Second moments of area Izz and Ixx |
Share Thread | Thread Tools |
| Jun3-11, 05:23 PM | #1 |
1. The problem statement, all variables and given/known data
A vertical column has the horizontal cross sectional area shown in the attached image. The column carries a vertical compressive point load of 30kN applied at d. calculate the following: a) The second central moments of area IZZ and Ixx b) The maximum values of compressive and tensile stresses c) The position on the cross section where the stress is zero 2. Relevant equations 3. The attempt at a solution I have done part a and got: Ixx = 5.48E+5 IZZ = 1.75E+5 for part b i know the formulas for compressive stress and tensile stress. However they require a bending moment number. How do i calculate this? Tensile = Mzc/Ixx Compressive M(zmax-Zc)Ixx Compressive stress due to point load F/A C) Im not sure how to complete this part Any help would be much appreciated |
| Jun3-11, 07:03 PM | #2 |
Recognitions:
Hint: Neutral Axis
| Jun4-11, 05:03 AM | #3 |
zc = 46.75mm and xc = 22.5mm. Is the bending moment calculated from these?
I have been trying to work out the bending moment for a while now and cant seem to get the answer of 3.97E+5 Nmm |
| Jun4-11, 10:53 AM | #4 |
Recognitions:
Remember, take your moments about the neutral axis.
| Jun4-11, 07:07 PM | #5 |
I am also stuck on a very similar question and i don't know how to calculate the moment. I assume the neutral axis was at the centroid of the shape which I would work out to be 46.3 mm. I have been looking for days for help on this and I'm getting nowhere
| Jun4-11, 07:08 PM | #6 |
Do you need to draw a bending moments diagram??
| Jun4-11, 08:12 PM | #7 |
Bending moment is M= mass x distance between the (load point D - Zc).
| Jun4-11, 08:26 PM | #8 |
The position of zero stress (Zo) is basically,
Zo=total tensile stress x total length of z-direction( I beam)/total tensile stress + total compressive stress. |
| New Reply |
| Thread Tools | |
Similar Threads for: Second moments of area Izz and Ixx
| Thread | Forum | Replies | ||
| Confusion of area moments of inertia with a Stability of Floating bodies question | Mechanical Engineering | 1 | ||
| Beam deflection (area moments) | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Statistical moments and multipole moments | General Math | 0 | ||
| 1st & 2nd moments of area | General Engineering | 0 | ||
| nuclear magnetic moments and electric quadrupole moments | General Physics | 0 | ||
