| New Reply |
First law of thermodynamics applied to a submarine |
Share Thread | Thread Tools |
| Jun13-11, 12:49 PM | #1 |
Hallo,
I hope someone can help me with the following question: A submarine conatins 1000m^3 of air and has a temperature and pressure of 15°C and 0.1MPa respectively. Due to the cold seawater a heatflow of 60 MJ/h occurs. The machines on the otherhand adds disspiative Work of 21 kW to the system. The specific heat capacity of air is c(p,air) = 1.005 kJ/Kg*K. what average Temperature will the air have after one hour of diving? V=constant=1000m^3 P=constant? T1=288.15K => T2=? Firstly i found the density and mass of the gas: R(air)= 286.9 J/K*Kg => density= P/T*R(air)=1.209 Kg/m^3 => m= V*density= 1209.63 Kg Secondly i found the total Energy: Q/h=Wdiss - Q/h = 15600 KJ/h Then i used the first law: dW=0 because V=constant dQ=dU Q=mcp(T2-T1)= m(R(air)-cv)*(T2-T1)= 288.19K .... which can't possibly be right because that is essentially my T1 temerature. So what did I do wrong? Thanks for your help in advance ^^. |
| Jun13-11, 02:14 PM | #2 |
R(air) = Cp - Cv
=> Cp=R(air)+Cv so, Q=m(R(air)+Cv)(T2-T1) |
| Jun13-11, 08:55 PM | #3 |
The specific heat at constant pressure is given in the problem.
If you assume a constant-volume process, you can calculate cv=cp-R. Either way the temperature increase is of the order of 10K (around 14K if you consider constant volume). Review your last step. |
| New Reply |
| Tags |
| thermodynamics |
| Thread Tools | |
Similar Threads for: First law of thermodynamics applied to a submarine
| Thread | Forum | Replies | ||
| Submarine | Introductory Physics Homework | 7 | ||
| Applied heat and thermodynamics. | Classical Physics | 3 | ||
| Good book for applied thermodynamics | Mechanical Engineering | 2 | ||
| Submarine Fires Torpedo, Submarine's Recoil? | Introductory Physics Homework | 16 | ||
| [SOLVED] explain the first law of thermodynamics as applied to a diagram for me? | Introductory Physics Homework | 0 | ||
