Can Energy-to-Mass Converters Achieve Near-Perfect Efficiency in the Future?
  • Context: Graduate
  • Thread starter Thread starter guss
The discussion revolves around the theoretical potential for energy-to-mass and mass-to-energy converters to achieve high efficiencies, specifically exploring the implications of such technology on energy conservation and the conversion processes involved. Participants examine the feasibility of these converters in future applications, touching on concepts from physics, including relativity and energy transfer mechanisms.
  • Some participants propose that energy-to-mass converters could theoretically reach efficiencies of 99.999%, questioning the limitations of current technology.
  • Others argue that the increase in matter from restoring substances to their original potential is only relativistic and does not imply a significant efficiency advantage over traditional systems like water wheels.
  • A participant suggests that energy losses, primarily due to heat, would ultimately reduce the amount of matter produced over time, regardless of the efficiency of the conversion devices.
  • There is a discussion about the challenges of converting energy (bosons) into rest mass (fermions), with some expressing skepticism about the feasibility of such conversions.
  • One participant speculates that future advancements could lead to devices capable of high efficiency in matter creation and destruction, questioning the existence of a natural limit to these conversions.
  • Concerns are raised about energy loss when transferring energy against gravity, with participants discussing various mechanical methods of energy transfer and their potential inefficiencies.
  • Questions are posed about the mechanics of the proposed systems, particularly regarding how matter is converted back to energy and the overall energy balance in the system.
Participants express a range of views, with no consensus on the feasibility or efficiency of energy-to-mass converters. Some agree on the theoretical aspects but disagree on practical implications and limitations.
Participants acknowledge the complexity of energy and matter conversion processes, including the dependence on relativistic effects and the challenges of achieving high efficiencies in practical applications. There are unresolved questions regarding the mechanics of energy transfer and the assumptions underlying the proposed systems.
guss
This is kind of similar to those troll science threads, but what am I missing here?
What if those energy-to-mass and mass-to-energy converters can reach 99.999% efficiency when converting to electricity to mass and vice versa in the future? Those converters are theoretically possible, aren't they?
Note, this is obviously an oversimplified diagram. The wires are simply meant to represent the transfer of energy from one area to another, in this case, from an area of lower gravitational potential to an area of higher gravitational potential.
The increased matter from restoring the substance to it's original potential is only relativistic. There is nothing new here and no acute efficiency over something such as a water wheel.
I know it's probably nothing new, I just want to understand why it won't work. And I don't quite understand your answer. The matter never really increases, either, it just goes through a cycle of energy and matter. I guess you could say the matter increases every time the energy is converted the matter at the top, but I'm not sure if that's what you're saying.
It will work but energy will be lost to heat.
You can increase the relativistic mass of an object by "carrying" it to a higher potential, therefor converting energy to mass though it is only relativistic and reference frame dependent.
The equation E = mc^2 is a relativistic equation.
It's easier to convert a small mass into a large amount of energy than it is to convert a lot of energy into a small mass, given the technology currently available. Haven't you wondered why we are not using transporters to get around (a la Star Trek)?
Nevermind how easy it is...
I don't think you can actually convert energy (bossons) into rest mass (fermions).
Due to losses the amount of energy generated would be less and less each time. Over time the amount of matter produced at the top is less and less until you have none. You would be turning the matter into energy, just like any fuel sorce does. This is all assuming you even have a device that can efficiently create and destroy matter.
It is obviously very difficult for us to create and destroy matter right now. But let's say in 500 years we have something that can get extremely high efficiency. I don't see any reason why this would be impossible. I don't see any proof that there is a natural "cap" to the efficiency of these conversions.
The wheel could theoretically make up for the energy lost on a machine with something even as low as 80% efficiency. Let's say the top part (energy-to-matter) was 20 miles above the ground part (matter-to-energy). They could be connected by superconducting wire. There could, again theoretically, be hundreds of these water-wheels more than making up for the 80% efficiency.
I like your diagram. :smile:
I think the question is: what happens if your make a current go up against gravity.
Energy conservation would imply that the electrical energy is lost when going up against gravity (that is, it is converted to potential energy).
Energy conservation would imply that electrical energy is lost when going up against gravity (that is, it is converted to potential energy).
Haha, thanks.
I had thought of that, but couldn't you just transfer energy mechanically with gears or whatever, and maybe a motor-generator combo or something (assuming this is the future and the motor and generator are super efficient)?
As in, just use a different method of energy transfer? Would energy still be lost this way? How?
guss said:
Haha, thanks.
ANY work you got out of the device would reduce the amount of matter (and energy) that you had. This is because work requires energy. The whole process would be 1000 times simpler if you just took out all the other stuff and left in the matter to energy converter.
Perhaps it inheres in the answers above, but:
WHY does the matter get converted back to energy? If you matter generator is cranking out iron, it falls on the wheel, generates electricity, and you've got slower-falling iron.
There's a part missing in your machine.
Those converters are just meant to be obscure objects. The fact that the matter is slowed should have little to no effect.
I think the scenario is (assuming 100% efficiency for the sake of the argument):
You have an object on top, you let it fall on a sort of "waterwheel" except it isn't using water but rather it gets it's energy from the collision of the falling object. When the object is at the bottom, to raise it back up you would need as much energy as you got out of the falling object assuming 100% efficiency. But if you convert the object into energy and transfer it to the top using electricity or gears or something else and then convert it back into the object, would you lose any energy by transferring it like that assuming 100% efficiency? And if you would keep on repeating the process, would this sort of a machine be able to do work without requiring extra energy being inputted?
No, you would lose energy by transferring it against gravity.
Aha!...huh?
I meant you've got slower-falling matter falling into the obscure energy converting machine.
Where is the part that coverts the matter into energy to feed into the energy-converting machine?
Please just add that to the other 2 obscure converters. One more won't do any harm.
You can fool the rest of these guys, but not me.
What do you mean dan? The bottom device converts matter to energy and the top converts energy to matter. I think it is just a representation of an actual device.
Ah, you're right. I just superficially glanced at the E, and confused it for the input.
OK, I'll buy stock.
guss said:
Haha, thanks.
It's an interesting problem! :smile:
If you would have a gear system running without transferring energy no energy would be lost.
However, if you take out energy at the top, and pump in energy at the bottom (with for instance a dynamo and an electric motor), some of the energy must be lost due to conservation of energy (i.e. the conversion to potential energy).
But exactly why that is? :confused:
The fun thing is that if the gear system were horizontal, then no energy would be lost! :smile:
I like Serena said:
I think the question is: what happens if your make a current go up against gravity. Energy conservation would imply that the electrical energy is lost when going up against gravity (that is, it is converted to potential energy).
It is. Think about it as electron flow and its obvious.
It's not obvious to me. :confused:
The simplest explanation that I can think of, would be that the electrons would gain potential gravity energy.
But that doesn't hold since the same number of electrons that go up, would go down.
Edit: Oh wait! The electrons that go up would be heavier (that is, contain more energy) than the electrons that go down?
Edit: Oh wait! The electrons that go up would be heavier than the electrons that go down?
Part of the kinetic energy is used by the "waterwheel", resulting in less energy gained at the matter-energy machine compared to what was released at the top. Repeated steps would cause the amount of matter dropped to dwindle until none was left.
IE: 100 protons are dropped from the top. They hit the wheel, cause work, and then fall to the bottom. The bottom device converts them to electrical energy and sends them to the topl. But wait! There isn't enough energy to send all 100 back to the top! So the device uses the energy of 1 proton to send the other 99. The process repeats and now only 98 can be sent to the top. After about 100 steps, there are no more protons! (By sending them to the top, I mean that it transfers enough energy to form 99 protons. Not that they are actually being transported)
Would you if you used a mechanical method of transfer like gears, though (zero friction, maximum efficiency)?
Yeah, thanks, much better way of saying it.
One easy way to think of why energy should be lost is this: say there was a solar panel at the top and a laser at the bottom hitting the solar panel. Let's say this method of transfer would be 100% efficient (in a perfect world) if the solar panel and laser were at the same altitude. Now let's imagine the solar panel is higher than the laser. When the laser is shown up, the photons are going to lose a little energy due to gravity, and therefore the solar panel would not absorb as much energy due to the fact that the photons are carrying more energy.
I tried to wrap my head around electricity, but I don't quite understand in a superconducting scenario. The easy way to think of it is as the electrons go up the wire, they slow down and therefore lose energy due to gravity. But, there are also electrons going down a different wire that would gain energy, and wouldn't that make up for the energy lost by the electrons going up?
The main thing I don't understand is how energy is lost when it is transported mechanically against gravity. Maybe something weird with special relativity or something?
... Note, this is obviously an oversimplified diagram. The wires are simply meant to represent the transfer of energy from one area to another, in this case, from an area of lower gravitational potential to an area of higher gravitational potential.
Hey, nice idea - here's another one. Say you shoot a gamma ray (energy) straight up, it hits your top converter and is converted into an electron and a positron (mass). The mass (electron/positron) now falls through the wheel and does some work, gets to the lower converter, the electron/positron join together and shoot straight up as a gamma ray again completing the cycle.
Where do we make up the energy? All I can think of is maybe we would loose energy to frequency shift as the lower converter is in a higher gravitational field.
No idea if this is correct...
Yes, it is clear that energy is taken out by the wheel (from the gained potential gravity energy).
What is not yet clear, is why energy is lost (converted to gravity energy) transferring it back up.
What's the difference with transferring it horizontally?
Yep! I think that we do. :)
Yep, I agree, I said something very similar in my post before this one I just edited that ties it back to the main diagram a little.
Actually, I think the same argument holds for the current carrying wire.
The electrons are pushed up by an electric field.
I think this field becomes weaker as it goes up against gravity.
(And the electrons would not becomes heavier as I conjectured earlier.)
Transferring it either horizontally or vertically makes no net difference. Vertically you have a gain in energy due to the matter falling that is counteracted by moving the energy, in whatever format, against gravity. Horizontally you have neither a gain nor a loss due to gravity.
The key here is that at BEST you could remove the water wheel and have a perfectly good perpetual motion machine. However, if you want to get work out of it then you WILL lose energy.
The gamma ray would redshift slightly on the way up, reducing its energy when it is absorbed by the machine on top. The loss in energy would be equal to the gain in kinetic energy of the falling particles.
If we remove the wheel, the matter will gain kinetic energy while falling, and this kinetic energy will be converted to heat when it hits the floor, bleeding the potential energy away.
(Or we could try to pick it up as well in the mass-energy-converter, maintaining a perpetuum mobile).
We are assuming a device to capture the matter and convert it into energy. The kinetic energy adds to the total energy, but that is counteracted by anything traveling against gravity back to the top.
  • · Replies 62 ·
13K
  • · Replies 21 ·
  • · Replies 37 ·
  • · Replies 16 ·
  • · Replies 18 ·
