| New Reply |
can opamp work this way ?? |
Share Thread |
| Aug30-11, 01:01 PM | #1 |
can opamp work this way ..?
when i input 2volts the output is 4volts , when i input 5 volts the output is 25 volts in simple words can opamp takes the square of input signals ?? is it possible ? i know how it work as differentiator, integrator, Summing amp but what about squaring ? |
| Aug30-11, 01:34 PM | #2 |
To obtain squares and square roots you need a four quadrant multiplier, such as the MC 1494.
There is an analog solution using the square law characteritic of diodes or FETs but they are tricky to set up. |
| Aug30-11, 01:37 PM | #3 |
can you please help about using diodes for squaring and square rooting ? what technique we use for squaring ?
like if we Apply n volts the output must b n*n or simply sum of n times , like if we apply 5 volts the output must be 5+5+5+5+5 |
| Aug30-11, 03:48 PM | #4 |
Review the circuit in
http://www.analog.com/library/analog...f/pdf/19_1.pdf The transistors are working in essentially the transdiode configuration, because they give superior diode lograrithmic performance than real diodes. Look at the equations Eq (1) thru (6). The (kT/q) log function is the ideal diode I-V response. Bob S |
| Aug30-11, 06:38 PM | #5 |
Mentor
| New Reply |
Similar discussions for: can opamp work this way ??
| Thread | Forum | Replies | ||
| OpAmp with same inputs | Engineering, Comp Sci, & Technology Homework | 1 | ||
| OPAMP as integrator | Electrical Engineering | 11 | ||
| opamp design | Electrical Engineering | 12 | ||
| opamp circuit | Electrical Engineering | 3 | ||
| Help with this OPAMP CKT | Engineering, Comp Sci, & Technology Homework | 9 | ||
