Solving a Limit Problem: x^3-5x+6-2 < 0.2
  • Thread starter Thread starter CrossFit415
    Confused Limit
The discussion revolves around proving a limit involving the expression x^3 - 5x + 6 as x approaches 1, specifically showing that it equals 2 within a certain epsilon (0.2) constraint.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the manipulation of the inequality |x^3 - 5x + 6 - 2| < 0.2 and the need to find a suitable delta. There is confusion regarding the relationship between epsilon and delta, and whether to adjust the polynomial expression.
Some participants are exploring different methods to express the limit condition in terms of delta, while others are questioning the steps needed to connect epsilon and delta. There is an acknowledgment of the need to use the polynomial division approach, but clarity is still being sought.
Participants mention constraints related to the use of a graph to find delta and the requirement to ensure that |x - 1| < delta leads to the desired inequality. There is also a note about the difficulty in expressing the problem due to limitations in formatting tools.
CrossFit415
Prove; limit as x->1 (x^3-5x+6) = 2, epsilon=0.2
I got |x^3-5x+6-2|<0.2
Then I don't know where to go from there. Should I add 2 to 0.2 first or subtract 2 from 6 to get x^3-5x+4 < 0.2 ?
I'm on mobile can't use latex. Thanks
What do you mean by "epsilon = 2"? Are you supposed to find a suitable delta?
Whoops I meant 0.2 Yea I'm trying to find delta.
Since you somehow want to use the fact that |x-1| < [itex]\delta[/itex], you should be trying to divide this polynomial by x-1.
Then you'll have |x3-5x+4| = |x-1| |P(x) | < [itex]\delta[/itex] |P(x)|, where P(x) is some other polynomial of order 2, which you could also bound...
Try that. :)
I'm sorry but I still do not understand. Couldn't we just solve for epsilon then replace it for delta? Thanks
I don't exactly understand what you mean.
You wrote |x^3-5x+6-2|<0.2
Defining f(x)= x3 - 5x + 6
But it's not that you need to solve an inequality. What you need to do, formally, is to find a [itex]\delta[/itex], so that for every x that holds |x-1| < [itex]\delta[/itex],
|f(x) - 2|| < 0.2.
So, like I said, you have to somehow use the fact that |x-1| < [itex]\delta[/itex].
You start off by writing |x3 - 5x + 6 - 2|, and you start looking for ways to somehow express it with, apart from other things, [itex]\delta[/itex]. You are looking to see how small this [itex]\delta[/itex] needs to be, so that |x3 - 5x + 6 - 2| is small enough.
You start off in the way I wrote. Otherwise - I don't understand your question.
Well it asks me use the graph to find a number Delta.
If |x-1| < d then |(x^3-5x+6)-2|<0.2
Then it tells me find Delta that corresponds to epsilon =0.2
Oh ok, I am starting to see it.
  • · Replies 27 ·
