| New Reply |
Prove this is greater than or equal to 8 |
Share Thread | Thread Tools |
| Sep24-11, 01:12 AM | #1 |
1. The problem statement, all variables and given/known data
Show that, if a, b, c >0 and a+b+c = 1, then, ([itex]\frac{1}{a}[/itex]-1)([itex]\frac{1}{b}[/itex]-1)([itex]\frac{1}{c}[/itex]-1) [itex]\geq[/itex] 8 2. Relevant equations The usual math is ok 3. The attempt at a solution I multiplied them out to get: ([itex]\frac{1}{abc}-\frac{1}{ac}-\frac{1}{bc}+\frac{1}{c}-\frac{1}{ab}+\frac{1}{a}+\frac{1}{b}[/itex]-1) = ([itex]\frac{1}{abc}-\frac{b}{abc}-\frac{a}{abc}+\frac{ab}{abc}-\frac{c}{abc}+\frac{bc}{abc}+\frac{ac}{abc}[/itex]-1) = ([itex]\frac{1-b-a+ab-c+bc+ac-abc}{abc}[/itex]) = ([itex]\frac{ab+bc+ac}{abc}[/itex]) = ([itex]\frac{1}{a}+\frac{1}{b}+\frac{1}{c}[/itex]), .........as 1-(a+b+c) = 0 abc is a small number as a,b,c are all less than 1, and it is and order smaller than anything in the numerator. OR, since a, b, c < 1, ([itex]\frac{1}{a}+\frac{1}{b}+\frac{1}{c}[/itex]) > 3 Now I don't know what to do. I'm not even sure I'm on the right track... There may be some other logic I should be using to make this easier, but I don't see it. |
| Sep24-11, 01:47 PM | #2 |
Mentor
| Sep24-11, 03:31 PM | #3 |
so, use c = 1 - a - b, substitute that into the first equation, and see what happens? |
| Sep24-11, 06:34 PM | #4 |
Mentor
That's what I had in mind, yes.
I tried that, and was able to factor things a lot, but I wasn't able to show that the expression on the left is >= 8. Where you might go next is to consider w = f(x, y) = (1/x - 1)(1/y - 1)( (x + y)/(1 -x - y)). Use calculus to show that there is a global minimum, and that the minimum value is 8. |
| Sep24-11, 07:21 PM | #5 |
[itex](\frac{1}{a}-1)[/itex] [itex]\geq[/itex] 2, as, if this is done, without loss of generality, it would apply to each, and 2x2x2 [itex]\geq[/itex] 8 |
| Sep24-11, 09:06 PM | #6 |
Mentor
| Sep24-11, 09:37 PM | #7 |
Recognitions:
I can't judge from your title or first post what level of analysis you have had already. So I'll propose a couple of things:
-- the straightforward one if you've had multivariate calculus is to use Lagrange multipliers, since you have a function and a constraint equation in three variables; you will be able to show easily that the critical point occurs where a = b = c ; you would then reduce the function to one with two variables and use the Second Partial Derivative Test to show that the value 8 is a minimum [the Test with three variable is messier]; this is, I believe, essentially what Mark44 is suggesting -- a non-calculus approach would be to consider that a + b + c = 1 in the first octant is an equilateral triangular region, the portion of the plane bounded by the coordinate planes; the product in question is plainly infinite at the edges of the triangle, so the interior must contain a minimum for the product; the three-fold symmetry of the region suggests that the "special point" lies where a = b = c = 1/3 ; that gives the "right number" for the product, but what is the behavior of the function?; fix one variable and shift one of the others by a small amount, which automatically shifts the remaining variable; show that any deviation from the special point must give a larger product |
| New Reply |
| Tags |
| analysis, proof |
| Thread Tools | |
Similar Threads for: Prove this is greater than or equal to 8
| Thread | Forum | Replies | ||
| [Number Theory] Prove (x^2 - y^2) is not equal to 6. | Calculus & Beyond Homework | 6 | ||
| Prove that the closure of Q is equal to R | Calculus & Beyond Homework | 15 | ||
| Prove that this vector is equal to this? | Introductory Physics Homework | 1 | ||
| prove 2/5 perfect squares must be even to have their sum equal odd | Calculus & Beyond Homework | 3 | ||
| Prove n^3 less than or equal to 3^n for n=1,2,... | Calculus & Beyond Homework | 4 | ||
