| New Reply |
Substitutions with ODE23/45 in MATLAB |
Share Thread |
| Oct5-11, 12:00 PM | #1 |
Hi everybody,
I am trying to solve laser rate equations with MATLAB using ODE23/45. For that I have to write the derivative terms always on the left hand side. This creates a lot of redundant variables in the function. Here is a part of the code: dy(1) = I/(q*V) - y(1)/Tau_n - y(4)*y(2); % derivative of the no. of carriers, N(t) dy(2) = (y(4)-1/Tau_p+log(100)/Tau_D) * y(2) + R_sp; % derivative of the no. of photons, S(t) dy(3) = (alpha/2)*3.2e3*(y(1)-N_th) + 20/Tau_D; % derivative of the optical phase, phy(t) dy(4) = y(5)*(-Kappa*y(6))+(1-Kappa*y(2))*y(7); % derivative of g(N,S) dy(5) = 3.2e3 * y(7); % derivative of g(N) dy(2) = y(6); dy(1) = y(7); Because of y(6) and y(7), I have to define initial values for them as well, for instance y(6) = y(7) = 1. This is now making problems for y(1) and y(2) since they are changing in each iteration, but because of the constant values of y(6) = y(7) = 1, MATLAB considers y(1) = y(2) = 1. Obviously, I do not want this to happen. I cannot write the dy(2) and dy(1) terms on the right hand side, since it is not allowed by MATLAB. Any suggestions to overcome this problem would be welcome. Thanks :) |
| Oct5-11, 12:01 PM | #2 |
Just to mention that Tau, Kapa, Tau_n, Tau_p and alpha are constants.
| Oct5-11, 06:20 PM | #3 |
Recognitions:
Can you post the mathematical equations you are trying to solve, not just your failed attempt at writing Matlab code?
I am guessing you have some basic misunderstanding about what you need to do here. |
| Oct6-11, 03:30 AM | #4 |
Thank you for your reply. So here are the equations:
dN/dt = I/q - N/Tau_n - g(N,S)*S % derivative of the no. of carriers, N(t) dS/dt = [g(N,S) - 1/Tau_p + log(100)/Tau_D] * S + R_sp; % derivative of the no. of photons, S(t) dphy/dt = (alpha/2) * 3.2e3 * (N-N_th) + 20/Tau_D; % derivative of the optical phase, phy(t) dg(N,S)/dt = dg*[-Kappa*g(N)]+[1-Kappa*S]*dS/dt; % derivative of g(N,S) dg(N)/dt = 3.2e3 * dN/dt; % derivative of g(N) There are more equations in fact but I have written the basic simplified ones, for the sake of understanding. According to MATLAB rules, one cannot write derivative terms on the right hand side. So I am using substitutions, as per the information available on mathworks website. This is what I did with y(6) and y(7) in the code for dS/dt and dN/dt in the code respectively. I look forward to your suggestions in this connection !!! |
| Oct6-11, 08:42 AM | #5 |
Recognitions:
I don't see why you need to introduce y(6) and y(7) at all.
If you wanted, you could substutute for dN/dt in dg(N)/dt = 3.2e3 * dN/dt to get dg(N)/dt = 3.2e3 * [ I/q - N/Tau_n - g(N,S)*S ] and similarly for dg(N,S)/dt. That "gets rid of the derivatives on the right hand side" without introducing any more variables. That's the way I would code it in matlab. Just write dy(1) = I/(q*V) - y(1)/Tau_n - y(4)*y(2); dy(2) = (y(4)-1/Tau_p+log(100)/Tau_D) * y(2) + R_sp; dy(3) = (alpha/2)*3.2e3*(y(1)-N_th) + 20/Tau_D; dy(4) = y(5)*(-Kappa*y(6))+(1-Kappa*y(2))*dy(1); dy(5) = 3.2e3 * dy(2); There is no problem using the value of dy(1) and dy(2) again after you have calculated them. Or if you feel worried about doing that, you could write temp1 = I/(q*V) - y(1)/Tau_n - y(4)*y(2); temp2 = (y(4)-1/Tau_p+log(100)/Tau_D) * y(2) + R_sp; dy(1) = temp1; dy(2) = temp2; dy(3) = (alpha/2)*3.2e3*(y(1)-N_th) + 20/Tau_D; dy(4) = y(5)*(-Kappa*y(6))+(1-Kappa*y(2))*temp1; dy(5) = 3.2e3 * temp2; |
| New Reply |
| Tags |
| matlab, ode 23 help, ode45 |
Similar discussions for: Substitutions with ODE23/45 in MATLAB
| Thread | Forum | Replies | ||
| Options when using the ode23/45 solver | Math & Science Software | 1 | ||
| Help!, solving simple PDE with ODE45 or ODE23 solver in matlab | Differential Equations | 5 | ||
| solve pendulum with ode23 | Calculus & Beyond Homework | 0 | ||
| How to solve an ode using MatLabs ode23 or ode45 | Calculus & Beyond Homework | 6 | ||
| MatLab help using ode23/ode45 | Math & Science Software | 2 | ||
