New Reply
wheel shimmy and wheel wobble difference
Share Thread Thread Tools
Oct14-11, 03:46 AM   #1
what is the difference between wheel shimmy and wheel wobble?...in certain books it said they meant the same..
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Oct14-11, 03:50 AM   #2
Recognitions:
Gold Membership Gold Member
I can't recall that I've ever heard the term "wobble" in reference to a wheel. To me, though, it seems to imply movement about a horizontal axis whereas "shimmy" is about a vertical one. Just my first thought, though; I don't really know.
Oct14-11, 03:53 AM   #3
Recognitions:
wheels have axial and radial run out. should not exceed 0.030" typically
Oct14-11, 05:23 PM   #4
Quote by monty37 View Post
For my personal definition, I think of "shimmy" as less intense than "wobble". (Although, I don't remember ever using "shimmy" to describe anything.)
Oct14-11, 11:13 PM   #5
A shimmy is when uncontrolled L/R oscillations in the front wheels cause the vehicle's direction to move left and right rapidly. It can happen in motorcycles, too. The Widowmaker, a 750cc three-cylinder bike was notorious for it: http://classicbikes.actieforum.com/t137-the-widow-maker
A wobble is merely a wheel's hub not being true. Thus, the hub's axis is not perpendicular to the directly of travel. It's often the result of hitting a major pothole or jumping a curb.
Oct15-11, 03:38 AM   #6
Being a mechanic, every wheel vibration gets dubbed as a "shimmy."... but yeah, wobble can be from a bent hub or bent rim, or on occasion someone forgetting to tighten lugnuts (i've seen it before! Yikes!) (so the axis of rotation is not perpendicular to the wheel)... Shimmy is usually from unbalanced wheels or abnormal tred wear; however, for engineering axial runout would be more probable (axis of rotation is not center in the wheel).
Oct15-11, 06:26 AM   #7
That quite cleared it ,can you elaborate on axial runout?
Oct16-11, 04:27 AM   #8
Recognitions:
run out is measured with a dial indicator..where it is placed determines the axial or radial run out..place it over the axle ..ie axial or place it on the outside of the wheel on tangent to the wheel radius..ie radial
Jan23-12, 05:52 PM   #9
Could I suggest taking a look at the work of Robin Sharp ( search Robin Sharp+ motorcycle) you will find some good technical papers.
New Reply
Thread Tools
Similar Threads for: wheel shimmy and wheel wobble difference
Thread Forum Replies
Friction and the difference between rear-wheel, front-wheel and four-wheel Engineering, Comp Sci, & Technology Homework 3
Calculating driving force from wheel rpm, wheel radius and engine power Mechanical Engineering 3
[High school physics] Wheel touching a kerb. What are the forces on the wheel? Introductory Physics Homework 4
calculate wheel torque based on known Weight, wheel size, acceleration data ? General Physics 9
translating velocity and angle into wheel speed (for a two wheel robot) Differential Equations 4
