If no singularity, what’s inside a big black hole?
The discussion revolves around the nature of the interior of black holes, particularly in the context of theories that propose the elimination of singularities, such as string theory and loop quantum gravity. Participants explore various hypotheses regarding what might exist inside a stellar-sized black hole, including concepts like ultra-dense states of matter and quantum geometries.
  • Some participants suggest that theories like string theory and loop quantum gravity could eliminate black hole singularities, leading to new predictions about the black hole interior.
  • One participant references a paper indicating that the singularity may be replaced by a "bounce" where quantum effects become significant, with the extent of this region depending on initial conditions.
  • Another participant provides a list of published papers that discuss the black hole interior, emphasizing that many works focus on the implications of loop quantum gravity.
  • There is a proposal that the interior of black holes may consist of a dense "spacetime foam" or a breakdown of quantum geometry, surrounded by a Kantowski-Sachs vacuum solution.
  • One participant expresses skepticism about the current understanding of black holes, suggesting that existing theories are preliminary and that geometry and matter may fundamentally be the same at extreme densities.
  • Another viewpoint is introduced regarding the "fuzzball" paradigm, which aims to address issues in traditional black hole physics.
  • A different perspective is mentioned, which claims to logically remove singularities from black holes and the universe, although this work is not peer-reviewed.
Participants express a range of views on the nature of black hole interiors, with no consensus reached. Some support the idea of a dense quantum state, while others emphasize the preliminary nature of current theories and the need for further exploration.
The discussion highlights the limitations in current understanding of black hole interiors, including unresolved mathematical steps and the dependence on various theoretical frameworks. The references provided suggest a breadth of research, but the interpretations and implications remain contested.
  • #91
The difficult thing is not so much calculating the correct area scaling law (although that was difficult enough), but rather giving a precise microscopic story about what the two local observers see, and how details of their measurements must be somehow entangled and noncommuting.
Since this is very much about details of semiclassical states, afaik this is way beyond LQG's current technology and it is not even addressed yet.
In fact, the exact details is not even known in string theory or AdS/CFT, and the fuzzball proposal is the only one that even tries to address this incredibly difficult problem head on.
  • #92
tom.stoer said:
What is the proton mass according to string theory? Up to how many arbitrary factors?
So let's continue seriously? or polemically?
You start here polemics. Indeed has been shown since long that in string theory the factor comes out right, to every detail. And what contributes are states that do go beyond "pure gravity", ie., have, in a sense, an extra-dimensional origin. In LQG, as far as I know, the result is proportional to an abitrary constant, the Immirzi parameter. This ambiguity (in front of a log!) thus does not allow to decide whether the number of states contributing is correct or not. So this is meaningless for settling this question in LQG.
This string computation is undisputable. What is disputable, and is disputed, is whether Mathur et al's explicit construction of the microstates, which goes much beyond just counting the states, is correct or not. While it looks convincing, there has been criticism, like for example whether the nice slice argument is physically well-defined etc.
As said we have been running a workshop on Quantum Gravity right now, which discusses this kind of questions. Tomorrow is LQG day and we will see what the LQG persons have to tell.
  • #93
http://www.physics.ntua.gr/corfu2011/st.html ?
  • #95
Sorry about that, but you started this kind of reasoning.
For extremal black holes with maximal SUSY, no Schwarzschild and no Kerr, right?
suprised said:
This ambiguity thus does not allow to decide whether the number of states contributing is correct or not. So this is meaningless for settling this question in LQG.
We know that all theories including quantum gravity (including string theory) are work in progress. So of course there are open questions. Everybody in the LQG community would agree that the Imirzi parameter os one of them.
All what I wanted to say is that there seems to be a very detailed description based on microscopic degrees of freedom which can be applied to "classical black holes". The Immirzi parameter has to be fixed, then the prediction is unambiguous. I do not see a problem to have one parameter in a theory w/o being able to derive it theoretically. You can't do that in other theories, either (QCD coupling constant / scale, GSW coupling / Fermi constant, ...)
fine
  • #96
not aware of...
Sure, that's the way non-perturbatively exact statements can be made without directly solving the theory.
Maybe I didnt make the significance clear enough. This is not only just some parameter like the QCD coupling that needs to be fixed. This would indeed be a triviality and no reason to muck around. Rather, because it multiplies the entropy, it directly affects how you count the number of states of the theory. Since this parameter is arbitrary, AFIAK, it is impossible to tell whether the states provided by LQG are "enough" such as to account for the microstates of black holes. Tuning the parameter to the "right" value won't continuosuly change the number of states until it matches the correct count. Rather it should be seen as a prefactor multiplying an unknown state count.
Thus, this result does not shed light on the question whether LQG provides, or not, the correct degrees of freedom of QG. This in contrast to strings, where the state count (in toy model examples of black holes) comes out right on the nose, including subleading quantum corrections.
These facts are known to anybody working in the field, and this was also confirmed by today's discussions.
  • #97
derek101 said:
if matter and anti-matter annihilate,only the expansion of time can keep them apart.thus a singularity at the center of a black hole i suggest consists of anti-matter 13.7 billion years in the past(back to the big bang)and matter 13.7 billion years into the future.the matter in the surrounding galaxy is being sucked into the future this is my understanding of space time.
Welcome to the forum.
I don't know what your purpose is here but this kind of "personal opinion" doesn't fly well with the moderators, especially when it looks like nonsense. If you are asking a question (and I don't see one in the above post), I would suggest that it be "why is my understanding of space-time so totally at odds with accepted physics".
  • #98
suprised said:
... Rather, because it multiplies the entropy, it directly affects how you count the number of states of the theory. Since this parameter is arbitrary, ... it is impossible to tell whether the states provided by LQG are "enough" such as to account for the microstates of black holes. Tuning the parameter to the "right" value won't continuosuly change the number of states until it matches the correct count. Rather it should be seen as a prefactor multiplying an unknown state count.
I never understoof the Immirzi parameter as a multiplicative parameter for the number of states (for a given area) but always as a multiplicative constant for the (classical) area given a predefined state count. So there are two issues: is the counting correct? what's the value of the Immirzi parameter?
What was the result of the discussion with the LQG colleagues you mentioned.
  • #99
I checked some papers (especially Sahlman, Agullo, Barbero) and I think they agree on the state counting. So this issue goes away.
I still have to look for recent results regarding the Immirzi parameter (which does not affect the entropy for a given spin network, but 'only' the area related to a given spin network; so as I said, the value must be fixed, but it does not affect the counting itself, only its relation to the 'classical area').
The picture within LQG is remarkable simple:
- the horizon is characterized by the 'isolated horizon condition'
- the state count is defined by spin network punctures of the horizon
- the microscopic degrees of freedom are spin networks (plus induced surface degrees of freedom)
- the calculation is known for realistic Schwarzschild black holes
- afaik the Kerr solution has not been studied so far
- afaik neither a dynamical collaps nor evaporation has been studied so far
- entropy is related to microstates but not yet to temperature
  • #100
Well, we have had various discussions and the general consensus seems that this formula is inconclusive, with regard to the question whether the right number of states is counted. In fact the "right" value of the Immirzi parameter depends on the particular LQG model, and thus is non-universal. And for spin foam models, which seem to have replaced LQG, there are AFAIK few, if any, relevant entropy calculations, and the Immirzi parameter does not appear. So the general feeling seems that while there are encouraging signs, something still is wrong or at least not understood.
The whole issue seems always to boil down to the following two possibilities: either gravity can be made sense of out of itself (by regularizing/discretizing it, UV self-completing it, etc), or it needs to be embedded into a "larger" theory which UV-completes it. But this is getting off-topic.
  • #101
I agree that there is no consensus regarding the Immirzi parameter. But we do not agree on the reasoning in general.
As far as I understand the models in LQG the idea is always to define a surface by isolated horizons and to "count states". Whether this counting is correct or not has nothing to do with the free parameter; the parameter is needed to define the area of the horizon. So as I said there are two issues: one is the counting itself, another one ios the value of the parameter.
I agree that something is still missing, but at the same time I would say that a lot is already correct, b/c up to a free parameter everything seems to fit nicely.
  • #103
If the radiation ball model described earlier is correct (0.75 Schwarzschild radius ), its possible for similar size merging black holes to partially or completely annihilate in a mini big bang.
  • #104
I wonder if some of the merged galaxies that appear to have had an explosion in the center actually have had an explosion in the center. Its now accepted that when galaxies merge the super massive black holes in the center can also merge. If the radiation ball model is correct these super massive black hole mergers might result in a massive ejection.
  • #105
Maybe a radiation star of R > 0.75 SR can exist in a black hole, as a partial radiation/quark mixture.
  • #106
On the other hand, most internet sources say radiation pressure equals (1/3)pc^2 and that gravitational potential energy for a neutron star (or radiation star) should equal (GM^2)/R. Using the viral theorem then also gives R = 0.75 SR for a radiation star. I'll try to get some authoritative opinion on this within a week.
  • #107
The other thing to consider is that inside 2M, r is temporal (as t is temporal outside 2M) so you would also have to consider the spacetime metric which would have to switch from space-like to time-like again in order to maintain a stable radius, is there a solution/form synonymous with Schwarzschild metric that suits this and incorporates a radiation star? The switch back to time-like space does occur with a charged and/or rotating black hole, though the charged solution is considered not very realistic as the universe has a tendency to neutralise any object with a charge. In its own way, the Schwarzschild solution is also deemed unrealistic due to the fact that it is an absolutely static solution whereas it's almost certain that no matter how small, all celestial objects have some degree of spin. The event horizons for black hole with spin are-
[tex]r_\pm=M\pm\sqrt{M-a}[/tex]
where [itex]r_\pm[/itex] represents the outer and inner horizon, spacetime becoming space-like in the radial at r+ and reversing to time-like at r-. The boundary of the radiation star (ring even) might occur within or at the inner horizon though the inner horizon (or Cauchy horizon) is sometimes described as the boundary of predictability, itself being a contender for a weak singularity.
  • #108
To continue, to calculate the radius of a non-spinning, non-magnetic star in a black hole using the viral theorem, here’s the best formulas I’ve found so far for radiation pressure and gravitational potential energy of a gas star of density profile 1/r^2. If anybody can suggest better formulas, please do!
Most sources state the pressure exerted by radiation is one third of its average energy density. That sounds sensible. Even relativists would probably agree that as material collapses into a black hole, all or much of it becomes relativistic no matter what form it takes (radiation, neutrons, or exotic matter), and the maximum pressure it would exert should be one third of its average energy density if all the matter was converted into relativistic particles or radiation. Therefore (1/3)Mc^2 should be the maximum support energy of any form of star, and this should determine the minimum radius. (The radius would be larger if not all the mass was converted to relativistic form.)
Most sources say the gravitational potential energy of a gas star of density profile 1/r^2 is about (GM^2)/R , but I’m not satisfied with that formula and have estimated that the gravitational potential energy is 28% higher than that of a constant density profile star [ (0.6GM^2)/R ], or about (0.82GM^2)/R. If anybody wants to know how this estimate was done, or has a better estimate, please speak up.
Using the viral theorem, if (1/3)Mc^2 = (0.41GM^2)/R , then R = 1.23GM/c^2. This means, if you use this train of thought, that the minimum radius of a star inside a black hole should be at least 61.5% of the Schwarzschild radius. This very possibly is not large enough for a huge ejection to occur if 2 equal size small black holes merge. But again, the star should be larger than 61.5% of the SR if not all the mass is in relativistic form, which is very possible and probably likely. Hopfully the merger of 2 objects identified as nearly equal mass black holes will be observed in the next few decades. That’s about the best I can do at this time. If anybody has any suggestions or comments, fire away.
BTW, here’s an interesting tidbit, for what its worth. So far, of the 2000 observed neutron stars the largest have a mass of 1.97 solar mass, and this is probably near the upper limit. Also, of the 20 observed small black holes in the Milky Way, so far the smallest equals about 5 solar mass.
  • #109
We recently had a lecture on black holes in the college. We were told about the new development going on in the field of theoretical physics on black holes. The prof. was telling that most of the singularities have been removed 2 a great extent but introducing another different set of co-ordinate system.
  • #110
Exactly, most of the singularities; this thread is about the singularity that cannot be removed by a clever joice of coordinates.
If you look at the Schwarzschild metric
http://en.wikipedia.org/wiki/Schwarzschild_metric
you find that it's singular at r=0 and r=2M. The latter singularity is due to the choice of the coordinates and can be removed, e.g. via Eddington-Finkelstein- and Kruskal-Szekeres- coordinates:
http://en.wikipedia.org/wiki/Schwarzschild_metric#Singularities_and_black_holes
The singularity at r=0 is not due to coordinates but is 'real'. This can be seen by looking at coordinate-independent scalars, e.g. the Kretschmann invariant
http://en.wikipedia.org/wiki/Curvature_invariant_(general_relativity )
which is obtained from a special contraction of the Riemann curvature tensor. The Kretschmann invariant scales as K(r) ~ 1/r6. Now you could use a different coordinate system; the function for K expressed in the new coordinates would look different, but at the space time point which corresponds to r=0 the Kretschmann invariant will again be singular.
  • #111
I've enjoyed this thread, but I have been missing some mention of the experimental record. No naked singularities have ever been detected so the black hole as a singularity is in the same company as monopoles and decaying protrons. If no singularities are produced at the LHC it might be time to give them up altogether.
There is recent data supporting a subsequent stage to a neutron star where matter flows without viscosity (http://www.nasa.gov/mission_pages/chandra/news/casa2011.html). This view receives interesting support from attempts to create a quark-gluon plasma (www.bnl.gov/rhic) which finds that at enormous temperatures protons appear to "melt" into a non-viscous state. The simple, classical way to explain what is happening is that when matter is sufficiently compressed a force arises that is powerful enough to resist gravity. We know that such short range powerful forces exist because the weak force behaves in this way.
Does anyone following this thread know of any attempts to explain why such quasi-superfluid states exist at enormous pressures and temperatures? Based on the present evidence, it seems possible that black holes may be superfluids.
  • #112
So you have in mind to identify a non-gravitational force that is able to resolve the singularity no matter how large the mass M of the object might be?
The first problem is that afaik no such force is known.
The second problem is that in order to understand GR (and QG) the singularity has to be resolved by gravity itself. You cannot expect that a theory X saves a theory Y that fails at a singuarity. It's up to Y (or an extension of Y) to cure itself.
  • #113
You have answered my question as to whether or not you know of someone who is trying to explain the non-viscous states of matter seen recently at BNL and by NASA trying to explain the behavior of a spinning high mass neutron star. The answer appears to be no. I hope I can provide something of an answer to your questions.
Thinking classically, although I know that this may be inappropriate, I see that with helium superfluids, both He-4 (bosonic) and He-3 (fermionic) repel themselves after London forces are switched off due to extreme cooling. This possible repulsive force is of the same magnitude as that of gravity. If we imagine that it is an inverse square law force, compressing matter, whether in a neutron star or at the RHIC, would be able to reproduce the non-viscous behavior that we see with helium superfluids. The search for a fifth force that opposes gravity with roughly the same magnitude is ongoing with no clear result so far (http://en.wikipedia.org/wiki/Fifth_force). I don't know of any attempt to incorporate such a fifth force into our understanding of GR at this time. So the answer to your first question is that there are some who would very much like to see a fifth force, but results thus far are inconclusive due to the weakness that such a fifth force is expected to have at normal pressures and densities.
The second question has to do with theories, but I would like to consider only GR. The discovery of dark energy, though no such potential force had been identified during Einstein's life, did not upset GR because its behavior was consistent with the cosmological constant term. GR is well-defined only up to the Schwarzschild radius. A force which prevented a singularity (not the singularity at 2M which depends on the coordinate system which you have pointed out, but the singularity at 0) would not necessarily do any harm to GR just as dark energy has done no harm to GR. The question would be whether or not such a force would have an effect at lower matter densities where we do depend on GR, outside the Schwarzschild radius. Extremely careful measurements at the University of Washington (http://www.npl.washington.edu/eotwash/) so far indicate no additional forces at normal temperatures and densities.
I am suggesting the existence of a fifth force (sixth if we count dark energy). The possibility of a fifth force is not new. If I am suggesting anything new, it is that this fifth force will only be seen at extreme density or at very low temperature. Thanks for your response, by the way. I enjoyed thinking about the questions that you posed.
  • #114
I think allintuition is on the right track by bringing up a quark-gluon plasma or other force in the core. One thing we can safely conclude about the core is that it is not neutrons. I no longer believe a star in a black hole would be a radiation ball. With a distributed mass star in a black hole (instead of a singularity), if all the matter was relativistic, pressure would be (pc^2)/3, and this pressure is so great it would force the mass far out beyond the Schwarzschild radius. A quark-gluon plasma in the core makes sense, and quarks have a higher collapse pressure than neutrons. But as for the upper layers and surface of the star, I think that could be neutrons since the pressure there is similar to pressures found in a neutron star.
  • #115
Even the QGP would not resist the collaps b/c it's not a specific interaction but simply the Fermi degeneration pressure that acts as a repulsive force. This is not sufficient to keep a massive neutron star stable and it would not change that much for a QGP- or a quark-star
Have a look at http://en.wikipedia.org/wiki/Degenerate_matter#Quark_degeneracy
  • #116
But (pc^2)/3 is more than sufficient to prevent collapse.
  • #117
"So you have in mind to identify a non-gravitational force that is able to resolve the singularity no matter how large the mass M of the object might be?"
Yes. For one model I think something roughly similar to a conventional neutron star could exist within the Schwarzschild radius. The upper layers and surface of the star could be neutrons since the pressure there is similar to pressures found in neutron stars. But pressures and densities in the core would be so great that the core material would go "relativistic" and generate a pressure of (pc^2)/3. It doesn't matter what the core is made of (quarks, etc), so long as it generates (pc^2)/3. The star might even have a radiation "atmosphere" - all located well within the Schwarzschild radius. But my earlier estimate of star size would be a little off because the upper layers would be supported mostly by neutron degeneracy pressure, which would be smaller than (pc^2)/3.
  • #118
what would be the equation of state?
afaik for a neutron star one uses p = ρ/3 which is ultra-relativistic and which does not prevent a collaps.
  • #119
All that's needed is to prevent core collapse, since that's where collapse happens. I don't think P = (pc^2)/3 is used for a neutron star core prior to collapse. But I think it would apply after core collapse.
  • #120
Also, at energies dramatically higher than that for quark production, where even quarks break up, it might be possible that P approaches or equals pc^2, but I don't think that much pressure is needed to support a star core in a black hole.
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 29 ·
15K
  • · Replies 22 ·
  • · Replies 20 ·
  • · Replies 29 ·
