Proof of work done by an ideal gas in a quasi-static adiabatic expansion
The work done by an ideal gas during a quasi-static adiabatic expansion can be expressed as W = (PfVf)/(Y-1)[1 - (Pi/Pf)^((Y-1)/Y)], where Y represents the heat capacity ratio (gamma). The derivation involves applying the first law of thermodynamics and the relationship PV^Y = constant. The key steps include substituting pressure and volume terms and factoring out PfVf to simplify the expression. The discussion emphasizes the importance of recognizing that the work is positive during expansion when no heat is exchanged (Q=0).
  • Understanding of the first law of thermodynamics
  • Familiarity with adiabatic processes in thermodynamics
  • Knowledge of the heat capacity ratio (gamma)
  • Basic calculus for integration and differentiation
  • Study the derivation of the first law of thermodynamics in detail
  • Learn about adiabatic processes and their applications in thermodynamics
  • Explore the concept of heat capacities and their significance in gas laws
  • Practice solving problems involving work done by gases in various thermodynamic processes
Students of thermodynamics, physics enthusiasts, and anyone involved in engineering or physical sciences who seeks to understand the principles of work done by gases during adiabatic expansions.
jrklx250s
Prove that the work done by an ideal gas with constant heat capacities during a quasi-static adiabatic expansion is equal to
W= (PfVf)/(Y-1)[1 - (Pi/Pf)^((Y-1)/Y)]
where Y = gamma, which is heat capacity at constant pressure over heat capacity at constant volume
Alright so this is my attempt and I am not sure where to go from here...
In an adiabatic quasi-static process we can write the formula
PV^Y = constant
constant = K for simplification
Since its adiabatic no heat change so Q=0
Using the first law of thermo
Q= ΔU -W
We know that W = -PdV
and P= K/V^Y
so...
W = ΔU
W = -PdV
W = -(K/V^Y)*dV
W = -K∫(1/V^Y)*dV
W = -K[V^(1-Y)/(1-Y)]*∫dV
W = -(K/(1-Y))[Vf^(1-Y) - Vi^(1-Y)]
W = -(K/(1-Y))[Vf^(-Y)*Vf - Vi^(-Y)*Vi]
W = -(1/(1-Y))[((Vf*K)/(Vf^Y)) - ((Vi*K)/(Vi^Y))]
since Pi = K/Vi^Y and Pf = K/Vf^Y sub those in
W = -(1/(1-Y))(Vf*Pf - Vi*Pi)
Times this by (-1/-1)
and we get
W = (PfVf - PiVi)/(Y-1)
This is where I get to not sure where to go from here to make this into
Any suggestions and help would be greatly appreciative.
As this is an expansion, and Q=0, the work of the gas is positive. The formula results in negative work, as Pi/Pf>1 and (γ-1)/γ >0, so it should be the external work.
PV^Y = constant
Q= ΔU -W
The elementary work of gas is WG=PdV. That of an external force is -PdV. So you determine the work of the external agent.
Nice derivation!:smile:
Factor out PfVf and use that PiViγ=PfVfγ to replace Vi/Vf
by (Pf/Pi)1/γ.
ehild
