Solving Hard Integral: \int^{\infty}_0\frac{\sin x}{\sqrt{x}}
  • Thread starter Thread starter matematikuvol
    Hard Integral
The discussion revolves around evaluating the improper integral \(\int^{\infty}_0\frac{\sin x}{\sqrt{x}}\,dx\). Participants explore various methods and approaches to tackle this integral, which falls under the subject area of calculus and improper integrals.
  • Participants discuss integration by parts and substitution methods, with some suggesting the use of complex analysis techniques, such as contour integration. Others question the necessity of these methods and explore alternative approaches, including the use of Laplace transforms and integral tables.
The conversation is active, with multiple participants contributing different perspectives and methods. Some have pointed out potential mistakes in earlier attempts, while others have offered insights into the nature of the integral, such as its relation to Fresnel integrals. There is no clear consensus on a single method, as various interpretations and techniques are being explored.
Participants note the importance of correctly transforming differential elements during substitutions and the potential complexity of the integral, indicating that it may not have a straightforward solution. There is also mention of constraints related to homework expectations and the need for proper justification of methods used.
matematikuvol
Solve
[tex]\int^{\infty}_0\frac{\sin x}{\sqrt{x}}[/tex]
[tex]\lim_{t\to \infty}\int^{t}_0\frac{\sin x}{\sqrt{x}}[/tex]
[tex]\sqrt{x}=v[/tex]
so
[tex]\lim_{t\to \infty}\int^{t}_0\frac{\sin v^2}{v}[/tex]
Integration by parts maybe? What is idea?
Do not forget dx from the integral. When substituting, you need to transform dx too.
ehild
Mistake
I will get
[tex]2\int^{\infty}_0\sin v^2dv[/tex]
matematikuvol said:
Mistake
I will get
You will get [itex]\displaystyle \int^{t}_0\frac{\sin x}{\sqrt{x}}\,dx=2\int^{\sqrt{t}}_0\sin (v^2)\,dv\,.[/itex]
But t goes into [tex]\infty[/tex] so I write in correct way last step.
Have you been introduced to the idea of using contours in the complex plane to solve integrals on the real line? Because if you have, that seems like the simplest way to solve this.
Is there some other way?
No, not every problem has a trivial solution!
Nope, have you been introduced to the idea I mentioned? I find it hard to believe that this question would be set if you haven't...
[tex]\int^{\infty}_0\frac{\sin x}{\sqrt{x}}=\lim_{a\rightarrow 0^+}\int^{\infty}_0 \frac{\sin x}{\sqrt{x}}e^{-a x}=\lim_{a\rightarrow 0^+}\sqrt{\frac{\pi}{2(a^2+1)(a+\sqrt{a^2+1})}}[/tex]
Complex methods are not the only way to do integrals.
or
The complex part of complex methods to do integrals can be hidden.
Depending on ones perspective.
matematikuvol said:
Ok. But I would like to see some trick how to calculate this integral in the desert island :)
I would expect you to have a table of standard integrals or something in which this one is included.
or
And how you get
[tex]\int^{\infty}_0 \frac{\sin x}{\sqrt{x}}e^{-a x}dx=\sqrt{\frac{\pi}{2(a^2+1)(a+\sqrt{a^2+1})}}[/tex]
or
Looks like a Laplace transform.
Seems to me that it's not trivial to calculate it yourself.
Did you use some table to find the transform?
We want to get rid of the 1/sqrt(t) so substitute
[tex]\frac{1}{\sqrt{t}}=\frac{2}{\sqrt{\pi}}\int_0^{ \infty } e^{-s^2 t}ds[/tex]
then interchange s and t integrations
[tex]\int^{\infty}_0 \frac{\sin(b t)}{\sqrt{t}}e^{-a t}dt=\frac{2}{\sqrt{\pi}}\int_0^{ \infty }\left\{\int_0^{\infty}\sin(b t)e^{-a t}e^{-s^2 t}dt<br /> <br /> \right\}ds=\frac{2}{\sqrt{\pi}}\int_0^{ \infty } \frac{b}{(s^2+a)^2+b^2} ds=b \cdot \sqrt{\frac{\pi}{2} \cdot \frac{1}{(a^2+b^2)(a+\sqrt{a^2+b^2})}}[/tex]
[tex]\int^{\infty}_0 \frac{\cos(b t)}{\sqrt{t}}e^{-a t}dt= \frac{2}{\sqrt{\pi}}\int_0^{ \infty }\left\{\int_0^{\infty}\cos(b t)e^{-a t}e^{-s^2 t}dt<br /> <br /> \right\}ds=\frac{2}{\sqrt{\pi}}\int_0^{ \infty } \frac{s^2+a}{(s^2+a)^2+b^2} ds=\sqrt{\frac{\pi}{2} \cdot \frac{a+\sqrt{a^2+b^2}}{a^2+b^2}}[/tex]
That last integral is messy, but it can be done with usual elementary calculus methods and functions. These might be in some Laplace transform tables though often some manipulation is required to get the right form.
Nice trick, lurflurf. But residue theorem leads to a quicker solution, though. Anyway nice post. :)
  • · Replies 105 ·
13K
  • · Replies 21 ·
  • · Replies 22 ·
