| New Reply |
Why all these prejudices against a constant? ("dark energy" is a fake probem) |
Share Thread | Thread Tools |
| Nov14-11, 02:37 PM | #69 |
| Nov14-11, 02:44 PM | #70 |
![]() But in fact when I said "we" I was interpreting from the passage from Bianchi and Rovelli that I quoted in post #65: "Why does standard QFT have so much trouble adjusting to this straightforward physical fact? We do not know the answer, but ..." |
| Nov14-11, 03:02 PM | #71 |
Since we are discussing the argument on page 7 of the Bianchi Rovelli paper, I should give the link again:
http://arxiv.org/abs/1002.3966 Why all these prejudices against a constant? Eugenio Bianchi, Carlo Rovelli (Submitted on 21 Feb 2010) The expansion of the observed universe appears to be accelerating. A simple explanation of this phenomenon is provided by the non-vanishing of the cosmological constant in the Einstein equations. Arguments are commonly presented to the effect that this simple explanation is not viable or not sufficient, and therefore we are facing the "great mystery" of the "nature of a dark energy". We argue that these arguments are unconvincing, or ill-founded. 9 pages, 4 figures An easy way to get the paper is simply to google "constant prejudices" ![]() The arxiv link should turn up as the first or second hit. Anyone coming in new would be well-advised to read the paper. It is easy to understand and puts the discussion here in a clearer light. |
| Nov14-11, 03:33 PM | #72 |
| Nov14-11, 05:30 PM | #73 |
But we can't verify the coupling of gravity directly to the individual loops involved in these quantum contributions. |
| Nov14-11, 06:58 PM | #74 |
| Nov15-11, 03:11 AM | #75 |
I suspect the 10^12 test you refer to is the classical mechanics test of the torsion pendulum, right? If there really experiments made that verifies the equivalence principle for actual lamb shift, that would be news for me. I think it's in principle testable, but the problem is as far a I know that the gravitational field on earth is too weak to yield much of a significant possibility to test it here? But I do not follow all new experiemtns, if someone konws of an actual test of the equivalence principle for lamb shifted systems I would be interested to read about how the experiment was conducted. I have seen some old papers where it was "in principle testable" was devicded, but the conclusion was that in practice it wasn't becaues hte gravity on earth is so weak. I'm not sure if some astronomic observations of lambshifted systems near more massive bodies is possible? I'm not sure how that would be done. /Fredrik |
| Nov15-11, 10:31 AM | #76 |
@Fra, Here is a reference that is the most referred in the literature but you'd have to go to your library to actually read it: http://slac.stanford.edu/spires/find...ww?irn=6818293
Please, read very carefully what I said in my previous comment b/c your response indicated that you had misunderstood it. |
| Nov15-11, 05:31 PM | #77 |
I looked at Polchinski's paper and understand now why you're right. Thanks. |
| Nov15-11, 05:53 PM | #78 |
@Harv, no problem! Joe's article is good and pretty much sums up the current situation. I saw his talk on this topic at KITP back in 2006, you can find it here if you're curious: http://online.itp.ucsb.edu/online/st...06/polchinski/
| Nov16-11, 07:01 AM | #79 |
Recognitions:
However I think I am correct in pointing out that the apparent magnitude of the problem occurs b/c of the scales mismatch, which is essentially set by the infrared physics. As far as numerology goes. I like the following two observations as well. If you take the cutoff to be the mass of the lightest neutrino, the scales match. Another weird coincidence... The supersymmetry breaking scale seems to be exactly halfway (on a logarithmic scale) between the vacuum energy scale and the Planck scale. Why? |
| Nov16-11, 12:07 PM | #80 |
That's why I did not really want to identify MSUSY with the scale obtained in some 4D EFT from the soft breaking but the numerology looks cute ![]() You probably mean perturbative instead on non-perturbative, right? This computation is in 10D, so there are no KK states involved. That said, at such extremely short distances even in a compactified 4D vacuum all the KK modes become light and the theory does effectively become 10 or maybe 11 dimensional. I think that what one really needs here for a realistic computation is to translate soft SUSY breaking in some 4D EFT into the splittings in the entire string spectrum and then compute the one-loop partition function. My hunch is that the scale of the boson-fermion splitting in the string levels would be related to the gravitino mass scale instead of the string scale and the result of the computation may actually give the correct order of magnitude. What was really neat for me to learn was that the finiteness of the CC in a non-tachyonic non-SUSY string theory is guaranteed by the modular invariance, despite the presence of an infinite tower of contributions in the UV. Here is a nice reference where you can read about these ideas: http://arxiv.org/PS_cache/hep-th/pdf/9503/9503055v2.pdf |
| Nov17-11, 03:39 AM | #81 |
Anyway my point was this: That paper tests WEP to one part in 10^12, but it's all classical mechanics (torsion balance) and relatively speaking macroscopic classical systems (which is dominated by baryonic mass) with classical measurements. Thus I question the validity of that test when applied to situations where the classical mechanics framework just don't hold. Also just as a ballpark number it seems the contribution of lamb shift to the classical level mass is the order of 1 in 10^15 or so? Which seems to be beyond hte level os current experimental tests? So I didn't quite get how that classical mechanics test of WEP for 1 part in 10^12 gives any information about the the nature loop corrections in general (which then of course goes outside classical mechanics)? Perhasp I'm missing something, could you explain? /Fredrik |
| Nov17-11, 09:30 AM | #82 |
Trying to make sure I understand the logic, let me know if I get it wrong:
/Fredrik |
| Nov17-11, 11:25 AM | #83 |
| Nov17-11, 11:39 AM | #84 |
| Nov19-11, 10:03 AM | #85 |
I read the Bianchi & Rovelli paper as well as Chap VIII.2 “The Cosmological Constant Problem and the Cosmic Coincidence Problem” in Zee, Quantum Field Theory in a Nutshell, Princeton Univ Press, 2003 (p 434). I do not find any disagreement regarding the facts, only their reactions thereto. For example:
B&R write, “But to claim that dark energy represents a profound mystery, is, in our opinion, nonsense.” In contrast, Zee introduces this subject by saying, “I now come to the most egregious paradox of present day physics.” Regarding the coincidence problem, B&R write, “it is quite reasonable that humans exist during those 10 or so billions years (sic) when [tex]\Omega_b[/tex] and [tex]\Omega_\Lambda[/tex] are within a few orders of magnitude from each other.” In contrast, Zee writes, “the epoch when [tex]\rho_M \sim \Lambda[/tex] happens to be when galaxy formation has been largely completed. Very bizarre!” Both agree that (per B&R) “There is no known way to derive the tiny cosmological constant that plays a role in cosmology from particle physics. And there is no understanding of why this constant is not renormalized to a high value.” B&R’s reaction to this fact is, “But this does not means (sic) that there is something mysterious in the cosmological constant itself: it means that there is something we do not understand yet in particle physics.” While Zee writes, “But Nature has a big surprise for us. While theorists racked their brains trying to come up with a convincing argument that [tex]\Lambda = 0[/tex] observational cosmologists steadily refined their measurements and recently changed their upper bound to an approximate equality [tex]\Lambda \sim (10^{-3} \mbox{ev})^4!!![/tex] The cosmological constant paradox deepens.” In short, the B&R paper merely argues for a particular emotional reaction to the situation regarding the cosmological constant in physics and cosmology. I would be surprised to see this paper published in a physics journal, since it does not expand upon our knowledge of physics. However, the paper’s use of a timely topic to highlight one aspect of our failure to unify the Standard Model with gravity is not without value. I could see this included in the proceedings for a philosophy of science symposium, for example. It would also be appropriate for a pedagogical journal in physics. It certainly motivated me to look more deeply into the issue. Thanks for posting this, marcus. Edit: I'm trying to figure out how to use TeX in PF. Obviously, I haven't found an "in line" tex command yet. |
| New Reply |
| Thread Tools | |
Similar Threads for: Why all these prejudices against a constant? ("dark energy" is a fake probem)
| Thread | Forum | Replies | ||
| Simple probem check | Precalculus Mathematics Homework | 8 | ||
| some probem in my salters investigation | Biology, Chemistry & Other Homework | 0 | ||
| Cycle over slope probem | Introductory Physics Homework | 2 | ||
| [SOLVED] PRobem of deconvolution... | General Physics | 4 | ||
| PHysics 11 Pulley probem | Introductory Physics Homework | 5 | ||
