| New Reply |
Liquid Fluoride Thorium Reactor |
Share Thread | Thread Tools |
| Nov14-11, 05:17 PM | #69 |
I do not see where Flibe Energy makes any five year claims, nor any connection at all with the US Military.
| Nov16-11, 03:20 PM | #70 |
Also, have a look at this: http://www.orlygroup.com/secondary_revenue_streams.html And this: http://atomicinsights.com/2011/11/te...#comment-12784 Something's going to happen in the next 5 years - sad to say, it's not likely to be here in the UK as there are too many 'What Ifs' in the air, combined with zero experience and zero political vision. |
| Nov16-11, 04:59 PM | #71 |
I did find this TED video interesting from lftrsuk' links above, by a couple of MIT nuke eng's on they are calling the "WaMSR", a molten salt designed to burn spent fuel (UOx?) instead of thorium. Good idea from a political / marketing stand point as it plays on the desire to get rid of nuclear waste.
They address one of the advantages discussed above in this thread: the Zirc Alloy metal cladding used in solid fuel reactors has a short life (4 years tops) which forces replacement and limits burnup, increasing the waste stream. Ok, great. But in an MSR, at some place the critical portion of the salt still has to be contained by some solid material (graphite?), that solid material will undergo a high flux and over time have to be replaced. Is this not moving the problem from one place to another? Perhaps the advantage of MS over solid Zirc rods is that, while the graphite (?) moderator might require replacement, the liquid fuel does not and can continue burn up? Can such a moderator be replaced without replacing essentially the entire reactor vessel? |
| Nov17-11, 02:26 AM | #72 |
LFTR is, to my mind, a profoundly stupid, dangerous idea and so's any other liquid fluoride salts based scheme. You have a highly corrosive coolant that explodes if it comes in contact with water and burns if it comes in contact with air. Pair that with a burnable moderator. Now imagine what a large-break LOCA looks like. I could only envision this being safe if it was built on the far side of the moon or something like that, a friendly place that's very cold by default and has no oxygen or water around. And all that money and brainpower is beng thrown down the drain because lead-moderated, lead-cooled is Not Invented Here. EDIT: and by "here" I mean in the US. Here, have a peek at the near future. http://myrrha.sckcen.be/ |
| Nov17-11, 06:38 AM | #73 |
This is not correct. Liquid fluoride salts are essentially inert in air. I worked with them. There is not enough reactivity in oxygen or nitrogen to displace the fluorine from the salt. There is perhaps confusion between liquid fluoride salt cooling and sodium cooling. The latter does indeed tend to explode on contact with water and does burn or at least oxidize very rapidly, with lots of heat, on contact with air, but molten fluorine salts don't. Separately, the Soviets did deploy lead bismuth cooled reactors on a nuclear submarines, but found them to be a maintenance headache. |
| Nov17-11, 07:33 AM | #74 |
| Nov17-11, 08:35 AM | #75 |
Uranium tetrafluoride is indeed nasty stuff, unlike the more stable fluoride salts I've had dealings with. |
| Nov17-11, 10:28 AM | #76 |
Though UF4 is toxic, neither the molten salt proposed for the reactor or UF4 alone is explosive in contact with air or water.
http://ibilabs.com/UF4-MSDS.htm |
| Nov17-11, 10:30 AM | #77 |
| Nov18-11, 02:52 AM | #78 |
In designs where fuel circulates through channels dug in the moderator, it's "a bit" more complicated. I don't think graphite would be used, pyrolitic carbon more likely, ideally coated in something that is less porous (although it may get electroplated all by itself, I don't know). |
| Nov18-11, 06:25 AM | #79 |
Admin
| Nov18-11, 08:53 AM | #80 |
| Nov18-11, 10:11 AM | #81 |
| Feb26-12, 08:31 AM | #82 |
Looking at ORNL's report (By L.G. Alexander), though, they are currently steering toward a system where the moderator is separate from the salt; this, of course, is a poor choice. If one uses MgF2 salt as the moderator (about on par with water in moderation) one could do a wholly homogeneous reactor. To breed, per Lietzke & Stoughton 1957, atom ratios of 17 Mg per Th and 105 F per Th (inclusive) would be needed. This would be a molar ratio of 12.3 MgF2 to 1 UF4. The scalability issue is that any molten fuel means you are pumping subcritical fissile fuel through your heat exchangers. But if you want to design for higher power, you need larger heat exchangers. The size of each heat exchanger is limited by the need to remain highly subcritical even at your expected highest breeding level. Similarly for pipe size. So, I would imagine a gigawatt range LFTR to have a large number of ~30 cm pipes going to rather small heat exchangers (once-through would be fine, since you don't need to worry about the possibility of over-heating the primary loop). Whether you use the heat exchangers as a NSSS or a brayton cycle heater is immaterial (although a closed Brayton is a definite necessity, there will be fission occurring in all the piping for the molten salt, and thus activation of everything within about a foot of the fluid). |
| Feb26-12, 11:07 AM | #83 |
Does the LFTR stability depend on the size of the fuel pool?
It seems logical that a gigawatt unit would be swimming pool sized, so the temperature and the concentration of the fuel might vary materially depending on where in the pool the measurements are taken, even if the fuel is getting pumped past heat exchangers. That seems difficult to control accurately. Is this a concern? More generally, it is clear after Fukushima that simply meeting a 'design basis' spec is not enough, it is important to have a sense of the possible consequences for a beyond spec accident. In the case of the various national breeder programs, the accidents that discouraged their proponents were fortunately not catastrophic. The LFTR proponents would enhance their case if they would subject their designs to very critical scrutiny, so that the public gets confidence that hostile eyes have not found cause for alarm. |
| Feb27-12, 07:30 AM | #84 |
| Feb27-12, 08:05 AM | #85 |
Is it possible to expand on this issue a bit more? It seems, afaik, a large pool of a 1000*C mixture of thorium fluoride, with substantial amounts of uranium and other transmutation products, where reaction speeds are muted if the temperature rises too much. Clearly drain plugs are not going to work fast, so preventing excursions, a core requirement, must rely on the thermal effects on reaction rates. How well proven is that for a range of radionucleide mixtures? Is there a risk of the salt getting vaporized in an excursion? |
| New Reply |
| Thread Tools | |
Similar Threads for: Liquid Fluoride Thorium Reactor
| Thread | Forum | Replies | ||
| Chlorine and fluoride filters | Product Claims | 2 | ||
| Polyvinylidene Fluoride (PVDF) | Chemistry | 1 | ||
| Liquid-fuel molten salt reactor? | Nuclear Engineering | 4 | ||
| Thorium Reactor | Nuclear Engineering | 3 | ||
| Fluoride in drinking water | General Discussion | 14 | ||
