| New Reply |
Finding the Relationship between the Limit Method and Direct Integral Method for Area |
Share Thread | Thread Tools |
| Nov30-11, 09:36 PM | #1 |
1. The problem statement, all variables and given/known data
I am in the process of studying integration and finding the areas under curves. So far, I know of two methods of finding the area under a curve: the limit method and the direct integral method. Could someone explain the relationship between these two methods? 2. Relevant equations [itex]\int[/itex]f(x) dx = F(x)|[itex]^{b}_{a}[/itex] = F(b) - F(a) = Area [itex]lim_{n→∞}[/itex] [itex]\sum^{n}_{i = 1}[/itex] [itex]f(x_{i})[/itex]Δx = Area 3. The attempt at a solution I noticed in the direct integration method for finding the area under a curve that the area under the curve is equal to the change in y of a more complicated function: the integral. I graphed it out on my calculator and I don't see exactly how this works. [itex]lim_{n→∞}[/itex] [itex]\sum^{n}_{i = 1}[/itex] [itex]f(x_{i})[/itex]Δx = Δy of F(x) = Area I'm trying to seek an explanation as to why the limit method yields the same result as the direct integral method. |
| Nov30-11, 10:13 PM | #2 |
That is the fundamental theorem of calculus. You might start by reading here:
http://en.wikipedia.org/wiki/Fundame...em_of_calculus |
| Dec3-11, 03:08 AM | #3 |
F(x) = [itex]\int^{x}_{a}f(t) dt[/itex] I've just never seen an antiderivative represented in this way before. Could you interpret this for me? Why does an antiderivative have an upper and lower bound? |
| Dec3-11, 12:07 PM | #4 |
Finding the Relationship between the Limit Method and Direct Integral Method for AreaNow the x in that definite integral is a dummy variable, not affecting the answer, so that line could as well have been written[tex]\int_a^b f(t)\,dt = F(t)|_a^b = F(b) - F(a)[/tex] Since this is true for any a and b, let's choose to let b be a variable x:[tex]\int_a^x f(t)\,dt = F(t)|_a^x = F(x) - F(a)[/tex] Since these are equal you still have F'(x) = f(x) so the left side is an antiderivative of f(x). Since a can be anything, the F(a) is like the constant of integration in our first equation. Does that help answer your question? |
| Dec3-11, 12:16 PM | #5 |
| Dec3-11, 12:32 PM | #6 |
| Dec3-11, 01:00 PM | #7 |
If f(0) = 4, then shouldn't f(x) - f(0) = [itex]\frac{x^{3}}{3}[/itex] - 4?
| Dec3-11, 01:44 PM | #8 |
| New Reply |
| Tags |
| area, curve, direct integral, limit |
| Thread Tools | |
Similar Threads for: Finding the Relationship between the Limit Method and Direct Integral Method for Area
| Thread | Forum | Replies | ||
| Prove that F satisfies all field axioms by method of direct verification | Calculus & Beyond Homework | 4 | ||
| Direct Integration Method for Deflection | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Newmark's method of direct integration | Mechanical Engineering | 0 | ||
| Direct Stiffness Method 2D Frame | Linear & Abstract Algebra | 0 | ||
| washer method and disc method for finding volumes of graphs | Calculus | 5 | ||
