Uniform Solid Sphere Moment of Inertia Calculation
The discussion revolves around calculating the moment of inertia of a uniform solid sphere with mass \( m \) and radius \( a \) about an axis through its center. The original poster presents their attempt at the calculation, expressing confusion over arriving at an incorrect result compared to the known correct answer.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to derive the moment of inertia using volume elements and integrals but expresses uncertainty about their calculations. Some participants question the mixing of variables and suggest reconsidering the choice of volume elements. Others introduce the use of cylindrical coordinates as an alternative approach.
The discussion is active, with participants providing different perspectives on the problem. Some guidance has been offered regarding the choice of volume elements, and there is an exploration of different methods to approach the calculation. However, there is no explicit consensus on the best method yet.
Participants are navigating the complexities of integrating over different coordinate systems and the implications of their choices on the moment of inertia calculation. The original poster's confusion about the volume element and the axis of rotation is a focal point of the discussion.
Mirumbe
Find the moment of inertia of a uniform solid sphere of mass,m and radius,a about an axis through its centre.
I have tried to solve it but I get the different answer, I don't know where I have done mistake. Please! check and correct my solution below:-
Consider a volume element, dv of the sphere; this has mass,mdv/(4/3)∏a^3.
Then
I = ∫(mdv/(4/3)∏a^3)r^2
Where r is the distance of the volume element, dv from the axis, and
I is the moment of inertia
I = m/(4/3)∏a^3∫r^2dv
We know, the volume of the sphere,v is:
v = (4/3)∏r^3
dv = 4∏r^2dr
Thus,
I = 3m/(4/3)∏a^3∫r^2(4∏r^2)dr
= 3m/a^3∫r^4dr under limit [0,a]
= 3m/a^3[r^5/5] under [o,a]
Hence,
I = (3/5)ma^2 --------------WRONG!
The correct answer is: I = (2/5)mr^2
For starters you seem to mixing r and a.
Here r is the distance to the axis.
v = (4/3)∏r^3
dv = 4∏r^2dr
Here r is the distance to the center.
My intention was to find the volume element, dv of the sphere about the axis. But, since the axis was through its centre that's why I said
v = (4/3)∏r^3
Then, after differentiating w.r.t variable, I got the volume element, dv
dv = 4∏r^2dr
So, if I am wrong here,what should I do, so as to get the volume element,dv?
I'd use cylinder coordinates [itex]\rho,\varphi,z[/itex]. The sphere is given by [itex]\rho \in [0,R][/itex], [itex]\varphi \in [0,2 \pi[[/itex], and [itex]z \in [-\sqrt{R^2-\rho^2},+\sqrt{R^2-\rho^2}[/itex]. Let [itex]n=\text{\const}[/itex] be the mass density. Then the moment of inertia is
[tex]\Theta=n \int_0^{R} \mathrm{d} \rho \int_0^{2 \pi} \mathrm{d} \varphi \int_{-\sqrt{R^2-\rho^2}}^{\sqrt{R^2-\rho^2}} \mathrm{d} z \; \rho^3.[/tex]
There one factor of [itex]\rho[/itex] comes from the volume element [itex]\mathrm{d}^3 x=\rho \mathrm{d} \rho \mathrm{d} \varphi \mathrm{d} z[/itex].
The integrals over [itex]z[/itex] and [itex]\varphi[/itex] are trivial. You find
[tex]\Theta=4 \pi n \int_0^R \mathrm{d} \rho \; \rho^3 \sqrt{R-\rho^2}.[/tex]
This remaining integral becomes
[tex]\Theta=\frac{8 \Pi}{15} n R^5 = \frac{8 \pi}{15} \frac{3m}{4 \pi R^3} R^5=\frac{2}{5} m R^2.[/tex]
Thanks Vanhee71 for your solution although it is the new idea to me.
Unfortunately, vanhees71 just did the problem for you which deprives you of figuring it out on your own.
The key point is to choose a volume element for which you can easily write down the moment of inertia. You chose spherical shells. (And in the process, mixed up the radius of those shells with the distance of a mass element to the axis of rotation.) You could do the problem that way, but you'd have to know the moment of inertia of a spherical shell. The better way is use cylindrical shells, which are easy. What's the moment of inertia of a cylindrical shell?
The moment of inertia of the Cylindrical shell is:
I = MR^2
  • · Replies 17 ·
  • · Replies 97 ·
