| New Reply |
Automotive Differentials |
Share Thread | Thread Tools |
| Dec31-11, 10:56 AM | #1 |
Folks,
Is it true to say for standard "open" differentials that when a car is turning a corner that the torque is equal on both wheels but the power will be different based on the expression P=TW, assuming that there is sufficient traction for all wheels, ie no slip? thanks |
| Dec31-11, 08:59 PM | #2 |
Yes; because of the way open diffs are constructed, the torque to each wheel will always be the same, and because of the difference in distanced traveled by each wheel, the power delivered will be different.
This also applies to slip conditions. |
| Jan3-12, 05:09 AM | #3 |
| Jan3-12, 10:20 AM | #4 |
Torque biasing is kind of misleading when used to describe how a limited slip or locked diff works; that implies an active control of the torque according to the traction available when in actuality it is a wheel speed control.
All the LSD does is keep the wheel with no traction from moving faster than the one with traction by locking them together either with a ratcheting or a friction-based (worm gear or clutch) system. That has the benefit of not reducing the torque being applied to the wheel with traction to equal that of the wheel with less traction, as happens with an open diff as we already agreed. Although some of the means of operation of the LSD can involve torque to actuate the locking mechanism, the main design objective is to keep both wheels rotating at the same speed. The different amount of torque being applied at the road surface is because of the differing traction available, not a torque biasing system per se. Electronic traction control systems apply the appropriate brake to slow a spinning wheel and again synchronize wheel speeds but the result is essentially the same. |
| Jan3-12, 12:59 PM | #5 |
You could argue that if a wheel is spinning that it has some torque and also some power and so its suffice to use either for descriptive purposes etc...? Whats your view? Thanks |
| Jan3-12, 02:15 PM | #6 |
Proper usage of terms is important when discussing things exactly; unfortunately that doesn't happen much outside of forums like this!
Without having an example of the verbiage being used and the context it's hard to say what the best terms to use are but I'm sure you've noticed that sales brochures are more about selling than telling! |
| Jan3-12, 04:15 PM | #7 |
One seldom mentioned effect of LSD (in rear wheel drive) is that understeer is generally promoted. This is good if the vehicle in question oversteers, but bad if it already understeers.
Respectfully submitted, Steve |
| Jan3-12, 05:07 PM | #8 |
I like to think of torque which provides the movement of a component while the definition of power I use to describe the time element in keeping a component moving at a certain speed. Just my 2 cents :-) |
| Jan3-12, 05:19 PM | #9 |
The extent to which the LSD locks the wheels together is a major factor in the wheels wanting to turn a corner. If the LSD is 100% locked up and the axle is effectively solid, the wheels will want to run straight ahead and resist turning.
Respectfully, Steve |
| Jan4-12, 06:59 AM | #10 |
Under what conditions do you want wheel speeds to be the same in a LSD..? |
| Jan4-12, 09:02 AM | #11 |
Here's an actual torque splitting/biasing differential: http://en.wikipedia.org/wiki/Torsen |
| Jan4-12, 03:40 PM | #12 |
thanks |
| Jan4-12, 08:30 PM | #13 |
Right; for that, an open diff is better. When cornering (once the corner is initiated), having the wheels locked can increase the likelihood of oversteer by forcing one wheel to slip, reducing the amount of lateral traction available as a result.
That's why the brake/traction control system has caught on, it emulates an LSD on demand but doesn't interfere with normal differential action when not needed. |
| Jan4-12, 08:38 PM | #14 |
I see most of the open diffs really just pushing the gears on the faster side of the axle.
If both are turning at the same speed, both sides are being propelled. If one side starts to go faster, say because you are going around a corner, or, one tire is on ice and the other on dry pavement, the faster tire is simply still the one being pushed, and the other side is coasting. If its a LSD, the two sides are held together, but the faster side is still being pushed and the slower side is still coasting if the break away torque setting is exceeded, allowing the two sides to go different speeds. (The two sides are both pushing until the difference between them exceeds the ability to hold them together, then it differentiates as normal.) If its a full locker, then the two sides can't differentiate even when the stresses build up....and the tires have to chirp or skitter around the turn on pavement, etc. There are other types, like a Torsen, etc...which have different means of proportioning the differentiation. I have a really old chevy video illustrating how an open diff works. I like the way it really simplified how the gears worked. http://www.youtube.com/watch?v=K4JhruinbWc :D |
| Jan4-12, 08:55 PM | #15 |
Not quite; in fact there is a small tendency to drive the slower tire more than the faster one because of the friction of the differential gears themselves, but I'm being pedantic.
![]() 1. An open diff drives both wheels all the time with the same torque whether in a straight line or cornering. Trying to accelerate with the inside tire on ice and the outside tire on pavement should prove to you that an open diff doesn't allow either tire to "coast". 2. An LSD typically uses clutch packs to resist different tire speeds with no preference to which tire is going slower or faster. Usually there is a break-away torque that is preset with spring pressure. Drive torque (stepping on the throttle) increases the break-away torque value by forcing the spider gears apart, putting more pressure on the clutch packs. 3. A Detroit style locker is the only diff that coasts or overruns on the inside tire. It has a ratcheting mechanism to allow that. 4. A spool is locked 100% of the time and is the one that causes the chirping. |
| Jan4-12, 09:07 PM | #16 |
What do you mean by them getting the same torque...if that means they are both spinning in the above scenario, its the opposite of what I see. 2. - Yup 3. - Yup 4. - Well, there are selectable lockers like air lockers, elockers, etc, that are like a spool when locked, and either open or like an LSD when not locked, depending on model. |
| Jan4-12, 09:12 PM | #17 |
| New Reply |
| Thread Tools | |
Similar Threads for: Automotive Differentials
| Thread | Forum | Replies | ||
| Differentials multiplied by differentials | Calculus & Beyond Homework | 3 | ||
| differentials, pseudo-differentials, and locality | Quantum Physics | 1 | ||
| Automotive Power | Introductory Physics Homework | 0 | ||
| Differentials under differentials in integrals | Calculus & Beyond Homework | 3 | ||
| confused about automotive differentials... | Automotive Engineering | 3 | ||
