| New Reply |
prove inequality |
Share Thread |
| Jan4-12, 01:05 PM | #1 |
prove inequality
I found this problem the other day, seems interesting but I am still not sure about the solution
Anybody can help x, y, z are numbers with x+y+z=1 and 0<x,y,z<1 prove that sqrt(xy/(z+xy))+sqrt(yz/(x+yz))+sqrt(xz/(y+xz))<=3/2 ("<=" means less or equal) |
| Jan4-12, 03:46 PM | #2 |
Recognitions:
I haven't worked it through. However, it looks like the max is assumed when x=y=z=1/3. In that case each term in the sum = 1/2.
| Jan4-12, 11:00 PM | #3 |
You are right I did that part already and think it's not enough
| Jan4-12, 11:18 PM | #4 |
Mentor
prove inequality |
| Jan4-12, 11:28 PM | #5 |
It should be proved for all other combinations of x,y and z.
Proving only for x,y and z equal 1/3 is incomplete |
| Jan4-12, 11:29 PM | #6 |
Mentor
| Jan5-12, 12:43 AM | #7 |
Devil's Advocate: ** You claim that the maximum is reached when x = y = z = 1/3, but it has not been shown by anyone in this thread that it is (or referenced to another place as already known to be). So . . . . . I am not convinced that the expression could not be greater than 3/2. mathman stated that "it looks like the max..." <---- Not concrete When JennyPA stated that she "did that part already" in response to mathman, she may have just referred to plugging in 1/3 for each variable to see that particular sum is 3/2 , but had no knowledge of whether that selection makes a maximum or not. |
| Jan5-12, 03:22 PM | #8 |
Recognitions:
I suggest that someone use some elementary calculus and see of the max is where it appears to be. To avoid partial derivatives, hold x constant and see if the max is at y=z. If that works, the rest should be easy enough.
| Jan5-12, 09:11 PM | #9 |
There was a previous discussion on this forum about this hypothesis:
If f(x,y,z) is continuous and symmetric, that is, f(x,y,z) = f(y,z,x) = f(z,x,y), then if that function has a global maximum at f(x*,y*,z*), then x*=y*=z* That discussion didn't include a proof of that, though. |
| Jan5-12, 10:18 PM | #10 |
| Jan5-12, 11:50 PM | #11 |
| Jan6-12, 09:02 AM | #12 |
Just a little algebra and the each term can eliminate a variable: xy/(z + xy) = xy/[(1-x)(1-y)]
Likewise for the other 2 terms. |
| Feb25-12, 06:58 PM | #13 |
| Feb25-12, 08:27 PM | #14 |
The best suggestion kind of got lost in the noise here. Take derivatives and use Lagrange multipliers/whatever calculus method you feel most comfortable with to find the maximum of the function
| Feb25-12, 08:45 PM | #15 |
| Feb25-12, 11:54 PM | #16 |
xy/[(1-x)(1-y)] when you eliminate z, then this expression is always 1 when x+y = 1
| Feb26-12, 11:44 AM | #17 |
you can replace z with 1-x-y but can't see what you did |
| New Reply |
| Tags |
| inequalities, number theory, polynomial |
Similar discussions for: prove inequality
| Thread | Forum | Replies | ||
| Use Schwarz inequality to prove triangle inequality | Calculus & Beyond Homework | 3 | ||
| Prove Minkowski Inequality using Cauchy-Schwartz Inequality | Linear & Abstract Algebra | 3 | ||
| prove an inequality | Calculus & Beyond Homework | 4 | ||
| Trying to prove an inequality | Calculus & Beyond Homework | 5 | ||
| how would you prove this little inequality? | Calculus | 5 | ||
