Is There a One-to-One Correspondence Between (0,1) and the Real Line?
  • Thread starter Thread starter cragar
    Interval
The discussion revolves around the relationship between the interval (0,1) and the real line, specifically exploring whether there exists a one-to-one correspondence between them. The subject area includes concepts from set theory and real analysis, particularly focusing on countability and uncountability.
  • Participants discuss various methods to establish a mapping from (0,1) to the real line, including the use of functions like tangent and transformations involving multiplication and shifting. Questions arise about the validity of these approaches and the nature of the mappings.
There is an active exploration of potential functions that could establish the desired correspondence. Some participants provide suggestions and corrections regarding the proposed mappings, indicating a collaborative effort to refine the approach. The discussion is ongoing, with no explicit consensus reached yet.
Participants are working within the constraints of homework guidelines, which may limit the types of solutions or methods they can use. The discussion also reflects a need to clarify definitions and assumptions related to the mappings and the properties of the intervals involved.
cragar
show that the interval (0,1) is uncountable iff [itex]\mathbb{R}[/itex]
is uncountable.
Can I take the interval (0,1) and multiply it by a large number and then a large number and eventually extend it to the whole real line. So now (0,1) can be mapped to the whole real line. Then can I use cantors diagonal argument to show that the real line is uncountable?
is uncountable.
They are probably just looking for a 1-1 function between (0,1) and the real line. 'multiply it by a large number' isn't going to get you there. Can't you think of any functions that map the real line to an open interval?
tan(x), will that work
tan(x) will map (-pi/2,pi/2) to R, right? Can you fix the function up so the interval is (0,1) instead of (-pi/2,pi/2)?
can i divide everything in the interval by pi and then shift it to the right by 1/2
You CAN do anything you want if it works. Try it and see. What's your answer for a function mapping (0,1) to R?
okay so [itex]tan(\pi(x-\frac{\pi}{2}))[/itex] should do the trick for the mapping.
at this point can I show the reals are uncountable.
Well, that's a 1-1 correspondence between (0,1) and R alright. Edit: Oh, wait. Don't you mean [itex]tan(\pi(x-\frac{1}{2}))[/itex]? Try the endpoints again.
ok you your right. so now that have a one-to-one correspondence between (0,1) and the real line.
If I show that the real line is uncountable using cantors diagonal arguement. will that complete the proof. Thanks for your help by the way.
  • · Replies 21 ·
