New Reply
AND gate
Share Thread Thread Tools
Feb3-12, 02:26 PM   #1
AND gate
Why is it required to have 6 transistors? Can it not have 4? Can the output not receive two LOW signals at once? Or does it have something to do with superposition such that upon adding the two signals it may enter the noise margin?
Here, I added a photo.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> NASA: Austin, calling Austin. 3-D pizzas to go
>> Research suggests modular design competence can benefit new product development
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
Feb3-12, 07:17 PM   #2
The circuit you've drawn in the bottom doesn't work. You can't use NMOS devices to pull up (and PMOS devices to pull down) in this way, because the devices will turn off before they pull up (or down) all of the way. Suppose your a and b are at Vdd. When those two NMOS devices try to pull up the output it will stop at <Vdd-2*Vt, because the NMOS devices turn off. In practice, what's called the body effect will make it even worse. If Vdd=5V, for example, the output probably won't pull up much past ~3V. Then if you feed this into the next gate of the system, the next NMOS devices have a lower voltage on their gates so the output pulls up less. Bottom line - it doesn't work this way.
New Reply
Thread Tools
Similar Threads for: AND gate
Thread Forum Replies
XOR gate to XNOR gate boolean algebra Engineering, Comp Sci, & Technology Homework 6
and gate Electrical Engineering 8
What happens when you place a NOT gate before and after a NAND gate Engineering, Comp Sci, & Technology Homework 11
Gate, jam,.... Omg! Academic Guidance 10
any gate i can substitute to xor gate? Computing & Technology 8
