New Reply
Constancy of c - second postulate
Share Thread
Feb5-12, 03:25 PM   #52
Quote by mangaroosh View Post
the Metre
How was the length of the path travelled by light in a vacuum measured, before the metre was defined in terms of the length of the path travlled by light in a vacuum?
the Second
The atomic clock used to register the oscillations of the caesium atoms e.g. the one in NIST, is that at rest relative to the earth, or in motion relative to it?
The original (and more pure or fundamental) definitions are the standard meter and kg as well as the solar day. For convenience (increased precision) impure (indirect) definitions are used nowadays. For theoretical discussions it is often better to stick to the pure definitions in order to avoid circular arguments as well as discrepancies with the definitions that were used for the formulation of the theory; however this should of course be clarified at the start.
Atomic clocks as used by NIST are at rest on the earth, and corrected for such things as altitude, pressure, temperature,...
Thanks to a lucky fact of the shape of the earth, it is not necessary to make a correction for the rotational speed: the clock slowdown due to rotation speed is compensated by the rate increase due to the higher potential from the bulging of the earth as a result of that same rotation.
Feb5-12, 06:06 PM   #53
Quote by DaleSpam View Post
The definitions of previous standards are not relevant to the definition of the current standard, except in terms of backwards compatibility. The current standard is not based on the earth centered frame.
They are relevant though if they form part of the basis for the new measurement; for example, the measurement of the path length of light in a vacuum first has to be measured using the existing standard.
Please cite your source. This is either a personal misunderstanding or a non-mainstream source.
If it is a misunderstanding, then it is a personal one. It could probably easily be cleared up though by asking if the clocks flown in planes in the Hafele-Keating experiment can be said to have measured the proper second. I presume the answer has to be no, because if they did they wouldn't have had net losses or gains.
Feb5-12, 07:09 PM   #54
Quote by harrylin View Post
The equations were not changed but generalised. Originally they were assumed to be valid relative to one inertial frame (retained with the second postulate), nowadays they are assumed (neglecting gravitation) to be valid relative to any inertial frame (the first postulate). Effectively that is what the combination of the two postulates means.
That's not so much to do with the equations themselves, but rather the interpretation of them isn't it? Isn't is possible that the measurements which lead to the derivation of the equations could carry certain tacit assumptions with them?
The combination of relativity of simultaneity + time dilation + Lorentz contraction assures that the same speed of light will be measured. The best way (probably the only way!) to fully understand that, is to do an example calculation yourself, for example with v=0.8c.
Is RoS a result of time dilation and Lorentz contractions?
Just on that point, and this is somewhere I might lack clarity, but if someone uses a slower clock and a smaller ruler (than similar instruments at rest on earth) and if they measure the speed of light to be 300,000 km/s with those instruments, would it not mean that the speed of light in both frames is actually different; because it would mean that the light in the reference frame moving relative to the earth actually took longer than a second to travel a distance shorter than 300,000 km?
That refers to the freely chosen simultaneity: when we set up a standard inertial reference system, we make the time for a light signal along that system in one direction equal to that in the opposite direction by means a convenient adjustment of clocks (clock synchronisation procedure).
What some textbooks mean with "the constancy of the speed of light" is not exactly the second postulate. The confusion is due to such sloppy textbooks. A few years ago there was a physics paper (I think in the AJP) that did a futile(?) attempt to correct such misunderstandings... The second postulate of special relativity is just what I cited: in a single inertial frame is the (operationally defined) speed of light in vacuum everywhere and in all directions the same constant.
The uni-directional speed of light is, essentially, an untestable assumption though isn't it? If it was abandoned, because it is untestable, and replaced with the notion that the round trip speed of light is the same for all observers,would that affect any of the conclusions drawn from experiments?
What you are missing - probably because the book you read forgot to mention it - is that the Fizeau experiments supports the fact that the speed of light is incompatible with ballistic light models. Michelson and Morley also repeated that experiment. Thus they assumed it to be a proven fact that light propagates as a wave with speed of propagation c according to Maxwell's model. Next they tried in vain to detect a small anisotropy of the two way speed of light in different directions at different times of the year.
- http://en.wikisource.org/wiki/Influe...ocity_of_Light
- http://en.wikisource.org/wiki/On_the...niferous_Ether
I came across this abstract when looking up the Fizeau experiment, but unfortunately I can't find the full paper [without having to pay for it]:
The motivation and interpretation of the Fizeau experiment are reviewed, and its status as a test of special relativity is discussed. It is shown, with the aid of a simplified, purely mechanical, model of the propagation of light in matter, that the experiment actually cannot discriminate between Galilean and relativistic kinematics.
American Journal of physics
Are you familiar with the paper by any chance?
Feb5-12, 07:15 PM   #55
When you say the pure definitions, do you mean things like the metre being defined in terms of the meridian (was it?) of the earth?
It seems, although not expressly stated, that measurements expressed in those units tacitly assume the earth centred reference frame as the rest frame; as you mention atomic clocks are at rest on earth, and the "pure" definitions would have been relative to the earth centred rest frame too.
Feb5-12, 07:54 PM   #56
Mentor
No, it doesn't. The current standard stands on its own. There is no need to do any measurements using previous standards in order to implement the current standard.
The correct answer is "yes, the clocks flown in planes in the Hafele-Keating experiment measured proper seconds". Proper time is defined as the time measured by a clock, and identified with the spacetime interval in both special and general relativity. It has nothing to do with the Earth centered reference frame, except coincidentally for clocks which happen to be at rest in the Earth centered reference frame.
Feb5-12, 07:59 PM   #57
Mentor
What you say would be correct except that you are forgetting the relativity of simultaneity. The Lorentz transform is not just length contraction and time dilation, but it also includes the relativity of simultaneity. You cannot just ignore it and get correct conclusions.
Feb5-12, 08:21 PM   #58
The previous standard, however, forms the basis for the current standard. Again, the path length of light in a vacuum had to be measured using the existing standard, before the path length of light in a vacuum could be used as the standard. This would be so right the way back the line, and so the implications would be the same.
The seconds measured by the clocks in the Hafele-Keating experiment did not measure seconds equal to that of the clock at rest on earth, so both cannot be said to have measured proper seconds, because that would mean that proper seconds are different in each reference frame. That would infer that a measurement of 300,000 km/s in one reference frame is materially different to that in another.
Forgive me for copying and pasting someone else's response [on another forum] to this point; I'd effectively just be saying the same thing anyway - the emphases are the other persons.
ROS is a subsidiary shorthand way of using distance contraction and time dilation and is not a separate stand-alone component of SR. ROS is a SUBSTITUTE for distance contraction and/or time dilation. It is NOT an additional function.
Feb5-12, 09:11 PM   #59
Mentor
This is not true. By historical accident the previous standard was measured before the current standard was, but there is no reason that it had to have happened that way. Back in Romer's day, in 1676, long before the BIPM ever made the first meter standard, someone could have defined a unit of length based on the distance light travels in 1/299792458 second and named it the meter.
Proper time is frame invariant but path dependent. The different clocks in the HK experiment measured different amounts of proper time because they took different paths. See: http://en.wikipedia.org/wiki/Proper_time
Please read the wikipedia article to begin. It is clear that you have some misunderstanding of what proper time is, and it is one of the most important concepts of relativity. If you have any questions, I would be glad to clarify.
Completely incorrect. I can easily come up with a coordinate transformation which has length contraction and time dilation, but not relativity of simultaneity. Likewise, I can easily come up a coordinate transform which does not have length contraction nor time dilation but does have the relativity of simultaneity.
They are three separate features of the Lorentz transform, and all three are required. You cannot simply use length contraction and time dilation and assume that relativity of simultaneity is somehow autmoatically included.
Feb6-12, 03:35 AM   #60
That's always possible; however both postulates were based on a long history of measurements and successful theories that were based on each.
In a certain way, but it's also the result of a human choice. Thanks to time dilation and Lorentz contraction the PoR applies to all laws of nature; consequently no absolute simultaneity can be established. Thus we can freely choose to make a relativity of simultaneity, as is the custom. Alternatively one could define for example the centre of the universe as in rest, and synchronize our clocks accordingly.
You forgot the RoS, and according to the PoR we can't determine what is actually true for such cases. Instead, we can only operationally define such things as "speed of light" without any metaphysical meaning as to what "really" occurs. That is the basic message of the introduction of Einstein's 1905 paper.
However, necessarily the velocity of a light ray relative to both frames as measured with an independent reference system is indeed different. As a matter of fact, that velocity (also called "closing velocity" in modern jargon) is equal to the vector subtraction (c-v).
That would change nothing as you can easily understand by you re-reading my 1907 citation of the second postulate.
Effectively Einstein assumed that when setting up a reference system we can make the one-way speed equal to the round trip speed which is postulated (as a law of physics) to be constant (everywhere and in all directions, independent of the motion of the source); and we postulate also that all laws of physics must be valid for all inertial reference systems. Combining those two postulates, we find that the round trip speed must be the same constant in all inertial reference systems, and we can make the one-way speed equal to the measured two-way speed by convenient clock synchronization. That is important to keep the laws of physics free from unnecessary complexity.
Sorry no, but it's likely irrelevant: it is well known that such tests are too imprecise to distinguish between the Galilean transformation and the Lorentz transformation. Much more relevant are the introductions of the papers to which I gave you the links and which explain why ballistic light theory was disproved before the end of the 19th century.
Feb6-12, 04:09 AM   #61
With "pure" I simply meant a definition that is not derived from other definitions by means of assumptions - for example the standard kg in Paris I call "pure". However, it is not at rest in the ECI frame; for that you would have to measure something at for example the North Pole.
Feb14-12, 01:44 AM   #62
@George - just wondering if you had a chance to read this post by any chance; I had a few questions on the analogy you used.
It's not so much concern that measurements of the speed of light don't use "the [official] second", I'm just wondering if the Maxwell's equations implicitly state that the speed of light is relative to a clock at rest on earth.
Because, a sundial is effectively just a means of breaking the daylight period into smaller segments; it effectively just breaks the "arc" of the sun, over a particular location on earth, into hours and minutes, doesn't it? So any measurement, expressed in the units measured by a sundial, could be read as a function of the movement of the sun relative to a an object at rest on earth. If that object were in motion relative to the earth, then the units would be different. The same could be said for measurements expressed in the units measured by observatories plotting the apparent motion of the fixed stars. Equally so, for an atomic clock at rest on earth, but perhaps even a more precise expression of it's location may be necessary.
Thanks, I think this analogy might be helpful.
This is more for myself, but I think we can imagine a plane shaped like a plus sign; such that, if the RC planes were both to start from the tail of the plane, and one of the planes turned at the intersection where the wings are, flew out to the end of the wing and then flew the distance to the end of the opposite wing, it would fly the same distance as the other RC plane flying out to the nose of the plane, returning to the midsection turning, and flying to the end of the same wing as the other RC plane; where the the detector determines if they arrived at the same time.
Staying with that analogy; what if the RC planes were of such a design (let's say they are made of massless particles) that there would be no wind resistance, they wouldn't need to assume that the plane's length had shortened, would they?
Also, if the length of time it took, for both RC planes to complete their respective trips, wasn't actually measured, rather the simple observation of whether they arrived simultaneously, or not was used; could they then conclude, when the planes arrive simultaneously, that someone on the ground would measure the speed of the RC planes to be the same as that measured by a person on the plane?
I replied to the part above before [re-]reading this part, so take no notice of the repetition; if the RC planes were designed [from massless particles, say] such that wind resistance wasn't a factor.
I try not to learn about relativity from someone who finds fault with Einstein, I generally try to learn about it from people like yourself - who are generous enough to take the time to answer posts; but I try not to accept things simply on the basis that someone says such and such is the case.
With regard to the MMX, I think what the author suggests is effectively a ballistic-like (not necessarily a ballistic) explanation for the MMX results; namely that the wavelength of the light reflected from the mirrors [in the interferometer] is the same, and so, no fringe shift would be expected.
But that would be circular reasoning wouldn't it, because both clocks use light; if he were to use a very precise mechanical clock, say, even though the light was traveling at speed c, he would measure a slower speed in his reference frame, with the other clock, wouldn't he; is that how experiments would measure the speed of light?
That is one thing that I have trouble getting my head around as well, because it seems that according to relativity that both observers can assume that they are at rest in the one and only ether frame; it does seem like both observers are treated as being at absolute rest, from their own perspectives.
Feb14-12, 03:51 PM   #63
Recognitions:
Gold Membership Gold Member
Yes, I read your post and was impressed by your level of understanding. I've said before, you seem to understand a lot about relativity. Am I right?
Feb14-12, 06:52 PM   #64
Quote by ghwellsjr View Post
Thanks George, I think I've got a half decent understanding of certain concepts, but obviously far from a full understanding. Based on that understanding though, Einsteinian relativity doesn't seem to sit well with me, so I'm hoping that through discussing it in depth I'll either confirm my bias or resolve those issues.
Just referring back to the RC plane analogy, with the planes that don't experience wind resistance, if the RC planes making their journey across the "big" plane in flight were to arrive simultaneously at the detector, I don't think we would conclude that length contraction and/or time dilation occurred, would we?
Also could we conclude that a person on the ground would measure the same speed of the planes as the RC operators? I think based on our previous discussions, that we couldn't; I'm just trying to figure out, what a reasonable conclusion would be from that scenario?
Also, just wondering if you had any thoughts on the issue of the moving observer measuring the speed of light; we mentioned that he would measure the speed to be c if he used a light clock, but if he were to use a mechanical clock, for example, an infinitely precise pendulum clock, then he would measure a speed different to c. I'm wondering if there are any issues that mean we couldn't use such an idealised pendulum clock? Is the fact that it wouldn't work in an inertial reference frame in deep space sufficient reason to exclude it?
Also, just on the point of being at absolute rest in the ether frame, this is something which also doesn't sit too well with me; I often hear that Lorentzian relativity contains the superfluous assumption of an undetectable, absolute rest frame, but Einsteinian relativity seems to include the assumption that reference frames are at rest in that rest frame, which doesn't seem to be any less of an assumption - to my mind it seems more objectionable.
Feb15-12, 12:25 AM   #65
Recognitions:
Planes that don't experience wind resistance are not a part of my analogy and you shouldn't be introducing them into the discussion.
I covered the situation where the measurement was made while stationary on the ground. You shouldn't be asking about this again.
It's not just in deep space but at different altitudes on earth. Note 7 of Einstein's 1905 paper says:
Not a pendulum-clock, which is physically a system to which the Earth belongs. This case had to be excluded.
You shouldn't be bringing this up. Isn't it obvious that if you want to use a mechanical clock, it must be one that is not going to be influenced by environmental factors? You could use a mechanical clock that has a balance wheel in it, the type that Einstein says to use.
Why do you object to any assumption that doesn't conflict with experimental evidence? You are free to adopt ether Lorentzian relativity or Einsteinian relativity (or both) since they both comport with reality identically (they both stand or fall together) but to argue that one should be excluded because it "doesn't sit too well with me" or because "to my mind it seems more objectionable" is the height of arrogance.
Feb15-12, 01:02 AM   #66
Apologies, I was trying to get a better understanding of the MMX without the notion of an ether wind.
Apologies, I thought they were different questions
In the scenario of the moving train, where the slower relative [to the train carriage] speed of light would be offset by the slower ticking light clock, would the use of such a mechanical clock to measure the speed of light lead to the observer measuring a slower speed.
I don't think it's a matter of arrogance, rather a matter of reason.
The objection to Lorentzian relativity, that usually seems to get cited as the reason for preferring Einsteinian relativity, is the fact that it doesn't have the undetectable, absolute rest frame; while Einsteinian relativity appears to treat each reference frames as though they are that absolute rest frame - that doesn't appear to be too different from my own reasoning.
However, that I find it more objectionable is not necessarily a conscientious preference for one over the other, rather that from trying to develop an understanding of both theories, the process of assimiltation of information has lead, for some reason, to Einsteinian relativity not sitting well; that could be, in part, due to the reasons that are given for preferring Einsteinian relativity over Lorentzian.
EDIT: also possibly because it seems like the superfluous assumption [of an absolute rest frame] that seems to make Lorentzian relativity less attractive, could probably be done away with, within the context of Lorentzian relativity.
Feb15-12, 02:44 AM   #67
Recognitions:
Now if that were the case, then there would be an experiment that would violate the Principle of Relativity in different Frames of Reference. You can rest assured that any type of accurate clock that isn't influence by environment factors will give identical results.
It sounds like you don't like either one!!
You said earlier, "I think I've got a half decent understanding of certain concepts, but obviously far from a full understanding". Could you please itemize those concepts that you feel you half-way understand?
Feb15-12, 03:58 AM   #68
Is there an experiment which would reveal such a violation of the PoR, given that many such experiments don't actually measure the speed of light in terms of distance/time?
I try to picutre the MMX in such a scenario, but wonder if it would reveal that the light was traveling slower relative to the carriage, because the light would still be traveling at an actual speed of c.
sorry, I meant less attractive for proponents of Einsteinian relativity (to generalise and sterotype )
I haven't tried to itemise them before, so I'm not sure if I'll label them correctly. I suppose whatever concepts you reckoned I had a good understanding of; I'm not sure what the concepts are apart from some generic terms, because my understanding is based on discussions with those more knowledgeable, on the topic, than myself, and the specific concepts might not always be named, or I might not recognise them as specific concepts.
The obvious ones would be:
- Time dilation
- Length contraction
- RoS (although that might be disputable - my level of understanding that is)
- the constancy of the speed of light
- twin paradox
- reference frames
- clock synchronisation
- Principle of Relativity
- Equivalence principle
New Reply
Similar Threads for: Constancy of c - second postulate
Thread Forum Replies
Finding the converse of Euclid's fifth postulate (parallel postulate) Calculus & Beyond Homework 2
Is Euclid's Postulate 5 really a "postulate of parallels"? Differential Geometry 18
can SR be derived from other postulates than the constancy of c Special & General Relativity 6
Constancy of c Special & General Relativity 5
The search for constancy General Physics 3
