| New Reply |
Time delation or clock malfunction!! |
Share Thread | Thread Tools |
| Feb9-12, 05:48 AM | #1 |
Using an example of light clock, it shows light takes more time now to reflect between reflectors due to elongated path as to moving observer, so 1 sec gets elongated. But this could also mean that the clock malfunctions as compared to observer. I mean one second is one second, how it can change???? light now takes more time to complete its one cycle doesn't mean 1 sec gets elongated. It's just the clock which now takes more than one second to show one second increment to the observer. That means clock malfunctions for the moving observer but it can't elongate 1 sec. Why will biological processes get slower? So why will aging occur?
| Feb9-12, 05:58 AM | #2 |
No, there doesn't have to be any clock involved. If A is moving at a high speed relativer to B, then B will observe everything about A is slower. It is NOT the case that the clock has "malfunctioned".
| Feb9-12, 06:08 AM | #3 |
Perhaps you would still call that "clock malfunction", but as it is in the nature of the best clocks that we can make, few people would agree with calling it such. |
| Feb9-12, 07:46 AM | #4 |
R Power, if you have two clocks in relative motion, they each will observe the other one to be running slow, so how do you decide which one is malfunctioning?
| Feb9-12, 11:11 AM | #5 |
| Feb9-12, 11:32 AM | #6 |
| Feb9-12, 11:40 AM | #7 |
But for your question each clock measures one second correctly for its own observer but wrong for the other observer. |
| Feb9-12, 12:11 PM | #8 |
| Feb9-12, 12:33 PM | #9 |
So, now for both the clocks the other one is slow. What will happen in case these both clocks meet each other. Imagine the clocks reverse their path to meet each other.
| Feb9-12, 02:16 PM | #10 |
It depends on exactly what you have in mind. For example, if to begin with, both clocks passed each other so that they could set their clocks to the same time, and then some time later according to each clock, they both turned around in the same way and eventually met up again, then their clocks will display the same time when they pass each other the second time.
However, if only one of them turned around and headed back to the other one, then that clock will display an earlier time when they pass. |
| Feb9-12, 04:53 PM | #11 |
Mentor
| New Reply |
| Thread Tools | |
Similar Threads for: Time delation or clock malfunction!!
| Thread | Forum | Replies | ||
| Time dilation explaination with mechanical clock instead of light clock | Special & General Relativity | 55 | ||
| Time delation by distance!! | Special & General Relativity | 7 | ||
| time clock question | Special & General Relativity | 3 | ||
| An absolute time clock! | Special & General Relativity | 204 | ||
| How Does a Clock Measure Time? | Special & General Relativity | 4 | ||
