New Reply
Fortran Factorials
Share Thread Thread Tools
Feb9-12, 06:18 PM   #1
Fortran Factorials
I don't understand at all how you tell the computer to evaluate a complicated factorial expression such as the one given in in the infinite sum of binomial theorem as
Ʃ [n! / k!(n-k)! ] * x^k
where n is the final value of the sum and k is where you are in the loop.
It's supposed to be
INTEGER :: k, n
REAL :: sum, fact, x
ASK INPUT (what are x and n?)
DO k = 0,n
sum = sum + fact*x**k
fact = fact * (n-k)/(k+1)
END DO
Is there a procedure to figure out what the term multiplied by the fact variable should be?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Feb9-12, 07:32 PM   #2
Math 2012
Recognitions:
Look at what the term are summing, for each value of k.
When k = 0, it is n! / (0! n!) so k0 = 1
When k = 1, it is n! / (1! (n-1)! so k1 = n = k0 * n / 1
When k = 2, it is n! / (2! (n-2)! so k2 = n(n-1) / 2! = k1 * (n-1) / 2
When k = 3, it is n! / (3! (n-3)! so k3 = n(n-1)(n-2) / 3! = k2 * (n-2) / 3
etc.
That is what the program is doing when it updates "fact".
Feb9-12, 09:35 PM   #3
Hmmm... then fact * (n-k)/(k+1) can't be right because it doesn't match the results of working out all the factorials like that. I checked it in command prompt and it said the sum with x = 2 and n = 2 is 5. This sum represents (1+x)^n which should be 9 in that case.
I thought fact * ( (n-k+1) / k ) would work but I'm not getting the right answer with that either.
Feb9-12, 09:50 PM   #4
Fortran Factorials
disregard that. i worked it out on paper and i got 9 but for some reason the program is outputting 5...
If the k0,k1,k2 etc values are the "fact", how is (n-2)/3 = (n-k)/(k+1) for k = 3? That's why I thought it should be ( (n-k+1) / k ).
Feb10-12, 07:33 AM   #5
Math 2012
Recognitions:
Quote by Goatsenator View Post
The code calculates "k3" when k = 2, not when k = 3.
Each time through the loop, it uses the current value of fact, then calculates the next value.
Feb10-12, 10:30 AM   #6
Code:
	i=n
	fact=1
	sum=1
	DO k= 1,n
		f = f*i/k*x
		i = i-1
		s = s + f
	END DO
Feb10-12, 10:38 AM   #7
Quote by AlephZero View Post
OH! I just realized that! It's so simple now that I understand it. Thank you for the help!
New Reply
Thread Tools
Similar Threads for: Fortran Factorials
Thread Forum Replies
Fortran 77 help making an empty array (or blank list if they exist in fortran) Programming & Comp Sci 5
FORTRAN 95: New to fortran, want to learn how to input a function Programming & Comp Sci 1
Factorials Calculus & Beyond Homework 3
Accessing Fortran Modules within a Fortran library from Fortran Programming & Comp Sci 0
sum of the first n natural numbers is n(n+1)/2 General Math 2
