best book for learning latex
by nickadams
Tags: book, latex, learning
nickadams
nickadams is offline
#1
Feb20-12, 03:11 PM
P: 184
what is the best book for a complete beginner to learn latex? I have a little bit of coding experience in matlab from a 1 semester intro course but other than that I know nothing about programming.
I really want to learn latex though so I can take notes in math classes on my laptop
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
Greg Bernhardt
Greg Bernhardt is offline
#2
Feb20-12, 03:16 PM
Admin
Greg Bernhardt's Avatar
P: 8,531
This book is fairly recent and has good reviews
http://www.amazon.com/LaTeX-Companio...9772506&sr=8-3
espen180
espen180 is offline
#3
Feb20-12, 03:33 PM
P: 836
Taking notes on your laptop, and furthermore typesetting them in LaTeX in class is terribly inefficient and generally a bad idea. You'll spend more energy on the typesetting than absorbing the lecture content, and, depending on the lecture, you likely won't be able to keep up.
However, LaTeX is an extremely useful typesetting language when writing assignments, so I reccomend you learn it.
Fredrik
Fredrik is offline
#4
Feb20-12, 07:50 PM
Emeritus
Sci Advisor
PF Gold
Fredrik's Avatar
P: 8,989
I agree with espen. It's a bad idea. Just make notes with a pen and paper, and type them up afterwards if you think there's something there worth saving.
I don't think you need a book actually, but having one can't be a bad idea. The first thing you should do is to download some LaTeX software, create a document and start typing stuff into it. When there's something you don't know how to do, Google it.
Sankaku
Sankaku is offline
#5
Feb21-12, 12:47 AM
P: 714
There are many people (mostly grad students) who live-Tex their class notes. This is not an unreasonable thing to do if:
a) you are a very good typist
b) you are very fluent in Latex
Try doing your assignments in Latex first. I am pretty good at bashing out Latex, but would never do it in lectures, myself.
However, you can check out these tips if you are keen:
http://stacky.net/wiki/index.php?tit...al-time_TeXing
http://annoyingpi.wordpress.com/2010...ng-experiment/
There is also the first post in this thread:
http://mathoverflow.net/questions/12...lectures/12673
As for books, why bother? The net is full of Tex advice.
nickadams
#6
Feb21-12, 01:34 PM
P: 184
Quote Quote by Sankaku View Post
thanks for your response, and ya I think I will start out typing assignments or retyping my handwritten notes until I get up to a decent speed. From your posts it looks like you can have shortcuts (macros I think they called it?) for common symbols or whatever so I will have to look into that.
Sankaku
Sankaku is offline
#7
Feb22-12, 12:07 AM
P: 714
Quote Quote by nickadams View Post
Yes, you can define your own (shorter) commands for commonly used ones. That helps a lot, even for assignments. Having a good editor is important as well, since it should have built-in keyboard shortcuts for many things.
Try to build good typing habits. I never kept the discipline long enough and my speed plateaued because of poor form.
nickadams
#8
Feb22-12, 11:56 AM
P: 184
what editor do you recommend?
espen180
espen180 is offline
#9
Feb22-12, 05:02 PM
P: 836
I use LEd and Texmaker. Both work fine for me.
Fredrik
Fredrik is offline
#10
Feb22-12, 05:18 PM
Emeritus
Sci Advisor
PF Gold
Fredrik's Avatar
P: 8,989
I'm using LEd. I like it enough to not want to switch, but I've had some difficulties with it. I remember that when I first installed it, I had some issues getting everything to work, and when I tried to do it months later on another computer, I wasn't able to get the previewer to work. It also has a feature that can be really annoying. When I type stuff involving ^ and I do something wrong...I think it's when I hit the spacebar before releasing the ^ key, a large section of text is highlighted and then deleted when I press the next key. (Fortunately, there's an "undo" feature as well). Also annoying is that it doesn't save any configuration settings. If I want something changed, I have to change it every time.
There are other threads where LaTeX software is discussed, so you could try a search.
Sankaku
Sankaku is offline
#11
Feb23-12, 12:29 AM
P: 714
I use Kile (under Linux/KDE) with Okular as my viewer. I understand that Texmaker has a similar layout but is cross-platform. I have only poked at it for a few minutes, though.
Register to reply
Related Discussions
Learning Latex Code? Math & Science Software 8
Suggestion Inclusion of how to type inline expressions in LaTeX introductory learning material Forum Feedback & Announcements 3
When do you are finished with a book that you are learning Academic Guidance 1
Book for learning Maple Math & Science Software 0
