QED and the Landau Pole
by waterfall
Tags: landau, pole
waterfall
waterfall is offline
#1
Feb21-12, 06:01 PM
P: 381
According to Wiki:
"If a beta function is positive, the corresponding coupling increases with increasing energy. An example is quantum electrodynamics (QED), where one finds by using perturbation theory that the beta function is positive. In particular, at low energies, α ≈ 1/137, whereas at the scale of the Z boson, about 90 GeV, one measures α ≈ 1/127.
Moreover, the perturbative beta function tells us that the coupling continues to increase, and QED becomes strongly coupled at high energy. In fact the coupling apparently becomes infinite at some finite energy. This phenomenon was first noted by Lev Landau, and is called the Landau pole."
I understood the above since years ago that probing with high energy causes the coupling constant to be larger. But BHobba was claiming that "As the cutoff is made larger and larger the coupling constant gets larger and larger until in the limit it is infinite". He was saying that even at low energy, α ≈ 1/137 would become 1/127 if you increase the terms of the perturbation series. To put in mathematical form.
[tex]
\sum_{n=0}^\infty c_n g^n
[/tex] (where g is the coupling constant).
with one term
[tex]
\sum_{n=0}^\infty c_n (1/137)^n .
[/tex]
with two terms or three terms
[tex]
\sum_{n=0}^\infty c_n (1/15)^n .
[/tex]
with 1000 terms
[tex]
\sum_{n=0}^\infty c_n (1/0)^n .
[/tex]
The above is true even at low energy (before I thought it's only when the probing is high energy). Can anyone science advisor please confirm if this is true and the context of this? Note I'm talking about normal perturbation and let's not complicate things by including the Renormalization Group and the trick of regulator and stuff. Thanks.
Phys.Org News Partner Physics news on Phys.org
A 'quantum leap' in encryption technology
Using antineutrinos to monitor nuclear reactors
Bake your own droplet lens
strangerep
strangerep is offline
#2
Feb21-12, 06:47 PM
Sci Advisor
P: 1,732
Perturbation techniques can be notoriously tricky. There are other cases where the first few terms of the perturbation series give extremely close approximations to the exact solution, but then start to diverge wildly after that.
Vanadium 50
Vanadium 50 is offline
#3
Feb21-12, 08:38 PM
Mentor
Vanadium 50's Avatar
P: 15,630
You may have missed my message on another thread:
If you are just now studying Power Series, you are by my count about 23 courses prior to where renormalization will be discussed. I think you're going to have to accept that the answers you get will be kind of hand-wavy.
If you picked up a murder mystery, read a few pages, and then jumped to the end, you shouldn't be surprised if the killer's identity seems to make no sense.
waterfall
#4
Feb21-12, 08:49 PM
P: 381
Quote Quote by Vanadium 50 View Post
I have spent years reading about feynman diagrams and virtual particles and higher order virtual contributions (or more terms in the power series) so I'm familiar already with the landscape and a little tie-up or updates would make me see the wider vistas.
Right now. I'm taking a crash course in relativistic quantum field theory with aims at applications in quantum gravity and beyond..
Register to reply
Related Discussions
South Pole colder than the north pole. why ?????? Earth 27
North pole and south pole of a magnet. General Physics 10
2 pole 4 pole 8 pole motors General Engineering 4
landau pole Quantum Physics 3
Wire does a loop of wire create a norh pole and a south pole General Physics 2
