New Reply
velocity from acceleration if acceleration is a function of space...
Share Thread Thread Tools
Feb22-12, 03:26 PM   #1
Hello Forum,
usually the acceleration a is a function of time: a(t)= d v(t) /dt
to find v(t) se simply integrate v(t)= integral a(t) dt
What if the acceleration was a function of space, i.e. a(x)?
what would we get by doing integral a(x) dx? The velocity as a function of space, v(x)?
but a(x) is not defined to be v(x)/dx or is it? maybe some chain rule is involved..
thanks,
fisico30
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Feb22-12, 07:17 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by fisico30 View Post
What would we get by doing integral a(x) dx? ... chain rule ...
You use chain rule
a(x) = dv/dt = f(x)
multiply dv/dt by dx/dx:
(dv/dt)(dx/dx) = (dx/dt)(dv/dx) = v dv/dx = f(x)
multiply both sides by dx
v dv = f(x) dx
If f(x) can be integrated and the integral of f(x) = g(x), then
1/2 v2 = g(x) + c
This results in an equation that relates velocity and position.
v = sqrt(2 (g(x) + c))
To get time versus position, you start with
v = dx/dt = sqrt(2 (g(x) + c))
and then integrate
dx/(sqrt(2 (g(x) + c))) = dt
assuming h(x) is the integral of dx/(sqrt(2 (g(x) + c))), you get
t = h(x) + d
where d is constant of integration. It may be possible to solve this equation to get x = some function of t.
One simple case is a(x) = -x, which results in x(t) = e(sin(t+f)), where e and f are constants.
Feb23-12, 07:42 AM   #3
Thanks rgcldr!
great explanation and example!
fisico30
Mar2-12, 10:03 AM   #4
Hi rcgldr,
one question:
when you get v dv = f(x) dx, is v a function of t or of x, i.e. is v equal to v(t) or v(x)?
It looks like it would be a function of x, v(x), since 1/2 v^2 = g(x) + c results in v(x) = sqrt(2 (g(x) + c)).
I am confused because when we write v=dx/dt I always assume that v must be a function of time t, i.e. v(t).
When in your first step you write a(x) = dv/dt I tend to think that the v must be function of t since dv/dt is a derivative with respect to time.
So which one is correct? a(x)= dv(x)/dt or a(t)=dv(t)/dt. Acceleration is always the time derivative of the velocity vector but the velocity vector can be a function of any dependent variable: v(t), v(x), v(F), where F is force, etc....
Thanks,
fisico30
Mar2-12, 10:12 AM   #5
I guess my point is: if a function, like a, is defined as a time derivative of another function, dv/dt, does the differentiated function need to be a function if time?
Mar2-12, 11:03 AM   #6
Recognitions:
when you get v dv = f(x) dx, is v a function of t or of x, i.e. is v equal to v(t) or v(x)? It looks like it would be a function of x, v(x), since 1/2 v^2 = g(x) + c results in v(x) = sqrt(2 (g(x) + c)).
At this point, it's just a relationship betwen v and x.
It is, but I was only able to take advantage of that in the last step where I find t as a function of x.
True, but I used chain rule to get rid of the dt and end up with v dv = f(x) dx.
Both are correct, but if acceleration is defined as a function of x, then it may not be possible to find an equation for acceleration as a function of time. In the simple example I gave, a(x) = -x, you will be able to find both a(x) and a(t). I ended up finding x(t) = e sin(t + f). You can take the derivative of this to find v(t), and the derivative of v(t) to find a(t), so a(x) = -x, and a(t) = -e sin(t+f). For other situations, you may not be able to solve for x(t), v(t), or a(t), in which case numerical integration will be required.
Mar3-12, 08:03 AM   #7
So it is mathematically legal and ok to write a derivative of a function even if
the independent variable a of the function and the differentiation variable b are not the same: f(a) and db to create df(a)/db...
I guess that is all the chain rule is about....
New Reply
Thread Tools
Similar Threads for: velocity from acceleration if acceleration is a function of space...
Thread Forum Replies
Acceleration as a function of position, and velocity. Classical Physics 2
Acceleration as a function of velocity - HW problem help Introductory Physics Homework 6
Acceleration as a Function of Velocity Introductory Physics Homework 4
motion in space: velocity and acceleration Calculus & Beyond Homework 7
Acceleration when velocity is a function of distance Introductory Physics Homework 7
