| New Reply |
Density vs. Mass |
Share Thread | Thread Tools |
| Feb25-12, 05:15 PM | #1 |
Density vs. Mass
Does lower density usually mean the material is lighter? I went through high school believing that an object with a larger molar mass is a larger object. However, doesn't a larger density mean that material in use is heavier since it have a more compact lattice structure?
| Feb25-12, 06:54 PM | #2 |
Which is heavier, a penny (density = 9 g/cm^3) or a tank truck full of water (density = 1 g/cm^3)? Mass = density * volume, so the mass depends on the density and the size.
| Feb25-12, 07:02 PM | #3 |
Sorry I should have been more clear. If you have two different chemicals in the same volume with different densities then the one with the highest density will be heavier.
Thank you for your help. |
| Feb25-12, 07:17 PM | #4 |
Density vs. Mass |
| New Reply |
| Thread Tools | |
Similar Threads for: Density vs. Mass
| Thread | Forum | Replies | ||
| Mass density of stars from number density | Astrophysics | 0 | ||
| Weight Density and Mass Density | Introductory Physics Homework | 4 | ||
| calculating the redshift at which radiation energy density equaled mass density | Cosmology | 4 | ||
| Help with problem of Center of mass, linear mass density and total mass | Introductory Physics Homework | 1 | ||
| The density of Mass relative to a critical mass | Astrophysics | 1 | ||
