Register to reply
Does Le chatlier's law apply if reactants are liquids and a product is solid?
by kenshi64
Tags: apply, chatlier, liquids, product, reactants, solid
Share this thread:
kenshi64
#1
Feb27-12, 09:01 AM
P: 34
Hi So the reaction is below:
Sodium thiosulfate + HCl = Sulfur + NaCl+ Water+ SO2
So if I wanted to say 'Increasing the conc. of Sodium thiosulfate has shifted the equilibrium to the left (reactants) and thus the system works to break down excess reactants and create more product by Chatlier's law' Would this be factually right?
I'm wondering because the example equation on Wikipedia consists of all gases. Thanks in advance! Cheers! :D
Phys.Org News Partner Chemistry news on Phys.org
Mineral magic? Common mineral capable of making and breaking bonds
Seeing is bead-lieving: Scientists create model 'bead-spring' chains with tunable properties
New molecule puts scientists a step closer to understanding hydrogen storage
Borek
#2
Feb27-12, 09:17 AM
Admin
Borek's Avatar
P: 23,381
Amount of solid doesn't matter (that is, putting more solid into the system will no shift the equilibrium), but changing concentrations has similar effect to changing pressure.
kenshi64
#3
Feb27-12, 09:26 AM
P: 34
Quote Quote by Borek View Post
Sorry, before I go ahead, Is the reaction reversible? I seem to have made a stupid assumption that I can talk about the equilibrium shifting to remove excess reactants when it mayn't be a reversible reaction. How do I know if it is one? THanks Borek
Borek
#4
Feb27-12, 10:58 AM
Admin
Borek's Avatar
P: 23,381
To some extent every reaction is reversible. In this particular case reverse reaction is what is used to produce thiosulfates (although it is done in alkaline solutions).
kenshi64
#5
Feb27-12, 11:11 AM
P: 34
Oh god, alas, another experiment down the drain.. Thank you!
Nik_2213
#6
Feb27-12, 11:58 AM
P: 217
Uh, with the sulphur precipitating out as a colloid, the reaction is some-what reversible. Starting with lumps of sulphur is a different matter. You'd probably need an ultrasonic bath to mobilise the surface reaction...
kenshi64
#7
Feb27-12, 12:00 PM
P: 34
Quote Quote by Nik_2213 View Post
I appreciate that!, But unfortunately i'm just a 12th grader and I don't have that kind of stuff.
Register to reply
Related Discussions
Can the amount of product at a given time be calculated with multiple reactants? Chemistry 1
Reactants of Photosynthesis & Respiration (as well as the product) Biology, Chemistry & Other Homework 7
Stoichiometry - Reactants & Product Masses... Biology, Chemistry & Other Homework 8
Finding the volume of a unknown submerged solid, given the denseties of 2 liquids Introductory Physics Homework 1
Apply kinetic theory to solids and liquids? Classical Physics 2
