| New Reply |
Does Le chatlier's law apply if reactants are liquids and a product is solid? |
Share Thread | Thread Tools |
| Feb27-12, 09:01 AM | #1 |
Hi So the reaction is below:
Sodium thiosulfate + HCl = Sulfur + NaCl+ Water+ SO2 So if I wanted to say 'Increasing the conc. of Sodium thiosulfate has shifted the equilibrium to the left (reactants) and thus the system works to break down excess reactants and create more product by Chatlier's law' Would this be factually right? I'm wondering because the example equation on Wikipedia consists of all gases. Thanks in advance! Cheers! :D |
| Feb27-12, 09:17 AM | #2 |
Admin
Amount of solid doesn't matter (that is, putting more solid into the system will no shift the equilibrium), but changing concentrations has similar effect to changing pressure.
| Feb27-12, 09:26 AM | #3 |
| Feb27-12, 10:58 AM | #4 |
Admin
To some extent every reaction is reversible. In this particular case reverse reaction is what is used to produce thiosulfates (although it is done in alkaline solutions).
| Feb27-12, 11:11 AM | #5 |
Oh god, alas, another experiment down the drain.. Thank you!
| Feb27-12, 11:58 AM | #6 |
Uh, with the sulphur precipitating out as a colloid, the reaction is some-what reversible. Starting with lumps of sulphur is a different matter. You'd probably need an ultrasonic bath to mobilise the surface reaction...
| Feb27-12, 12:00 PM | #7 |
| New Reply |
| Thread Tools | |
Similar Threads for: Does Le chatlier's law apply if reactants are liquids and a product is solid?
| Thread | Forum | Replies | ||
| Can the amount of product at a given time be calculated with multiple reactants? | Chemistry | 1 | ||
| Reactants of Photosynthesis & Respiration (as well as the product) | Biology, Chemistry & Other Homework | 7 | ||
| Stoichiometry - Reactants & Product Masses... | Biology, Chemistry & Other Homework | 8 | ||
| Finding the volume of a unknown submerged solid, given the denseties of 2 liquids | Introductory Physics Homework | 1 | ||
| Apply kinetic theory to solids and liquids? | Classical Physics | 2 | ||
