New Reply
Torque on the Accretion disc
Share Thread
Feb27-12, 03:57 PM   #1
http://www.maths.qmul.ac.uk/~rpn/ASTM735/lecture3.pdf
The diagram on page 26 is the accretion disc.
The torque acting on the inner edge of the ring (the one that has a thickness of dR in the diagram) is
RFin = -2[itex]\pi[/itex]R3[itex]\nu[/itex]Ʃ[itex]\frac{dΩ}{dR}[/itex]
The torque acting on the outer edge of the ring is
RFout = [2[itex]\pi[/itex]R3[itex]\nu[/itex]Ʃ[itex]\frac{dΩ}{dR}[/itex]]R+dR
I would think that the net torque acting would be
T = [2[itex]\pi[/itex]R3[itex]\nu[/itex]Ʃ[itex]\frac{dΩ}{dR}[/itex]]R+dR - [2[itex]\pi[/itex]R3[itex]\nu[/itex]Ʃ[itex]\frac{dΩ}{dR}[/itex]]R
= [2[itex]\pi[/itex]R3[itex]\nu[/itex]Ʃ[itex]\frac{dΩ}{dR}[/itex]]dR
but according to equation (66) on page 27 of http://www.maths.qmul.ac.uk/~rpn/ASTM735/lecture3.pdf, the net torque is
[itex]\frac{∂}{∂R}[/itex][2[itex]\pi[/itex]R3[itex]\nu[/itex]Ʃ[itex]\frac{dΩ}{dR}[/itex]]dR
Does anyone know why [itex]\frac{∂}{∂R}[/itex] is included in the expression?
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Feb27-12, 07:00 PM   #2
Assume you take the limit that [itex] dR \rightarrow 0[/itex] then that is the correct expression, just based on the definition of the derivative.
Conceptually its because the torque is the difference in force between different radii.
Feb28-12, 12:45 AM   #3
Recognitions:
Gold Membership Gold Member
This sounds suspiciously like a variant on Lorentian aether, which has been thoroughly disproven.
Feb29-12, 02:41 PM   #4
Quote by zhermes View Post
Why does dR [itex]\rightarrow[/itex] 0 makes it a correct expression?
Feb29-12, 02:53 PM   #5
Because that's the definition of a derivative
[tex] f'(x) \equiv \lim_{dx \to 0} \frac{ f(x+dx) - f(x) }{ dx } = \lim_{dx \to 0} \frac{ f|_{x+dx} - f|_x }{ dx } [/tex]
Feb29-12, 03:40 PM   #6
If that's the definition of the derivative, shouldn't [itex]\frac{∂}{∂R}[/itex] on the expression be [itex]\frac{d}{dR}[/itex]
Feb29-12, 03:45 PM   #7
No, because you're only looking at the explicit R dependence---in your equation f(x) would be just the explicitly R dependent part. So you're just doing the partial derivative.
Feb29-12, 05:45 PM   #8
Tm = [itex]\frac{dj}{dt}[/itex]
where Tm is the torque per unit mass, and j = R2Ω(R) which is the specific angular momentum (angular momentum per unit mass)
It may be shown that
[itex]\frac{dj}{dt}[/itex] = [itex]\frac{∂j}{∂t}[/itex] + (v.[itex]\nabla[/itex])j (convective derivative)
= vR[itex]\frac{∂j}{∂R}[/itex] [equation (68) of page 27 http://www.maths.qmul.ac.uk/~rpn/ASTM735/lecture3.pdf]
Looking at the convective derivative, I'm guessing that [itex]\frac{∂j}{∂t}[/itex] = 0 due to the derivative of j = R2Ω(R) with respect to t. If that's the case, then surely
[itex]\frac{dj}{dt}[/itex] should also be 0 which makes vR[itex]\frac{∂j}{∂R}[/itex] equal to 0.
I don't understand why [itex]\frac{dj}{dt}[/itex] isn't 0.
Feb29-12, 06:22 PM   #9
The change in specific angular momentum would be zero if there were no torque. If there is torque, its not zero.
The equation you gave, which (at least) looks right---says that [itex] \frac{dj}{dt} = (v \dot \Del ) j = v_R \frac{ \partial j}{\partial R}[/itex] (i think you're right about the partial w.r.t. time being zero---at least if we assume a steady state). But the divergence of the specific angular momentum isn't zero---so neither is the R.H.S.
New Reply
Similar discussions for: Torque on the Accretion disc
Thread Forum Replies
Hydrostatic Equilibrium in an Accretion Disc Astrophysics 9
accretion disc for a black hole Astrophysics 7
radius of the accretion disc? Special & General Relativity 1
Detecting Black Hole accretion disc Astrophysics 2
accretion disc observations Astrophysics 2
