| Thread Closed |
Non-geometric approach to gravity impossible? |
Share Thread | Thread Tools |
| Mar1-12, 06:18 PM | #69 |
Non-geometric approach to gravity impossible?find this starting line: "5. Einstein's geometrodynamics viewed as the standard field theory for a field of spin 2 in an "unobservable flat spacetime" background...". Please share how it differs to your description of Baryshev's as when you described it in the other thread: "FTG is a classical field theory that begins with the Lagrangian which has three terms, one each for the field, one for the matter and crucially one for the interaction between the field and the matter. The exchange boson, if the theory was quantized would be spin-2. All this is done in Minkowski spacetime." atyy.. since you are familiar with the MTW approach, please share how it differs to the above FTG theme. Thanks. |
| Mar1-12, 06:40 PM | #70 |
See, for example: http://arxiv.org/abs/0809.2328 Almost all other authors on spin 2 field theory would disagree with every prediction of the above paper, believing that spin 2 field theory would agree with GR instead. As with atyy, I am not in a position to judge Baryshev on the merits. One comment on the disagreement is noted in the following: http://arxiv.org/abs/1106.2476 : "Finally, let us mention that approaches exist that treat gravity as simply a spin-2 field on flat space [114, 115]. It has been conjectured that one could reconstruct the Einstein-Hilbert action in such an approach by considering consisitency conditions order by order in perturbation theory. This will, of course, be an invalid treatment when gravity is strong, and in cosmology." Most authors disagree with this paragraph and argue that such recovery of the Einstein-Hilbert action is imperative, and that the comment on invalidity is itself invalid. |
| Mar1-12, 06:55 PM | #71 |
Recognitions:
There is a sublety regarding scaling when you go from the linear to the full nonlinear theory around certain solutions. So when doing perturbation theory around say the Schwarschild solution you naively run into an inconsistency and that is what Baryshev is picking up on.
What he fails to mention is that this problem was dealt with long ago by Vanshtein. "To the problem of nonvanishing gravitation mass”, Phys. Lett. B, 39, 393–394, (1972) But anyway, this is way beyond the scope of this thread and is just arguably going to confuse things more than they already are. |
| Mar1-12, 07:07 PM | #72 |
| Mar1-12, 07:31 PM | #73 |
Also in the MTW approach where space can expand (according to atyy). Take note of this logic: Since expanding space is automatically curved spacetime, and since curved spacetime is just spin-2 field on flat spacetime. Then expanding space is composed of spin-2 field and flat spacetime. Therefore expanding space is related to expanding space&spin-2 field and expanding space&flat spacetime. How does one imagine or model expanding space&spin-2 field for example? Or expanding space&flat spacetime which is a Milne model that isn't valid. Can one say that when one adds spin-2 to Milne model. It becomes valid? Do you see if there is something wrong with my analysis. Thanks. |
| Mar1-12, 07:56 PM | #74 |
For me, the eye-opener is that the non-linearity of GR emerges from the coupling of the boson field to the whole Lagrangian, requiring the infinite series. I think it also shows the deficiency in the FTG approach which has been highlighted in other posts. |
| Mar1-12, 08:04 PM | #75 |
This was posted in another thread, but here is a recent defense by Deser of the derivation of GR from spin 2 field:
http://arxiv.org/abs/0910.2975 |
| Mar1-12, 08:09 PM | #76 |
Spin-2 field over flat spacetime produces an illusion of curved spacetime. Now when space expand. Why did it use the curved spacetime thing when it is just an illusion. Shouldn't it interact with the more primary flat spacetime as it's the more original? |
| Mar1-12, 08:29 PM | #77 |
Recognitions:
| Mar1-12, 08:37 PM | #78 |
| Mar1-12, 08:48 PM | #79 |
Recognitions:
http://www.einstein-online.info/spotlights/big_bangs "The term "big bang" has two slightly different meanings, and the answer to questions like "Did the big bang really happen" depends crucially on which of the two big bangs you are talking about." |
| Mar1-12, 09:17 PM | #80 |
Intermission: About milne expansion... In between supergalatic clusters are empty space devoid of any matter and spin-2 fields (let's say we can ignore the CMB and cosmic rays), then the region of the space can be considered flat. Then can't it be considered a milne expansion? |
| Mar1-12, 09:26 PM | #81 |
Recognitions:
| Mar1-12, 09:35 PM | #82 |
| Mar1-12, 09:42 PM | #83 |
Recognitions:
| Mar1-12, 09:47 PM | #84 |
classical spin 2 theory? quantum spin 2 theory? I thought all spin 2 theory are quantum. But then you can't have spin 2 particles in classical theory just like you can't have photons in classical electrodynamics. |
| Mar1-12, 10:18 PM | #85 |
Recognitions:
| Thread Closed |
| Thread Tools | |
Similar Threads for: Non-geometric approach to gravity impossible?
| Thread | Forum | Replies | ||
| A Geometric Approach to Differential Forms by David Bachman | Differential Geometry | 175 | ||
| A Geometric Approach to the Riemann Hypothesis | Linear & Abstract Algebra | 0 | ||
| Special Relativity - geometric approach? | Science Textbook Discussion | 2 | ||
| A Geometric Approach to the Standard Model, Greg Trayling | High Energy, Nuclear, Particle Physics | 0 | ||
| A New Approach in Quantum Gravity | Beyond the Standard Model | 0 | ||
