New Reply
Relative energy of a black hole.
Share Thread Thread Tools
Mar2-12, 09:05 AM   #103
I couldn't help but wonder if, say for instance a very large star ended up being slung around the suppermassive black hole in the center of the galaxy. Then this star ended up traveling at a very high speed straight for Earth. So then say that the relative speed of the star and its mass creates an event horizon around itself because of the relative mass that was seen from Earth. You could say that it was just the relative mass that made it look like a black hole and that any planets traveling along with the star didn't observe this relative mass so then they could orbit around the star and stay just fine. So then they send a team into the black hole to try and slow it down to prevent the destruction of Earth. They then would travel straight into the black hole at speeds close to the speed of light to prevent becoming spagitified. They then transfer into the frame of reference of the star itself so they no longer observe it being a black hole. And then they land on one of the planets and find life and decide to live there since they failed blowing up the star and live on inside this "black hole" as if they are just fine. So, then do you think something like this scenario would be possible or totally science fiction?
Mar2-12, 09:49 AM   #104
Quote by Naty1 View Post
Q-reeus posts:
If you READ from posts 88 on....Tricky, my posted quotes, George Jones comments and quotes and Peter's comments explain it to the extent it can be....'non localizable', covarient derivative effects, non localizable,etc,etc ......
these are all complementary, not in conflict.
including these:
from Ryder
and from Penrose:
I could quibble with Peter's comment about problems with energy theorems (in #91) being more 'philosophy' than physics.....but that's waaaaaaaaay too nit picky....
Q-Reeus...While I see why pervect opted out early, I am on the other hand happy to see your persistence:
" It is better to debate a question without settling it than to settle a question without debating it."
.......Joseph Joubert, the 18th century philosopher
I, for one, am 'outta' here....finally!!
Naty1, I was fearing getting only stick from you at first, but sort of ended on a relative high - but I understand your departure. It has got a bit torrid. On your first point, I want to be clear there was no specific attacking the notion of 'non-localizability' in my query. Just can't see the connection on the specifics I raised, and non-localizability seems off the mark in that respect. Just want a clear statement as to whatever connections are implied. May have missed something earlier but can't recall it. Anyway you have inspired me to soldier on, so good!
Mar2-12, 10:11 AM   #105
Recognitions:
Gold Membership Gold Member
Quote by Q-reeus View Post
Last bit is patently untrue, but I guess you forgot to insert 'that I acknowledge'.
The insertion would not change the truth value, I suppose. But you apparently don't understand what is actually required for a counterexample. A counterexample would look like this: "Here's an actual physical observable that the standard EFE/SET method doesn't predict or explain." Or: "Here's a prediction made by the standard EFE/SET method that doesn't match this actual physical observable." You have given no such example, because you have never actually tried to figure out what the standard EFE/SET method predicts or explains; you haven't used it. You've insisted on reasoning from your own set of premises (like "gravity gravitates") instead, and then you've tried to claim that if the conclusions you reach don't appear to be consistent with the standard EFE/SET method, the standard method must be wrong. So it's not that I'm saying any counterexample must be wrong by definition: I'm saying you have not actually given counterexamples at all; instead you've given conclusions derived from a different set of premises altogether, and those premises are only approximately true (and even that is only in a limited domain).
Maybe neutron stars, but even there do we have convincing evidence it is needed to account presumably for maximum NS mass (less if pressure is SET source, than if not)? Have come across articles where it is admitted the eqn's of state within NS's are still not fully understood.
Neutron stars are a good example of pressure contributing significantly to the SET, yes. And yes, the maximum NS mass is one area where the pressure contribution is important; we know that even though we don't know the exact equation of state (because we've tested a whole range of possible equations of state numerically).
Hope you can appreciate that from my pov the above is frustratingly empty. On the one hand, a clear statement that gravitational field energy Eg is specifically absent from the SET. But then go on to say it is one way of describing the relationship between measured M and the SET. But nowhere have I seen you attempt to pin down what is then gravitational "energy's" role in a 'way of describing'. What exactly is it that means anything given Eg is utterly absent from the SET? Curvature non-linearity? If so, how about just plainly say so and why, or if something else, say exactly what it is.
I appreciate that things look this way from your pov. But now consider how they look from my pov. As I've said several times now, in the standard EFE/SET picture, there is no *need* for the concept of "gravitational energy" at all. All physical predictions can be made without ever using it. So from my pov, the problem is not that I'm not answering your questions, but that you insist on asking them even though I've repeatedly said that they are based on the wrong set of concepts. I have been trying to meet you halfway by at least trying to express how one *might* salvage some kind of correspondence between the concept of "gravitational energy" and the standard EFE/SET method, in a limited domain. But that's only because I understand that the concept of "gravitational energy" has intuitive force, so I'm willing to expend some effort in trying to explore it and its limits.
But asking for what "exactly" the concept of "gravitational energy" means is asking too much: the concept is only a heuristic one and it does not have an "exact" meaning. (Or perhaps a better way to say this would be: one could give an exact definition of "gravitational energy", such as the Landau-Lifshitz pseudotensor, but no such definition is unique, and any such definition only "makes sense", only corresponds to our intuition, in a restricted set of cases.) If you want an exact answer, it is this: there is no "gravitational energy" in the SET, so as far as exact calculations of physical predictions are concerned, it doesn't exist. (You'll note, in this connection, that nobody uses any definition of "gravitational energy" to actually make physical predictions: they all use the standard EFE/SET method, and then once they know what the answer is, they overlay their chosen concept of "gravitational energy" on top of it to help them understand intuitively what's going on.)
Admit the inescapable, basic logic - *total* system *observed* mass M thus declines. If your 'answer' is to ignore this request, understand I will feel free to draw obvious conclusions. And recall in past postings you have specifically claimed M cannot decline if all matter+energy is included. Deny that and I will gladly furnish quotes to the contrary. This is relevant to the monopole GW issue btw.
All right, let's look at this from an *exact* point of view. The exact point of view is this: the "total system" is the entire spacetime, including the region "at infinity". This "total system" does not *have* a "mass M". The exact metric is not in any of the forms where "M" even appears; it's more complicated. (One could try to extract a "piece" of the metric where a coefficient "M" appears, but that's just an approximation-see below.) So from the "exact" point of view, there is *nothing* in the physics corresponding to "total system observed mass". There is a metric at each event, and there is an SET at each event (nonzero in the interiors of the two pulsars themselves, zero everywhere else--if we ignore the EM radiation emitted by the pulsars and assume the only "radiation" in the spacetime is GWs), and the EFE holds at each event. That's it.
Does this "total system" have a "total energy"? It depends on how you define "energy". The spacetime as a whole does not have a time translation symmetry, so we can't define "energy" that way. The spacetime *may* have a continuous set of spacelike slices that match up well enough with what symmetry does exist (for example, maybe the slices are good approximations to "natural" ones that observers hovering at a large radius R above the binary pulsar system would pick out as "surfaces of constant time") to be useful in defining "energy" by integrating the energy conservation equation (i.e., the covariant divergence of the SET) over each spacelike slice. This could define a "total energy" for the system, and this total energy could turn out to be conserved (i.e., the same on every slice), at least to a good enough approximation (the same level of approximation to which the slices are good "surfaces of constant time" for some set of observers). But will this "conservation of energy" be "exact"? Probably not, since the spacetime does not have any exact symmetry. So if you want an exact answer, it is that there is no "total energy".
Now, suppose I decide to draw a boundary at some finite radius R around the binary pulsar system, and say that inside that boundary is "the total system" and outside it is "the rest of the universe". I can pick R large enough that, to a good approximation, the binary pulsar system "looks like" a simple gravitating body with some mass M. More precisely: the metric at R is still not quite in the Schwarzschild form, because the spacetime is not spherically symmetric or static; but it will be close enough that I can "split" it, approximately, into two pieces: a "Schwarzschild" piece and a "gravitational radiation" piece. The Schwarzschild piece, to a good approximation, will look like a gravitating body with a mass M that slowly decreases with time ("time" meaning "proper time according to an observer hovering at radius R). The gravitational radiation piece will be oscillating in quadrupole fashion, and could be measured by, for example, letting the oscillations heat up a detector and measuring the energy taken up. We could then, in principle, do an energy balance: the decrease in M is balanced by the energy carried away by GWs.
Will this energy balance be "exact"? Probably not, because the split of the metric into the two pieces probably won't be exact; there will probably be extra terms in the metric that are left out--they aren't included in either the Schwarzschild or the GW piece--because they are small compared to both of those pieces.
So we come back again to what I said above: if you insist on an "exact" answer, then it is this: "gravitational energy" doesn't exist, and the only exact "energy conservation" is what I said earlier: the covariant divergence of the SET (the standard SET) is zero at every event. Anything else is approximate, and breaks down if you try to press it too hard. That includes things I've said previously (like "M cannot decline if all matter-energy is included"); I apologize if I didn't make it clear enough that I was only speaking approximately.
Mar2-12, 10:42 AM   #106
Quote by PeterDonis View Post
A counterexample would look like this: "Here's an actual physical observable that the standard EFE/SET method doesn't predict or explain .
Does dark matter qualify?
Mar2-12, 10:58 AM   #107
Recognitions:
Quote by TrickyDicky View Post
No. "Dark matter", from the standpoint of the EFE/SET, is just ordinary "matter" (i.e., it has the same kind of SET as the matter we observe every day) that doesn't interact with anything else non-gravitationally, so we have no way of observing it the way we observe ordinary matter, by EM radiation or any other type of non-gravitational radiation or interaction; the only way we know it's there is indirectly, through its gravitational effects.
I realize that there is an ongoing debate in astronomy as to whether the standard interpretation of observations (like galaxy rotation curves) as signifying the presence of "dark matter" is correct. There are alternate theories that modify the way gravity works (i.e., they are *not* standard GR) in order to account for the observations without postulating dark matter. I am not saying those alternate theories have been proven wrong; they haven't (I consider them all much more unlikely than the standard interpretation, but that's just my opinion). I'm just saying that the observations, by themselves, are not counterexamples to standard GR: standard GR can account for them perfectly well, by just adding the dark matter to the total SET that is being used in the EFE.
I realize also that the above is open to another objection: well, sure, you can make any set of observations compatible with standard GR by [Edit: fixed typo, was "but"] just fiddling with the SET. First of all, that's not quite true; mathematically, it can be done, yes--you can postulate any tensor you like as an "SET", put it on the RHS of the EFE, and solve for the metric it will produce--but the results may not be very reasonable physically (for example, they may violate energy conditions or other constraints that are widely accepted). Dark matter doesn't do that: the dark matter SET, as I said, is just like that of ordinary matter, so it's perfectly reasonable physically.
Second, dark matter fits into the picture in multiple places, not just one; for example, the current "best fit" big bang model requires cold dark matter, in roughly the same proportions ("roughly" because all of these calculations have significant "error bars" at our current level of knowledge) as are required to explain the galaxy rotation curves and other "local" observations. So dark matter is not just being put in ad hoc to fit one piece of data; it has a reasonable place in a comprehensive model, and that comprehensive model uses the standard EFE/SET of GR. (That's one reason, btw, why I think the alternate theories that modify gravity are unlikely to be right; they all monkey with the overall dynamics of the universe in a way that messes up the correspondence with other cosmological observations, so they then have to make other ad hoc assumptions to fix things up. I admit I am not very up to date in this area, so there may be recent developments that I'm not aware of; but that's my understanding of where things stand.)
Mar2-12, 01:17 PM   #108
Peter, appreciate that in #105 you have tackled in your own inimitable style the specifics I raised earlier. There is a sense of deja vu to it all. Collectively we have created a a lengthy record of exchange for any looking on to make their minds up from. Guess you can figure what I'm saying. I will end my participation with a slightly edited cut-n-paste from #57 which turned out to be just intermission. End of the show here for me, and I trust no hard feelings between us: From #57:
Peter, thanks for your clarification and with that I agree with [some of] the above. On the broader picture, while I respect you are an accomplished master of GR maths and it's application, sad to say there is no final consensus. Bravo though for putting in a lot of effort in trying to evaporate my scepticism. At the least it has given me a clearer understanding on how this issue is seen by the GR community. Have a nice day.
Mar2-12, 01:21 PM   #109
Recognitions:
I trust no hard feelings between us.
No hard feelings at all. It was a fun discussion.
Mar2-12, 01:21 PM   #110
I realize also that the above is open to another objection: well, sure, you can make any set of observations compatible with standard GR but just fiddling with the SET. First of all, that's not quite true; mathematically, it can be done, yes--you can postulate any tensor you like as an "SET", put it on the RHS of the EFE, and solve for the metric it will produce--but the results may not be very reasonable physically (for example, they may violate energy conditions or other constraints that are widely accepted). Dark matter doesn't do that: the dark matter SET, as I said, is just like that of ordinary matter, so it's perfectly reasonable physically.
Well explained, of course one has to wonder what kind of observation could serve as counterexample if we are always allowed to postulate some kind of SET source that fits our model but has never been detected or can't be directly observed.
Mar2-12, 01:31 PM   #111
Recognitions:
I addressed this in my post (last two paragraphs). (Note: I just fixed a small typo in that post that may have caused confusion.) We are not "always allowed" to postulate whatever SET will match the data; there are other criteria we can use to judge whether the postulated SET is reasonable. Yes, that's a judgment call, but so is every statement about correspondence of theory with experiment.
Mar2-12, 01:59 PM   #112
Yes, you missed my point I guess, I meant the postulated SET in this case has no correspondence with experiment because no experiment has ever detected it and some claim it might never be.
Actually my questios was no rhetorical, what kind of observation would count as counterexample in your opinion?
Mar2-12, 02:16 PM   #113
Recognitions:
It's not true that "no experiment has ever detected it"; the observations of galaxy rotation curves and the dynamics of the universe count as such experiments. A more accurate statement would be "no non-gravitational experiment has ever detected it, and some claim it might never be".
An observation that doesn't match the predictions of the standard EFE with a physically reasonable SET. Actually, for the cases we've discussed in this thread, the list of physically reasonable SET's is pretty short: perfect fluids just about covers it, with the proviso that the "dark energy" SET, which is a constant times the metric, counts as a "perfect fluid" where the pressure is equal to minus the energy density. For some of the cases (such as the case I gave of two objects that fall together and collide), we would also have to include non-zero kinetic energy and momentum components, and possibly shear stresses. This general category of SETs is used in numerical simulations in GR all the time; for example, the binary pulsar calculations that match up so well with the Hulse-Taylor observations, were done using this kind of SET. The animation of two black holes merging, which Q-reeus mentioned, also ultimately depends on the same kind of SET, since that's what's used to validate the initial form of the metric around each black hole due to the object that collapsed to form it. The rest of the evolution of the merger, AFAIK, follows simply from the vacuum EFE when you have two black holes separated in space.
New Reply
Thread Tools
Similar Threads for: Relative energy of a black hole.
Thread Forum Replies
Relativistic mass increase appearing to form a black hole vs. a real black hole Special & General Relativity 9
Time dilation and black-hole--black-hole mergers, and ringdown gravitational waves Special & General Relativity 13
Is black hole existence relative to the reference system? Special & General Relativity 8
Relative to a black hole... Special & General Relativity 12
V relative to black hole General Astronomy 2
