New Reply
why is superdeterminism not the universally accepted explanation of nonlocality?
Share Thread
Mar2-12, 07:30 AM   #171
Quote by Delta Kilo View Post
Wouldn't retro-casuality have exactly the same outward appearance as superdeterminism to us? It is certainly more economical (in occam sense) - the 'conspiracy' in each case only has to go back in time as far as needed to achieve correct outcomes as opposed to setting it all up just before big bang. Also laws of physics are time-symmetrical already (:those that counts anyway:).
exactly. it shouldnt be called super determinism. it should be called universal causality. if im the first with this this then i claim it. adrians universal causality
Mar2-12, 07:33 AM   #172
Quote by lugita15 View Post
You're right, I am assuming that. But that's a harmless assumption to make. Perfect correlations for matching measurement settings is a consequence of quantum mechanics, so surely if a local realist theory wanted to match the predictions of QM then it would have to have perfect correlations for matching measurement settings. I highly doubt this is what ThomasT is disputing.
(You can, of course, be the fringe type of local realist who has a theory making predictions contrary to QM, but who believes that the only reason the experiments have proven QM right is that they're subject to various flaws, loopholes, and systematic biases. But as Bell tests become more sophisticated, that becomes an increasingly untenable positon, arguably even more so than superdeterminism.)
if you could match experimental settings, which you cant, then you wouldnt have correlations, youu would have the exact same result.
Mar2-12, 08:02 AM   #173
OK, let me give you an example of why you need special initial conditions.
In a deterministic theory, in order to predict the current behavior of any object, you need to know the initial conditions of the object, as well as the deterministic laws of the universe. In Newtonian mechanics, for example, you need to know the positions and velocities of all the particles at time t=0, and then F=ma will tell you the behavior of the particles at all later times.
Now let's consider what a local deterministic explanation of entanglement would look like. Let particles A and B be an entangled pair of photons, which are separated by a great distance and then sent through polarization detectors. We also have particles C and D: C tells the experimenter what angle he should set the polarizer that measures A, and D tells the experimenter how to set the polarizer that measures B. You can think of C and D as neurons in the brains of the experimenters if you like.
Now we find experimentally that the behavior of particle A through its measurement device is strongly correlated with the angle at which B's measurement device is set. And that angle is determined by particle D. So we have a correlation between the behavior of particles A and D.
But particles A and D are seperated by such a large distance, so they cannot communicate with each other to coordinate their behavior (unless you have a nonlocal theory like Bohmian mechanics which allow undetectable faster-than-light signalling between particles). So a local determinist has to conclude that A and D are correlated not based on a current relationship between the present states of A and D, which would be impossible, but based on a past relationship of the initial states of A and D.
This is what we mean by special initial conditions: A and D seemingly have nothing to do with each other. After all, it is A and B that were in the entangled state, and yet somehow we have to conclude that the initial conditions of A and D had to be specially set so that a correlation between A and D would be observed in the future. And instead of just D, we can have a large number of particles D1, D2, D3,... which together determine the measurement setting, so the initial state of particle A had to have been set based on the initial states of all these particles. And in the real world, almost all particles in the universe are interacting in some way with almost all other particles, so really the setting of measurement device depends on almost everything in the universe, from which we conclude that the initial conditions of the whole universe were specially set so that the right kind of correlation would be displayed billions of years later between particle A and the measuring device.
This is why superdeterminism is called "conspiratorial". That doesn't mean it's wrong, it just has some issues which make it rather difficult to construct a viable superdeterministic theory, but let me repeat that some potential first steps toward such a theory have already been taken by a few people.
also with d could have this instantaneous effect on a as i could decide to shoot my self in the head or not depending on the angle, wouldnt this be faster than light info tranfer, violating relativity?
this further seems proof that d and are within the lightcone of the distant past, in which case, the info about what d will do to affect a is predetermined. and nonlocal interactions can only occur within a lightcone or you violate relativity.
Mar2-12, 08:07 AM   #174
also, has it been proven in a lab that time moves forward and isnt frozen or moving backwards? it seems like that is something our intuition has guided us to regard as truth. is there not enough intuition in the world to regard determinism as truth?
Mar2-12, 08:23 AM   #175
Quote by DrChinese View Post
Free will is not a necessary component of QM. So I certainly am not rejecting superdeterminism because of that. I reject superdeterminism as an explanation for Bell test results, and I do so for the reasons already stated.
Please bear in mind that there are no candidate superdeterministic theories to reject at this point, so it is a moot point in many ways. The reason I mention the amount of local information to be stored in every particle is because a candidate theory will end up postulating this (in some form or fashion) as a way to explain Bell test results. It is not necessary to assume free choice for measurement settings in any stage of the argument, but you must explain how (i.e. the exact mechanism, since we have no other reason to suspect it exists) the choice is propagated in a superdeterministic candidate.
Not so easy, I assure you. Which is again, the answer to your original question.
then why even call it superdeterminism. there is no conpiracy! its simply causality governed by relativity. call it universal causality. yes it is that easy.
Mar2-12, 08:44 AM   #176
Quote by jadrian View Post
exactly. it should be called super determinism. it should be called universal causality.
No, it is obviously different. superdeterminism does not by itself imply retro-causality. Instead some constraints are placed on the initial conditions which somehow pre-determine the outcomes of all Bell-type experiments (including experimenters' choices) in the future. These initial conditions then evolve forward in time according to laws of physics, causing all these pre-determined outcomes to eventuate.
And the other way around, retro-causality does not mean total super-determinism.
Too bad, you are at least 25 years late. See Transactional Interpretation. Although I personally don't like it, or rather don't see a point. It does not clarify what measurement apparatus is, where does preferred basis come from and what happens to Shroedinger's cat. It keeps all these thorny questions swept under the carpet.
But then transactional interpretation does not hold a monopoly on advanced wave solutions. After all, MWI is sufficiently weird, those who accept it might as well go for broke and add retro-causality to the mix.
Mar2-12, 08:53 AM   #177
That is just NOT true in any meaningful sense. A particle has only a few observable elements: momentum, position, mass, charge, spin, color, etc. It would be instructive to state specifically how you would know ANY information about the past interactions by knowing these. Suppose the spin is +1. What does that tell you? Or momentum is 1.63 (units ignored) in direction XYZ? Not much history to be gained from that!
No, you need there to be a rich hidden internal structure. One that contains the entire initial conditions of the universe, like DNA. And this DNA would need to be in every particle so they know how to react during Bell tests.
conservation of information. finiteness of information. your quote "what does that tell you" is ambiguous. you are trying to say that information can not adequately explain the universes deterministic evolution? are you serious? do you believe in true randomeness? in order for an electrons position to be truly random, you would have to assume it is moving at infinite speed!
and your dna analogy is completely imcompatable. dna is replicated. information is not.
consider a rack of pool balls getting struck by the cue ball.
now remove all the balls besides the cue ball and the 8 ball. assume the cue ball is particle d and the 8 ball is particle a. without the other balls measured positions on the table, you will not be able to know how the cue ball transfered its info into the 8 ball resulting in the cue ball and 8balls new locations. it requires ALL!!, ALL!! how many times do i have to say it? of the information of all the other balls location, how much they spun, etc.. to figure out how cause led to effect via determinism in this situation. you keep throwing these things at me as if they are a way around the law of conservation of information. seriously?
Mar2-12, 08:56 AM   #178
Recognitions:
Gold Membership Gold Member
Actually, there are QM interpretations in which time does not flow in the conventional sense. These are called "block world". I happen to be something of a fan of a particular one of these, called Relational Block World.
Relational Blockworld: A Path Integral Based Interpretation of Quantum Field Theory; W.M. Stuckey, Michael Silberstein, Timothy McDevitt (2009)
Although time does not flow, the future is a component in interactions and it is the total setup that is relevant. Although the authors do not call it a time symmetric model per se, I think it qualifies.
For those that are interested:
The above paper is advanced reading, but it is absolutely fascinating in this sense: It is a QM interpretation that makes predictions that are slightly DIFFERENT than standard QM. Incredibly, those predictions seem to account for experimental evidence in favor of an accelerating expansion of the universe WITHOUT adding otherwise new physics.
Easily the most ambitious program I have seen in the few years. So a tip of the hat to the authors, good luck! If anyone wants to discuss, we can start a new thread on that.
Mar2-12, 09:02 AM   #179
Again, I am not claiming that A and D could never have interacted. I am saying that the interaction of A and D would have to have occurred in just the right way so that they would demonstrate nonlocal correlations of just the right kind. And by similar arguments, you would have to conclude that at the beginning of the universe all the particles interacted with each other to set just the right initial states for each particle, so that all the Bell tests which would be performed in the entire history of the universe would get just the right results. That's what's called a conspiracy.
they dont have to interact in a special way, what makes you think that. weve already been through your abcd experiment and ive shown its irrellevant to universal causality leading to determinism without any special initial conditions. there is no conspiracy unless you NEGLECT the histories of the pool balls besides the cue ball and 8 ball as i described above
Mar2-12, 09:15 AM   #180
Recognitions:
conservation of information. finiteness of information.... you keep throwing these things at me as if they are a way around the law of conservation of information. seriously?
Well, golly. Perhaps you can share this with us. What exactly is this law? Can you cite a reference? Does it have anything to do with entropy (which increases to the future, see 2nd law of thermodynamics)?
At any rate, you continue to throw out terms without understanding their meaning. At this point, I, lugita15. Delta Kilo and others have tried to help you with the physics involved. You seem to reject this in favor of speculation which lacks any basic background study or consideration. Your billiard ball example is typical, as it doesn't explain Bell test results and never will.
So good luck, and again I recommend you do some more study in the area.
Mar2-12, 09:18 AM   #181
Any deterministic theory has causality. But if you have some arbitrary deterministic theory and some arbitrary initial conditions, chances are you won't get the nonlocal correlations necessary to match the results of Bell tests. It's only if you have very specific initial conditions, conditions where the initial state of each particle is set based on the initial states of all other particles, that you get the right kind of nonlocal correlations. That's what makes superdeterminism conspiratorial.
Let me repeat, that does not mean superdeterminism is ruled out, it just means there are hurdles that any superdeterministic theory has got to face.
there is no conspiracy. c is pretty quick. theres no reason why you would need every particle to be causally strung together in the beginning. anything within a lightcone will be causally "connected" very quickly if it wasnt from the start. info spreads and infects through every event very quickly it like i said the cue ball and 8 ball alone will not know how they ended up in their future state. but think of the other balls as all the particles in the universe. each ball doesnt have a conpiratorial copy of what the cue ball did. they only know their own finite amount of info. but if you add up all their info, you will know where both the cue ball and 8 ball are
Mar2-12, 09:25 AM   #182
No, there isn't, but there is something conspiratorial about a particle behaving in just the right way based on the information it has about what other particles are going to do at just the right time and place. Again, particles interacting and transferring information is not regarded as a conspiracy. It's a conspiracy if their interaction induced some very special behavior on their part which leads to a Bell-type nonlocal correlation.
i still have no idea why you say conspiratorial. say historically interacted instead of conspiracy.
bells nonlocal correlations... come up with a billion of them... they are a non issue because they dont violate relativity and are therefore predetermined
Mar2-12, 09:43 AM   #183
To repeat, in order to have Bell-type nonlocal correlations between A and D in a local deterministic theory, we need A and D not only to have interacted in the past, but to have interacted in just the right way so that they would get the right "conspiratorial" initial conditions so that they would display the right kind of nonlocal correlations years later.
just the right way... you make it sound so special.... its just causality.... determinism does not have to be local, because nonlocality doesnt violate relativity.
Mar2-12, 09:52 AM   #184
Off topic, but Einstein definitely did not find the new radical notions of space and time he came up with intuitive. He was led to SR because he saw that the electrodynamics of moving bodies seemed to possess a greater degree of symmetry than their conventional description gave them credit for, and so he tried to redo the laws of kinematics so that Maxwell's equations could be shown to conform with the principle of relativity.
then why would he say things say things such as "your math is correct, but your physics is abominable".... einstein was a thinker no doubt about that. hes was the living representation of occams razor. he always believed the laws of nature should be elegant.
and gr owns qm in terms advancing our understanding of our world.
Mar2-12, 10:04 AM   #185
Quote by ThomasT View Post
There's no way to know or demonstrate that information, or anything else, is instantaneously transferred from a to b. In fact, instantaneous propagation is a contradiction in terms. If a and b are changing instantaneously, then they're changing simultaneously. And there's nothing in our observations of our world, our universe, that suggests that simultaneous, spacelike separated, changes in a and b imply a causal relationship, or any sort of communication, between a and b. Rather, what this does imply is that a and b are part of a larger system, or that a and b have something in common due to a common cause.
Wrt some formulations (eg., inferred wrt standard QM and explicit wrt dBB interpretation) a and b can be said to change, or are explicitly encoded as changing, simultaneously. So, if one wants to give this some sort of pseudo mechanical meaning, then one might say that information is being instantaneously transferred between a and b. But this isn't really mechanics. It's just an assumption that can't be verified or falsified. Ie., a physically meaningless statement.
That's news to me. I would say that observations indicate that our universe behaves contrary to the notion of block time. That is, it's evolving and transitory. But that certain theoretical constructs/eventualities suggest block time. And, afaik, the theoretical stuff that suggests block time (or that contradicts observation) is more or less routinely disregarded/discarded.
Because it's unwarranted wrt extant observation and mainstream interpretation of theory.
Your title asks why superdeterminsim isn't universally accepted. My guess is that it's because superdeterminism doesn't refer to anything other than determinism. Determinism might not be universally accepted, but I think it's the predominant assumption and starting point wrt virtually all of the physical sciences.
Why not? Are you saying that the assumption of determinism implies action at a distance? Or superluminal propagations?
Ok. So far this is just determinism.
You've arbitrarily assumed a starting point (ie., initial conditions) that isn't influenced by past events. But we can just as well assume that wrt whatever you want to assume as a starting point there are antecedent events, ie., some prior history/conditions.
So, as far as I can tell, superdeterminism is a superfluous term, which actually just refers to determinism.
thats the way i feel. there doesnt need any super conspiracy to allow determinism
Mar2-12, 10:12 AM   #186
Let's say I decided to run Bell test and choose settings for A based on the address book of Acapulco. For the test to produce the results it does while maintaining local realism, something in the past would have to causally influence both the source of entangled photons in the lab and the early settlers of Acapulco in such a way as to establish a very specific relationship between the two. Just having a causal link is not sufficient, it would have to be a very specific 1-to-1 correspondence. Do you have a theory to explain it?
Mar2-12, 10:18 AM   #187
Yes, I reread your reply. I still don't understand what differentiates superdeterminism from determinism. I think Demystifier also tried to explain it one time to me. That didn't do it for me either. Or what Bell or 't Hooft have to say about it. I mean, it just isn't clear to me what the word superdeterminism refers to that's different from what the word determinism refers to.
i agree.
and demystifyers explanation can simply be explained by causality. if thats not enough ill call it supercausality.
below is the explanation that demystifyer tried to explain supdet vs determinism.
Originally Posted by ThomasT View Post
In an optical Bell test involving photons entangled in polarization, what does t=0 refer to? The time of emission of an entangled pair? What are the hidden variables? The polarizations of the paired (entangled) photons?
The time t=0 is some hypothetical time in the past when all of the particles in your system, or worse yet all the particles in the universe, communicated with each other and set the initial values of their hidden variables. This include the particles, or the ancestors of the particles, which will eventually end up in the brain of the experimenter, or whatever device he uses to choose the polarizer setting. It also includes the photons, or the ancestors of the photons, which will be measured in the Bell test. Presumably t=0 occurred long before the emission of your entangled pair, because it had to be a time when all of the particles were within a small distance of each other, so that they could communicate without FTL signals (otherwise we would have a nonlocal realist theory).
As to what the hidden variables are, they need to come in two kinds:
1. The particles whose descendants will be the photons in the Bell test will need to have information about whether a photon should go through or not when it encounters the polarizer, knowing in advance what the angle will be.
2. The particles whose descendants will (for instance) be in the brain of the experimenter need to have information about which setting the polarizer should be set to, knowing in advance whether the photon will go through or not.
But didn't Demystifier indicate, or at least suggest, that the predictions of local superdeterministic models (as opposed to the predictions of local deterministic models) agree with QM? That is, aren't local superdeterministic models enhanced in some way so as to predict (correctly) results that local deterministic models can't? This is what I'm asking about. What makes a model of a particular experimental preparation superdeterministic as opposed to merely deterministic?
Yes, a local superdeterminist model would make the same predictions as quantum mechanics. In a standard local realist model, Bell's inequality would be satisfied, whereas in quantum mechanics it is violated. In a superdeterminist model, the particles would set their initial conditions, knowing in advance what the polarizer settings will be, in order to make Bell's inequality appear violated. In other words, they are conspiring in order to make local determinism seem false when it is really true.
New Reply
Similar discussions for: why is superdeterminism not the universally accepted explanation of nonlocality?
Thread Forum Replies
Gauss' Law Universally True? Classical Physics 36
superluminal instantaneous influence Quantum Physics 5
Arguments Against Superdeterminism General Discussion 142
why is there such little talk regarding superdeterminism? General Discussion 23
I hear a lot about nonlocality and it's relationship to QM Quantum Physics 3
