New Reply
A problem involving Force in terms of time????
Share Thread Thread Tools
Mar2-12, 09:41 AM   #1
1. The problem statement, all variables and given/known data
There is a body of 3 kg which is moving to the right with a velocity of 10 m/s. A force of 6 N/s2t2 is applied on the body to the left. How much distane will the body have travelled from t=0 when its velocity is 0 m/s?
2. Relevant equations
I think they should be F=ma , dv/dt = a, ds/dt = v
3. The attempt at a solution
F=6t2
So by newton's second law,
F=3(2t2)=ma
so i got a = 2t2
Integrating this, i got v=t3+C and s=t4/4
Now i thought initial velocity will be -10m/s which i put in C
and V=0
so, 0 = t3-10 or t=2.31 seconds
I have no clue what to do after this. I thought i'll substitute the value of t in the equation with s in it, but some how i don't think its correct. And i don't have any answers to check my solution. please help..
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Mar2-12, 10:04 AM   #2
Hint:
Equation for s has to be written in a different form. With constant acceleration it is
s = V0t+.5at^2
You do not have constant acceleration.
Mar2-12, 10:06 AM   #3
is the equation s=t4/4 + C??
Mar2-12, 10:31 AM   #4
How about something like this
s = V0 * t + integral(a(t) * t)*dt
where a(t) is the acceleration, F(t)/m.
You have a mistake below for your time
"Integrating this, i got v=t^3"
Mar2-12, 10:34 AM   #5
Your equation s=t^4/4 is incorrect because your previous integration was incorrect.
Mar2-12, 10:36 AM   #6
But all this mathematics and integration in physics often confuses me. I don't know when to use which technique of integration. Moreover, I have only done the rudiments of calculus. Is there any definite way to know when to use which technique?
Mar2-12, 10:39 AM   #7
You can use whichever you feel the most comfortable. If you had solved for the time you could use definite integrals and avoid constants of integration.
When you integrate x^n you get (x^(n+1))/(n+1). Does this help?
Mar2-12, 10:53 AM   #8
And when you integrate
a*x^n you get a*(x^(n+1))/(n+1) where a is a constant. Do you see your mistake now?
New Reply
Tags
force, newton's laws, physics, velocity
Thread Tools
Similar Threads for: A problem involving Force in terms of time????
Thread Forum Replies
Force of gravity in terms of time, rather than distance. General Physics 3
Time problem involving Mass and a Pulley? Introductory Physics Homework 1
HELP! problem involving force of friction and normal force Introductory Physics Homework 7
Need help with a Force problem involving friction. Introductory Physics Homework 1
SHM problem involving an applied force Introductory Physics Homework 6
