Cross section of coulomb sacttering vs Rutherford
The discussion focuses on the differential cross section of Coulomb scattering and its relationship to Rutherford scattering. It establishes that the differential cross section can be modeled using a form factor multiplied by the Rutherford cross section, particularly when using a spherically symmetric charge density. The conversation highlights the limitations of Rutherford's model when the potential deviates from spherical symmetry or when the kinetic energy of the scattered particle is significant. For more complex charge distributions, such as Gaussian, and non-spherical potentials, it is necessary to revert to fundamental principles as outlined in Goldstein's "Classical Mechanics."
  • Understanding of differential cross sections in scattering theory
  • Familiarity with Coulomb and Rutherford scattering models
  • Knowledge of angular momentum and energy conservation in classical mechanics
  • Basic principles of potential energy and charge distributions
  • Study Goldstein's "Classical Mechanics" for foundational principles in scattering
  • Research Gaussian charge distributions and their impact on scattering outcomes
  • Explore Mie's theory of scattering and its extensions for non-spherical potentials
  • Investigate integral equations related to inverse scattering problems
Physicists, particularly those specializing in scattering theory, graduate students in classical mechanics, and researchers exploring charge distributions and their effects on scattering phenomena.
oosgood
differential cross section of coulomb scattering can be expressed as a form factor times Rutherford one, we model the charge we used spherically symmetric charge density, if we replace this point charge with other distribution like Gaussian , what is the difference between these two models, is there physical explain?
If your potential is firstly spherically symmetric and secondly your scattered particle does not penetrate too far into the charge distribution then Rutherford's model is adequate. The phrase I used of 'too far' is a matter of accuracy. A Gaussian potential clearly is non zero at large distances and will affect the result.
If you want to consider non spherical symmetrical potentials or when the kinetic energy of the scattered particle is significant with respect to the electrostatic energy of the scattering particle ie it goes 'too far' then you will need to go back to elementary principles - see Goldstein's Classical Mechanics - but be warned there are very few 'closed' ie analytic solutions for such problems.
A help maybe in a totally different area of scattering theory look up the extensions made to Mie's theory of scattering from ellipsoids - the math will help
Hope this helps
Regards and good luck
Sam
Let us suppose the impact factor is [itex]b[/itex], and the initial velocity is [itex]v_\infty[/itex]. If the potential energy is spherically symmetric [itex]V = V(r)[/itex] and vanishes at infinity, then the law of conservation of angular momentum and energy give:
[tex] m \, v_\infty \, b = m \, r^2 \, \dot{\phi}[/tex]
[tex] E = \frac{m \, v^2_\infty}{2} = \frac{m}{2} \, \left(\dot{r}^2 + r^2 \, \dot{\phi}^2 \right) + V(r)[/tex]
One can then eliminate [itex]\dot{\phi}[/itex] from the first equation and use it to go over from time dependence to angular dependance:
[tex] \dot{r} = \frac{d r}{d \phi} \, \dot{\phi} = \frac{v_\infty \, b}{r^2} \, \frac{d r}{d \phi} = -v_\infty \, \frac{d}{d \phi} \left( \frac{b}{r} \right), \ z \equiv \frac{b}{r}[/tex]
to get a 1st order differential equation for the trajectory of the particle:
[tex] E = \frac{m \, v^2_\infty}{2} = \frac{m \, v^2_\infty}{2} \, \left[ \left( \frac{d z}{d \phi} \right)^2 + z^2 \right] + V \left( \frac{b}{z} \right)[/tex]
[tex] \left( \frac{d z}{d \phi} \right)^2 = 1 - \frac{V(b/z)}{E} - z^2[/tex]
The value for which the r.h.s. becomes zero determines the distance of closest approach [itex]r_0(b, E) = b/z_0(b, E)[/itex]. If we measure the angle [itex]\phi[/itex] from that point, then r increases and z decreases with increasing angle. This means we need to take the negative root of the above equation and the variables separate:
[tex] \phi = \int_{b/r}^{z_0(b, E)}{\frac{d z}{\sqrt{1 - \frac{V(b/z)}{E} - z^2}}}[/tex]
As we take [itex]r \rightarrow \infty[/itex], the angle approaches the "scattering angle". Due to symmetry, we have:
[tex] \theta(b, E) = \pi - 2 \, \int_{0}^{z_0(b, E)}{\frac{d z}{\sqrt{1 - \frac{V(b/z)}{E} - z^2}}}[/tex]
where, again, [itex]z_0[/itex] is determined from:
[tex] 1 - \frac{V(b/z_0)}{E} - z^2_0 = 0[/tex]
Once you know [itex]\theta = \theta(b; E) \Rightarrow b = b(\theta; E)[/itex], you can find the differential scattering cross section from:
[tex] \sigma_d(\theta; E) = \frac{d\sigma}{d \Omega} = \frac{b(\theta; E)}{\sin \theta} \, \frac{d b}{d \theta}[/tex]
More interesting for you is the inverse problem: Given [itex]\sigma_d(\theta; E)[/itex], can you find [itex]V = V(r)[/itex]? This amounts to solving some intergral equations, and is rather involved, so I cannot present it right now. Once you have that, you can find the charge distribution from Poisson's equation:
[tex] \nabla^2 V = \frac{1}{r^2} \, \frac{d}{d r} \left( r^2 \, \frac{d V}{d r} \right) = \frac{q\, \rho(r)}{\epsilon_0}[/tex]
where q is the charge of the projectile.
12K
